Trains.com
The steps taken to upgrade an MTH NS Dash 8 dummy.
  • Member since
    February 2004
  • 15,416 posts
Posted by ChiefEagles on Wednesday, June 15, 2005 9:38 PM
The Railking dummy was pretty much a "Plain Jane" but a great price [new].
So I added the stripes on the frame and a few extra decals which perked it up. Now I was about to attempt to paint the stripes when Tom [Spankybird] told me that automotive pin stripping was the answer. It is!!! Too easy to install and stays [does not chip].
I was not satisfied with that so I went for lighting. A buddy of mine who is a MTH tech was going to send me the pickups, insulators and wires. He had some health problems and it kept slipping. One day I called MTH and talked to a nice lady. We discussed what I needed [two pickups, to bottom plastic insulators, machine screws, nuts, top plastic insulators, black wires and red wires]. She told me she would check with techs and ship them. Well weeks went by. I was about to call her when I had a message on my answering machine that they were shipped and about $21. [the moral of this story is don't give up, they are just slow]. Picked up some 16V lights and mini switches at a hobby shop. Got some two pole connectors at Radio Shack [so I could disconnect the lights in the shell from the wiring in the frame]. Installed the pickups.
Next I wired the lights in the shell [front headlights, back lighs, interior light behind the engineer and ditch lights. [got stick on conduit from Radio Shack to help route the wires]. The bulbs are held in by black sticky W/S sealing "rope" [very sticky and will hold but removable]. Just pull off a little and it sticks anything clean to a clean surface.
Everything came together about the time the *** Teal article came out in CTT. Idea!!! Lets smoke this thing. Emailed *** Teal and he said Lionel smoke unit would work but the 18V for TMCC and DCS might burn it out. Emailed Bob Nelson [lionelsoni], a electrical engineer, on how to reduce the voltage. He explained how to build a bridge rectifier.
Next I started building the bridge rectifier. Got 4 watt 400V ones. Smaller ones would have worked. These were the best. Started with 5 [+ and - soldered together and the ~ from one soldered to the other making them in series]
I picked up a new Lionel smoke unit [was readily available at Miss Edna's]. Immediately took it apart. It was rotating backwards. Reversed the wires. Took out the wick and replaced it with fiberglass insulation. Took the sleeve off of the element.
Did some "bench" testing.
It smoked good with 5 rectifiers.
Used an "L" bracket form Ace Hardware to make amounting bracket to match the Lionel bracket on the unit. I did reverse the ends the Lionel bracket was originally mounted. Elongated the holes to make the bracket adjustable. Got some wide closed cell insulation [one side sticky] from Ace. This became the top gasket. Mounted the unit with another 2 pin connector for easy removal if necessay.
Wired all to two separate switches to give an off/ on postion for lights and smoke unit. These mounted in the holes in the frame made by MTH.
Put everything together and used wire ties to get wiring to go into shell easily.
On the track.
[fan in room blowing smoke to one side]
Found that with one, two or three engines running in TMCC, voltage drop was enough to change the number of rectifiers. Went to three in series. Not quite enough. Went to one. Mighty hot but plenty of smoke. Went to two. Works good.
Above it is in the middle of two NS SD80's lashed.
Here it is in the lead of a NS SD60.
I always have a powered unit behind to take advantage of the electrocouplers. It also looks good behind a string of hopper cars as a "pusher".
This is not that hard to do and does not take too long.
 God bless TCA 05-58541   Benefactor Member of the NRA,  Member of the American Legion,   Retired Boss Hog of Roseyville Laugh,   KC&D QualifiedCowboy
  • Member since
    November 2003
  • 5,608 posts
Posted by dougdagrump on Wednesday, June 15, 2005 10:08 PM
BRAVISIMO !!!!!
[bow]
Remember the Veterans. Past, present and future.
www.sd3r.org
Proud New Member Of The NRA
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Wednesday, June 15, 2005 10:14 PM
Wow thats a pretty cool thing to do. I have yet and doubt I will tinker with any guts of any engines for now until I go through my electrical engineering degree process.
Thanks for inviting me to the forum.
Dave
  • Member since
    February 2004
  • 15,416 posts
Posted by ChiefEagles on Wednesday, June 15, 2005 10:18 PM
Hey Dave. Check out the "Coffee Pot". Another North Carolinian and southerner. [:D] Even better, NCSU [my old school].
  • Member since
    July 2003
  • 2,869 posts
Posted by Bob Keller on Thursday, June 16, 2005 6:31 AM
Two thumbs up! Outstanding job, Chief!
Bob Keller
  • Member since
    March 2004
  • 7,578 posts
Posted by Buckeye Riveter on Thursday, June 16, 2005 6:41 AM
Bob, this should be considered for publication in CTT. First of all this is how for very little money, someone made something much better that it arrived from the manufacturer. Although the author eats grits and talks funny, it still deserves consideration.
Chief, from all of us
[:(!][^][:D][B)][:I][:o)][8D][xx(][V][8][}:)][:X][?][:(][:O][8)][|)][:)]
[:P][;)][alien][angel][*^_^*][banghead][X-)][bow][4:-)][censored][C=:-)][%-)][C):-)]
[dinner][D)][{(-_-)}][(-D][:-,][oX)][sigh][swg][:-^][zzz]
we say
Job well done.
Celebrating 18 years on the CTT Forum. Smile, Wink & Grin
Buckeye Riveter......... OTTS Charter Member, a Roseyville Raider and a member of the CTT Forum since 2004..
Jelloway Creek, OH - ELV 1,100 - Home of the Baltimore, Ohio & Wabash RR
TCA 09-64284
  • Member since
    March 2004
  • 2,292 posts
Posted by jonadel on Thursday, June 16, 2005 7:20 AM
Thanks Chief, I really like the step by step process with the pic's. I'm tempted to this this with my F 3's this fall. You may have just started your own cottage business with this idea.
Good Job[tup][tup][tup]
Jon
Jon
So many roads, so little time.
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Thursday, June 16, 2005 7:37 AM
What was the total price tag, and what was the total hours it would take now that you know what you are doing?
  • Member since
    February 2004
  • 15,416 posts
Posted by ChiefEagles on Thursday, June 16, 2005 8:37 AM
This is my estimate on cost.
MTH pickups and etc. $21 [includes shipping]
Lights and switches $ 9
Radio Shack $10
Smoke Unit $12 [?, bought some other stuff too that day]
Ace Bracket $ 2 [4 in packet and used only one]
Ace foam Insulation $ 5 [used only 1 inch of ten foot roll]
Ace bolts and nuts $ 1
total $60 [about]
had wire, wire nuts, fiberglass insulation and etc.
Time of actual work if I were doing another one and had all the parts. 1 hour or less. Msot of my time was spent tweaking the number of bridge rectifiers needed for this job. Bob Nelson says there is now true formula and the best way is to test it on the track. This took time and removing shell and unsoldering anf resoldering. Now, Bob has come up with another "twist". Installing another switch to "cut in or out" the number of bridge rectifiers and thus changing the amout of smoke. ie. heavy train, more smoke; light train, less smoke. All can be reached without taking the train off of the track.
  • Member since
    July 2003
  • 5,707 posts
Posted by wrmcclellan on Thursday, June 16, 2005 10:19 AM
Nice job Chief! Great writeup!
Regards,
Roy
Regards, Roy
Join our Community!
Our community is FREE to join. To participate you must either login or register for an account.
Search the Community
FREE EMAIL NEWSLETTER
Get the Classic Toy Trains newsletter delivered to your inbox twice a month
