Trains.com
My Father's Lionel 2020
  • Member since
    December 2009
  • 16 posts
Posted by PhillyDuke on Monday, January 11, 2010 8:58 PM
So I dug through my dad's old steamer chest in my basement to see what I had in the way of O-Gauge, remembering that my sister got many of them when I took the HO stuff nearly 10 years ago. What I found was a Lionel 2020 & 2020W tender. The tender was in its box, but the engine was in a box marked "3451." The engine looks to be in decent shape, albeit a bit dirty and lacking some paint around the stack. The tender is pretty dirty and could use a scrub down and perhaps a repaint.
Anyhow, I plan on taking them over to my LHS to see if they can get them running smoothly (I know NOTHING about taking these apart), and I may look into completely refinishing them with new paint and fresh decals. I'm planning on running them, not keeping them as collector items, so I'm not concerned about all the decor being "original."
My question is this: I'm sure this came as part of a set (my sister probably has the other pieces), but I'd like to try to build a postwar consist with this as the engine and would prefer to keep the cars as accurate as possible. So what cars were originally pulled by this engine? I'm guessing the #3451 log dump car is one...any others?
If nothing else it'll give me a long-term project to work on and some neat treasures to search for at York in April. Thanks in advance!
  • Member since
    December 2001
  • 10,096 posts
Posted by lionelsoni on Monday, January 11, 2010 9:16 PM
If you're going to repaint it, you might want to change the number to that of the prototype (there was only one!)--6200.
Bob Nelson
  • Member since
    November 2007
  • 3,780 posts
Posted by RockIsland52 on Monday, January 11, 2010 10:02 PM
PhillyDuke.....I have not had a chance to welcome you to the Forum, so Sign - Welcome
I personally like your idea of taking your Dad's 2020 S2 Turbine, getting it professionally serviced, conduct a thorough shell cleaning, and replicating/securing the same freight cars that came with the original set.
Read this for some basic Lionel and actual history on your engine: http://www.postwarlionel.com/cgi-bin/postwar?ITEM=2020
This link will tell you what year the engine was manufactured.  The 2020W whistling tender came with models made in 1946 and 1947.  Ask the repair guys if it has a smoke bulb or a smoke element.  If the former, you have a 1946.  If the latter, you have a 1947.
Hopefully one of the other guys with some reference material will jump in here and tell you what freight cars came with a 2020 set.  I don't have any of these books.
When it comes time to clean the shell, AFTER you have had it serviced, ask for advice here in the Forum.  64 year old paint can be delicate, but you may be pleasantly surprised at how good you can make your Dad's engine look with just a little patient cleaning.  It is not difficult to remove the shell for cleaning or to put it back on.
Every nick and scratch on your engine tells a story about the owner (your Dad) and the times.  My steamer has not been repainted.
Re the 3451 box.....that may have been the original box for one of the freight cars.  A Lionel 3451 was an operating Log Dump car.  http://shop.ebay.com/i.html?_nkw=lionel%203451&_dmpt=Model_RR_Trains&_fln=1&_sc=1&_sop=16&_sticky=1&_trksid=p3286.c0.m283&_rdc=1
Hope to see some before and after pictures!
Jack
IF IT WON'T COME LOOSE BY TAPPING ON IT, DON'T TRY TO FORCE IT. USE A BIGGER HAMMER.
  • Member since
    November 2007
  • 3,780 posts
Posted by RockIsland52 on Tuesday, January 12, 2010 4:47 AM
Regarding trying to replicate the cars that would have come in a set with your Dad's 2020 steam engine, check out this web site for the freight car numbers for different sets, by year, headed up by your Dad's engine.  The freight cars are probably available at Ebay or your local train store if they sell used.
http://www.lionel-train-set.com/1946/1946.htm
In 1946 there were two sets that were headed up by the 2020 and included the operating log dumping car 3451.....1417WS and 1421WS.
In 1947 there was only one set......1441WS.
Once you find out whether your engine has a smoke bulb (1946) or a smoke element (1947), you can start hunting for the correct freight consist.  It is possible your Dad did not buy a set but acquired the train items ala carte so to speak.  Also, back then it was not uncommon for train and hobby shops to pull apart complete sets to get what they needed quickly for a customer.
Hope this helps,
Jack
  • Member since
    July 2007
  • 409 posts
Posted by PhilaKnight on Tuesday, January 12, 2010 8:56 AM
This brings back memories. The 2020 was the first engine my dad gave me or should I say found while looking in the basement closet when I was about 12. Like most it was only missing the back steps. It was and still is my favorite engine. I found it packed in a old C-Ration box with some box cars and a caboose. I must have dumped tons of money into to keep it running but it's worth more in sentimental value than Greenburg could put a price on.
  • Member since
    August 2007
  • 320 posts
Posted by Bob.M on Tuesday, January 12, 2010 8:58 AM
 FWIW, Williams made a version of this one-off prototype, the PRR S2-100 Turbine. It matches the Lionel postwar size, and as such looks small next to any Scale engines. I measured it, and it is 20" long including the tender. I wonder how long the actual Lionel version is?
  • Member since
    January 2005
  • 4,014 posts
Posted by phillyreading on Tuesday, January 12, 2010 9:49 AM
Along with what others have said, Greenberg's price guide lists the 2020 being made in 1946 and again in 1947 thru 49. Maximum value according to Greenberg for a 1947 to 49 loco and tender is $208.00, the max value for the 1946 loco & tender is $222.00.
See what it will cost to have a hobby shop overhaul it, clean and lube it, as you may have sticker shock if you don't ask for an estimate first!! If you want to hold onto the engine & tender by having it repaired or lubed & cleaned that is up to you. Sometimes sentimental value of an item gets expensive to maintain it in working order.
As somebody else mentioned Williams by Bachmann makes a nice Pennsylvania S-2 steam loco similar to the Lionel 2020, looks more like a post war Lionel 681, but is way less expensive.   I bought a Williams S-2 Pennsy steam engine and it runs great, has plenty of power and low end starting power.
Lee F.
Interested in southest Pennsylvania railroads; Reading & Northern, Reading Company, Reading Lines, Philadelphia & Reading.
  • Member since
    August 2007
  • 320 posts
Posted by Bob.M on Tuesday, January 12, 2010 3:10 PM
Here is a picture of the original.  I am a little confused about all the different numbers mentioned. The late 1940s Lionel was 2020. My 2004 Williams is 671, another number, 681 was mentioned and the full scale prototype shown here is 6200. If I were the restoring a Lionel model owned by my father, I  would use the original 2020, as that is what the old man saw when he ran it. Just my opinion.
 #6200
 This is my Williams version taken March, 2004.
  • Member since
    December 2007
  • 679 posts
Posted by Berk765 on Tuesday, January 12, 2010 4:18 PM
Sign - Welcome to the forum. Those Lionel turbines were great little engines and still are. I have a 681 which is basically an O gauge version of your 2020 with magnatraction. It is by far my most powerful pulling engine. Postwar engines are easy to take apart to clean and lubricate.
 There are three screws that hold the shell on to the chassis. Take the screw out that is on the front of the chassis off first and then the boilerfront should slide off. Once the boilerfront is off you should see a headlight bulb in a socket that is mounted in a clip that should snap off with ease. And then take the two long screws out that are on the back part of the frame and the shell should slide off.
 Once you take the shell off you should see your motor in the back an e-unit in the middle and the smoke unit in the front part of the frame. Before you run it there is a hole in the motor's metal casting, that is an oil resorvoir, make shure you fill it up with oil before you run it. Since your engine doesn't have magnatraction, there might be a lead weight mounted by two screws over the gear box. Just remove the wieght to reveal the gearbox. Sometimes grease gets hard so make shure you clean the gears before you apply new grease. I hope any of this helps.
Give me steam locomotives or give me DEATH!
Berkshire Junction, bringing fourth the cry of the Iron Horse since 1900.
  • Member since
    November 2007
  • 3,780 posts
Posted by RockIsland52 on Tuesday, January 12, 2010 4:37 PM
Lionel made 4: the 2020, 671, 681, and 682.  A buddy of mine has the 671RR which is sitting on my layout as we speak.  I know the 6200 designation BobN mentioned appears in a red surround on the boilerplate of the 671RR.  The 2020 is unique in that it was the only one of the 4 Lionel releases that had nickel rims on the drivers like the actual prototype photo BobM provided.  There were several tenders that were released with these releases.
Jack
  • Member since
    December 2007
  • 679 posts
Posted by Berk765 on Tuesday, January 12, 2010 5:04 PM
The real Turbine locomotive had two steam turbines that were directly geared to one of the driving axles, one turbine was for reverse and one was for forward moving. The turbine had no vibrations that normally would tear up tracks at high speeds (such as the massive side rods and reciprocating pistions) so this engine could easily go over 100 mph. It was scrapped because the turbine guzzled down fuel and water at high rates at slower speeds and the turbine was very delicate and hard to maintain. I really wished this locomotive was saved nonetheless because it was my favorite steam locomotive experiment. It made a loud WHOOOSH sound as it went down the tracks.
  • Member since
    July 2009
  • 951 posts
Posted by servoguy on Tuesday, January 12, 2010 5:57 PM
 When you lube any of the turbines or the 726/736, you should lube all the axles with oil and also the side rods on the 726/736 the piston rods.  These engines transmit the motor torque through the side rods, and failure to lube them will result in premature wear.
 I bought a 736 about a year ago that was locked up solid because the grease had dried out.  I haven't done a serious clean and lube for it yet, but I got it running by using WD-40 to soften the grease.  It has been sitting for most of the past year and is still turns free.
Lubing the motor with oil through the oil hole that is between the armature and worm is very important.  One of the few motors I have seen worn out was from a turbine, and it had no sign of oil anywhere.  The rear bearing was so loose the motor would not run.
Bruce Baker
  • Member since
    July 2003
  • 2,214 posts
Posted by Roger Bielen on Tuesday, January 12, 2010 6:06 PM
I checked a ref. book at work today and found the following info.:
My original set, that I still have.
1947  Set # 1443WS
2020 loco, 2020W tender, 3459 operating ore car, 3462 operating milk car, 2465 Sunoco 2 dome tank car, 2457 lighter Penn N5 caboose, Type S transformer, and track.
1946  Set # 1415 WS
2020 loco, 2020W tender, 3459 operating ore car, 3454 operating merchandise car, 2465 Sunoco 2 dome tank car, 2472 unlit Penn N5 caboose, 1041 transformer and track.
Most of these cars are readily available at reasonible prices.
Roger B.
  • Member since
    December 2001
  • 10,096 posts
Posted by lionelsoni on Tuesday, January 12, 2010 6:23 PM
According to Paul Ambrose, nickel rims appeared on both early 671s and early 2020s.  Lionel says that the locomotives are identical.
Bob Nelson
  • Member since
    August 2007
  • 320 posts
Posted by Bob.M on Tuesday, January 12, 2010 7:12 PM
 My 1948 catalog shows 2 consists using the 2020:
1. 1447WS = 2020 steam turbine, 6020W tender, 3451 automatic lumber car, 2461 transformer car, 2460 crane car, 6419 wrecker-caboose. This set cost $59.50.
2. 1449WS = 2020 steam turbine, 6020W tender, 3462 Automatic milk car  , 6465 oil car (2 dome), 3459 automatic ore dump car, 6411 flat car, with a load of logs, 6537 illuminated caboose. $65.00.
Since the engine was found with a 3451 box, I'd guess it was the 1447WS set. If anyone asks, I could type in the other parts of the set, xfmr, etc. Both sets were O27. While it is obvious that the "WS" stands for Whistle & Smoke, I am guessing that the 2020 designation relates to the number of wheels on the engine. There are 3 consists involving the 671 in the same catalog, but they are "O" gauge.
I got my answer as to the length of the Lionel model: Catalog says 18 7/8".
Looking at the picture of the 1:1 scale model, and other pictures I have, it appears that the tender has a total if 16 wheels. in an 88 pattern. The Lionel/williams versions have (only) 12 wheels.
  • Member since
    November 2007
  • 3,780 posts
Posted by RockIsland52 on Tuesday, January 12, 2010 8:09 PM
PhillyDuke said he is sure his Dad's 2020 with the 2020W tender were part of a set, his sister probably has the rest, he has the box for the 3451 operating log dump car, and he prefers to keep the cars as accurate as possible.  I took that to mean he prefers to keep the cars as accurate as possible to the set his Dad had.
The 2020, 2020W and 3451 were together in a set only for 1946 and 1947.  That would mean he is looking only for sets 1417WS and 1421WS for 1946, and 1441WS for 1947.
Only the 1946 2020 engine had a smoke bulb.  If he finds his engine has a smoke bulb, he is looking at either set 1417WS or 1421WS.  If he has a smoke element, he has a match with set 1441WS.
In another thread someone said you can look down the smoke stack and if the 2020 has a smoke bulb you can see it.
Jack
  • Member since
    December 2009
  • 16 posts
Posted by PhillyDuke on Tuesday, January 12, 2010 8:29 PM
Wow, such great responses all around. Thanks! Yes, I do have the 2020 and 2020W, so I'm looking at a 1946 or 1947 set (my Dad was born in '38, so this makes sense), and the box the engine is in was a 3451 log dump car (which I believe I remember seeing when my sister claimed the rest of the O-Gauge), so I guess I need to nail down the year now.
Unfortunately the O-Gauge service/repairman at Nicholas Smith only works on M-W-F, so I wasn't able to bring the set by today. I'll probably drop by on my lunch tomorrow and see if he can at least ID the smoke unit.
As far as repainting goes, there are some areas that definitely lost paint, but as someone mentioned, although the cab reads "2020", there is a PRR Keystone decal on the front of the engine that reads "6200". I'll try to take a few pics and get them posted.
  • Member since
    November 2007
  • 3,780 posts
Posted by RockIsland52 on Tuesday, January 12, 2010 8:43 PM
PD......Of the 8 drive wheels, how many have the nickel edges versus plain black?  If you look down the smoke stack, can you see what looks like a light bulb?  We might be able to determine the engine year without the repair guy.
Jack
  • Member since
    December 2009
  • 16 posts
Posted by PhillyDuke on Tuesday, January 12, 2010 9:16 PM
OK, I was curious so I broke out the 50D to take some pictures. I'm guessing this is a '46, because the smoke unit looks like a bulb with a depression in it to me. Can't really tell if the drivewheels are nickel or not. The front of the unit looks like it's seen better days, with lots of what I can only imagine is smoke pellet residue and some corrosion. There are even areas that look completely eaten through. The bulb access door looks like it was forced open/shut a few times, too:
  • Member since
    November 2007
  • 3,780 posts
Posted by RockIsland52 on Tuesday, January 12, 2010 9:57 PM
Philly....if you look at each drive wheel, it appears silver on the edge.  As you move toward the center of each drive wheel, the color is black.  The 1946s had these wheels.  But so did all of the 1947 units.  But that must be a smoke bulb I see too, making the engine a 1946.  Since I am neither a 2020 or smoke bulb expert, I am going to touch base with someone else on the Forum to take a look for us.  He's got a 1946 version.  We are getting close.  Regarding the boiler, boiler plate, and the steam chest, it does look from the pictures that a simple cleaning won't do the trick.  Same whith the tender shell which is plastic.  Not a problem because some guys on the forum have stripped and repainted both the engine and the tender.  They know the entire process from stripping and prep all the way to the correct paint, color as well as sheen, the correct numbering process, and other details.  The cab on the back appears straight, not bent or chipped.  That's a plus.  Let me run down Jim T who I believe refinished his Dad's 1946 2020 and is currently posting and showing video of his completed refurbishing project.  He replaced the smoke bulb with a smoke element because he wanted more smoke.....and boy did he get it!
My repair guy prefers the shell left on my steamers when I drop them off to protect everything inside.  You may want to wait on the cosmetics until your repair shop is finished with the R&R and the engine is sound operationally.  You can go from there on the cosmetics.
I'll get back to you.
Jack
  • Member since
    December 2009
  • 16 posts
Posted by PhillyDuke on Tuesday, January 12, 2010 10:05 PM
Thanks, Jack! I look forward to hearing from you and seeing Jim's video.
  • Member since
    November 2007
  • 3,780 posts
Posted by RockIsland52 on Tuesday, January 12, 2010 10:20 PM
I'm trying to contact JimT (green97probe) asking if he would read your thread "My Father's Lionel 2020" and weigh in on your master plan.  In the meantime, read his thread "1946 Lionel 2020" and find his post where he provides a link to his youtube video running his finished product.  Will knock you over!
Jack
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Wednesday, January 13, 2010 12:43 AM
PhillyDuke,
                  I just got Jack's message, and I have looked at the pics you've posted.  As for cosmetics, I'd leave her exactly as she is now.  The paint has less than average wear, and the only thing that really needs attention is the smoke unit.  If it was really bad, then I'd say restore it, but it looks great just the way it is.  Also, restored pieces, no matter how well done, just don't have the same character that they had originally IMHO. The spots on the boiler, as well as the corroded smoke unit, are the result of the ammonium nitrate pellets that these early units used.  Ammonium nitrate is not stable, and it will eat metal when it is in the liquid state.
These engines are very easy to service, and I'd suggest that you do it youself instead of taking it to someone.  It will be much cheaper, quicker, and a great learning experience to do it yourself.  Plus, you'd know that the job was done right.  I'd be more than happy to walk you through it online or over the phone.
  • Member since
    July 2003
  • 1,786 posts
Posted by cwburfle on Wednesday, January 13, 2010 4:39 AM
As Jim states, it's a 1946 turbine, with it's original smoke bulb unit. Starting in 1947, Lionel offered a kit to convert those units to the nichrome wire heater type unit. (Those kits were available as late as 1969).
Original smoke bulbs are available, but are generally way overpriced.
Good reproductions have been made, and are reasonably priced.
Be aware that with a smoke bulb, the engine will smoke poorly, or not at all.
The bulb just does not get hot enough for the modern smoke materials.
The original smoke material has not been available in years, because it's nasty stuff.
IMHO, the engine is not bad enough to repaint, nor would I convert the smoke unit.
Doing either would ruin it's character / uniqueness. .
But it's your train, do whatever makes you happy!
  • Member since
    December 2009
  • 16 posts
Posted by PhillyDuke on Wednesday, January 13, 2010 9:45 AM
Jim,
Thanks so much for taking a look. I'm somewhat torn as to whether to leave things as-is or take a crack at restoring it to it's former glory. That said, I'm still going to drop by Nicholas Smith on my lunch today and see if it at least runs (I have no layout set up right now), and pick up some supplies to maintain it.
I'd love to touch base with you and pick your brain on how best to clean this up and service it. I may feel differently about doing a complete cosmetic overhaul once the corrosion and spots are off the boiler and smoke/headlight unit. The tender could use some TLC as well. Feel free to PM me and we can either pick this up there or I'll give you my offline contact info. Depending on where in PA you are we might even be able to meet up in person.
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Wednesday, January 13, 2010 10:16 AM
Philly,
              I'll send you a PM.
  • Member since
    December 2007
  • 679 posts
Posted by Berk765 on Wednesday, January 13, 2010 11:23 AM
PhillyDuke
Wow your engine is very nice dude. I would replace the smoke bulb holder though. The early smoke pellets Lionel used were very corrosive. I believe they were ammonium nitrate?
  • Member since
    August 2007
  • 320 posts
Posted by Bob.M on Wednesday, January 13, 2010 11:43 AM
 I am curious as to what transformer you found with the engine (if any). Back then, I had  types "R", "N" and "B", plus a prewar model that would give me a shock whenever I touched it. (It is gone now).
  • Member since
    December 2009
  • 16 posts
Posted by PhillyDuke on Wednesday, January 13, 2010 12:17 PM
Berk765
I'd love to! Anyone know where I can acquire the replacement part? It's pretty much beyond cleaning at this point. I don't want to necessarily get the smoke running again (at least not in its original form), but the holes in the metal concern me some. I'm hesitant to replace it with one of the '47-'49 smoke units, as I was informed that this involves tapping and drilling, making the modification irreversible. I would, however, be interested in what Jim did with his 2020 if he's able to find a way to get the headlight working again.
Bob.M
Unfortunately I don't remember if there was one, or what it was if there was. It's been many years since we divided up my father's toys.
Just as an update, it's been determined that the majority of the white spotting on both the boiler and the tender are mildew and not ammonium nitrate corrosion. Anyone know of a safe way to remove the mildew w/o removing the paint?
  • Member since
    November 2007
  • 3,780 posts
Posted by RockIsland52 on Wednesday, January 13, 2010 12:27 PM
PhillyDuke…….your pictures really turned out great in lighting, angles, and detail.  I also agree with the responses you got.  I’d get it back to operationally sound and put a little TLC into cleaning it up.  Then run it while you are backfilling the original set.
To me, the beauty of an heirloom piece isn’t in its perfection but is actually in its imperfections.  As I wrote to you, each cosmetic item which may drive some guys wild has a story behind it, a personal one for you.  Once restored or touched up, you can’t unrestore it or or remove the touch ups.  CW said it well: the beauty is in the unvarnished originality.   With the shell off….. the insides appear to be remarkably clean and well preserved except for the smoke bulb unit.   If you had the opportunity so see other 64 year old 2020 shells that are out there for sale, here is what you might observe about your own unit.  It’s dirty, but had Dad removed the smoke pellet residue periodically and/or before he stored it away…….family story #1. The drive rods are clean.  The headlight lens in the boilerplate is there.  The 6200 marker on the marqee is intact though a little rough.  The “catcher” and front steps are intact and solid.   The hand rails are straight and the support guides are all there and straight.  The rear cab appears straight with no metal chips.  The numbering is sharp enough.  The pickups are there and appear unbent.  The underside is clean and is not infested with corrosion or rust.  The drive wheels with the nickel rims are clean.  The front pilot truck is there and appears straight as does the rear truck.   With a good cleaning, oil and lube,  an examination of the e-unit, a swap out of the old brushes and brush springs, and you may find yourself good to go.  And you need to make a decision on the smoke: replace with original bulb setup, or consider the correct conversion heating element if you want more smoke. Keep us posted.  And when it comes to cleaning the shell, ask for guidance.  64 year old paint, numbers, and decals are delicate.
Jack
Join our Community!
Our community is FREE to join. To participate you must either login or register for an account.
Search the Community
FREE EMAIL NEWSLETTER
Get the Classic Toy Trains newsletter delivered to your inbox twice a month
