Trains.com
Lionel Giraffe Car
  • Member since
    March 2004
  • 7,578 posts
Lionel Giraffe Car
Posted by Buckeye Riveter on Friday, April 2, 2004 11:52 AM
Please bear with me because I did ask this question before under another post, but never received any responses.
Below is a classic Lionel Giraffe Car. To make the giraffe duck under using Lionel tubular track there is a tell tale with a special slide type bracket.
[?] Does anyone know how to make this car work on MTH Realtrax? I might have a way to do it, but I am looking for simple and best.
Celebrating 18 years on the CTT Forum. Smile, Wink & Grin
Buckeye Riveter......... OTTS Charter Member, a Roseyville Raider and a member of the CTT Forum since 2004..
Jelloway Creek, OH - ELV 1,100 - Home of the Baltimore, Ohio & Wabash RR
TCA 09-64284
  • Member since
    September 2003
  • 356 posts
Posted by rlplionel on Friday, April 2, 2004 4:04 PM
I've never attempted what you want to do, but it seems to me the Realtrax will need to be modified to accept the telltale pole bracket. This would entail cutting into the Realtrax track bed as necessary until the bracket can clip to the track..
Another alternative would be to come up with a device of your own making to place along the track that would catch the giraffe cam like the Lionel bracket does. I guess MTH doesn't have any kind of Realtrax track trip that would help you out?
  • Member since
    December 2003
  • 6,218 posts
Posted by Big_Boy_4005 on Friday, April 2, 2004 4:24 PM
This sounds like a situation where you are going to have to get creative, and make your own gizmo, or at least a special holder for the Lionel actuator. The easiest way may be to notch out part of the roadbed, and use the normal clip.
I just happened to pick up a piece pf Realtrax at the hobby store the other day, so I could look at it. It may be as simple as carving away enough plastic to get the clip to go right on. I think you would have even more trouble with Lionel's Fastrack, because the rail has no base to hold the clip.
The more I look at the Fastrack and Realtrax systems, the more I like the Realtrax better of the two.
  • Member since
    April 2003
  • 5,231 posts
Posted by spankybird on Friday, April 2, 2004 4:29 PM
Hi Buckeye,
The realtrack has a place in the roadbed that snaps out for the lockon. Can you fit or adapt the telltale in there.?
tom
I am a person with a very active inner child. This is why my wife loves me so. Willoughby, Ohio - the home of the CP & E RR. OTTS Founder www.spankybird.shutterfly.com
  • Member since
    March 2004
  • 7,578 posts
Posted by Buckeye Riveter on Friday, April 2, 2004 5:43 PM
Everyone's suggestions are appreciated, and are basically the same as I have been thinking about. Thank you. [bow]
What is interesting is that the by using a new plastic style clip I might also need to add weight to the car to prevent derailments. The original metal clip that came with these cars had a spring tension to avoid the derailment problem but would be difficult to attach to the RealTrax.
TCA 09-64284
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Friday, April 2, 2004 7:59 PM
Or you could put in a piece of tubular track using Realtrax adapting track sections.
  • Member since
    December 2014
  • 105 posts
Posted by jprampolla on Friday, April 2, 2004 8:28 PM
Hi Buckeye,
I use my giraffe car on a section of GarGraves and with a strip of 1/4" plywood, about 12" long and approximately 1/2" wide instead of the metal blade to activate the ducking mechanism. In other words, I matched the height of the original blade as compared to the outside rail. I used two finish nails to attach it to the plywood beneath the ballasted track. I tapered the ends so the yellow bar will slide smoothly up over the homemade blade. For the tell tail pole, I used a block of wood, painted gray, and drilled a hole to accommodate the base of the pole. The block of wood is screwed to the plywood also. This keeps the giraffe's head down longer than the original device that slid under the track. Just be sure your other equipment doesn't get hung up on your homemade blade. I painted the homemade blade black. Hope this helps!
Take care, Joe.
http://www.josephrampolla.com
https://www.youtube.com/user/christmasgarden
  • Member since
    March 2004
  • 7,578 posts
Posted by Buckeye Riveter on Friday, April 2, 2004 10:07 PM
Thanks Joe! I think your suggestion gives me something to work with and develope it further for my layout. Did you need to put extra weight in the car?
TCA 09-64284
  • Member since
    December 2014
  • 105 posts
Posted by jprampolla on Saturday, April 3, 2004 9:45 AM
Hi Buckeye,
No I didn't need any additional weight in the car. I have the finish nails glued into the homemade blade but just friction fit into the plywood of the benchwork, so it is adjustable. I can raise or lower it to fine tune it, and the taper on the ends is gradual, which helps. I did have a clearance problem with my center cab 44 ton diesel, so the blade is perhaps just a bit farther away from the outside rail than the original metal blade. Here is a diagram that might help: http://yourpage.blazenet.net/jprampolla/blade.gif
Take care, Joe
  • Member since
    March 2004
  • 7,578 posts
Posted by Buckeye Riveter on Saturday, April 3, 2004 2:48 PM
Thanks Joe. I appreciate the sketch.
TCA 09-64284
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Monday, February 12, 2007 9:15 AM
 jprampolla wrote:
Hi Buckeye,
Take care, Joe
Any chance you could re-post your homemade Giraffe mechanism online or in this forum?  I just picked up the Giraffe car at a train show and I need to rig something up to work with FasTrack.  Anyone have any suggestions specific to FasTrack?  Thanks in advance.
  • Member since
    December 2014
  • 105 posts
Posted by jprampolla on Monday, February 12, 2007 12:37 PM
Hi Folks,
      Here it is:
Take care, Joe.
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Monday, February 12, 2007 12:50 PM
Thanks Joe!
  • Member since
    November 2003
  • 2,047 posts
Posted by brianel027 on Monday, February 12, 2007 8:41 PM
I did something very similar to what Joe did above, only I use long pieces of brass that are bent at a slope on each end. I use these on the straight away sections. On my previous layout, I made manually operated shorter trips for curves made from basswood and attached to a rod with a spring mounted in the layout surface, held down by fishline going to the front of the layout. When I would release the fishline lock the trip would "automatically" extend up ward and operate the car on my 027 curves. Then I could pull the trip back down to not interfere with any other car's overhand on the 027 curves.
I may adapt this idea for the curves on the new layout, space permitting, since the new layout is smaller than the previous one I had. I may also operate the curve trip with bicycyle brake cable.
brianel, Agent 027
"Praise the Lord. I may not have everything I desire, but the Lord has come through for what I need."
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Monday, February 12, 2007 11:58 PM
I may have to do some very creative work to get my Giraffe to work properly.  From what I've been told the Giraffe is usually up (head above the roof) by default and its switch lowers it (perhaps to go through a tunnel).  My Giraffe must be shy because she likes to hide inside.  Upon further inspective I believe my car is missing a few components (broken plastic piece and perhaps a spring?).
  • Member since
    March 2004
  • 7,578 posts
Posted by Buckeye Riveter on Tuesday, February 13, 2007 7:53 AM
Yes, your giraffe is broken, but parts are readily available for repair from just about any Lionel parts dealer.
Has anyone painted the giraffe to look more like a giraffe than a yellow stick?
TCA 09-64284
  • Member since
    December 2014
  • 105 posts
Posted by jprampolla on Tuesday, February 13, 2007 12:27 PM
Hi Buckeye and Folks,
    I have touched up the paint on the sheriff and outlaw figures which are sort of rubbery, with acrylics paint, but I guess you could repaint the giraffe with craft acrylics paints, too.  I have had good luck without priming many plastics, just wiped down a clean figure with rubbing alcohol, let dry, then painted it with acrylics, but you wouldn't want to paint the figure on a valuable giraffe car since it would lessen its resale value to collectors.
   Take care, Joe.
  • Member since
    September 2003
  • 356 posts
Posted by rlplionel on Tuesday, February 13, 2007 9:17 PM
Wow, this thread is almost three years in the making! Here's a little video clip of the giraffe cars in action to commemorate it.
Giraffe cars video
  • Member since
    September 2006
  • 15 posts
Posted by ChooChooMan2 on Tuesday, February 13, 2007 10:20 PM
Got one of these Giraffe cars when I was 6 in 1962.  Very cool car.  A lot of fond memories.  I still have it.
Jeff
  • Member since
    March 2004
  • 7,578 posts
Posted by Buckeye Riveter on Wednesday, February 14, 2007 10:18 AM
   Take care, Joe.
Thank you JOE!!!  I have been waiting for someone, with better artist skills than me to discuss the painting of the Sheriff and Outlaw Car.  My car is a 1960's model.  What colors did you use?
As to the Giraffe, I believe the Giraffe that was used in the old and new cars are the same mold.
TCA 09-64284
  • Member since
    December 2014
  • 105 posts
Posted by jprampolla on Wednesday, February 14, 2007 11:06 AM
        I didn't repaint the sheriff and outlaw, just touched up their hats and the clothing a little leaving the faces as they were.  I used black acrylic for the outlaw's hat, and for the sheriff's hat and neckerchief, I used Burnt Umber with Sable, with just a dot of Orange, but a craft store, even Wal-Mart, will probably have the same color of brown as the original hat.  I have repainted plastic animals and I use a shading method, similar to the old furniture antiquing technique, of applying a tinted wash made from a drop of Rust acrylic paint, Flow Medium, and Extender, or a drop of paint in about a teaspoon matte acrylic varnish.  My page: http://www.josephrampolla.com/lions.html shows repainted Fisher-Price lions.  After just repainting in sold colors, the wash brings out detail and adds shading automatically.  Just apply the wash and wipe off the excess.  The less you fuss, the better it looks.  I used the same technique of the wash to bring out facial features on figures of people.  The wash stays in the sculpted recesses of the figures and you wipe off the excess with a cotton swab, or dry paint brush. Very easy and if you don't like what happens, you just wipe it off before it dries and start over.  I often build up the shading in 2-3 applications of a wash.
      If the brown spots on your giraffe are worn off, and you don't mind the yellow color of the bare plastic, I would just touch up the spots.  I am very sentimental about my old stuff so I keep the original appearance.
      Take care, Joe.
  • Member since
    December 2014
  • 105 posts
Posted by jprampolla on Wednesday, February 14, 2007 11:18 AM
Hi Robert,
      Just love those giraffe cars!!!!!  Thanks for sharing your vid of them in action!
    Take care, Joe.
  • Member since
    March 2004
  • 7,578 posts
Posted by Buckeye Riveter on Wednesday, February 14, 2007 11:21 AM
Thanks, Joe for the tips.  I liked the video too.
TCA 09-64284
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Thursday, February 15, 2007 8:30 PM
We have liked the Giraffe cars since seeing four in a row duck there heads on a layout in a hobby shop years ago.  I had to start searching them out and picked four over the next year or two at train shows.
With three bridges and a twin tracks looping thru a mountain tunnel we have lots of giraffe heads hopping.  I installed guide rails before, thru and after each bridge.  I only put the guide rails before and out of the tunnels to make it look like the head was down the whole time.  The curves is the tunnels was too much to mess with.  I only installed the guide rail on one side and it only works in the counter clockwise direction.  Since we have double reversing loops on all loops we change directions all the time and this is no problem.
I will have to make giraffe movie for U tube before the layout get put up for the summer.
Charlie
  • Member since
    October 2004
  • 7,607 posts
Posted by laz 57 on Thursday, February 15, 2007 10:55 PM
Nice video.
laz57
  There's a race of men that don't fit in, A race that can't stay still; Robert Service. TCA 03-55991
Join our Community!
Our community is FREE to join. To participate you must either login or register for an account.
Search the Community
FREE EMAIL NEWSLETTER
Get the Classic Toy Trains newsletter delivered to your inbox twice a month
