Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Tortoise Switch Machines
  • Member since
    October 2009
  • 2 posts
Posted by arizonaredneck on Tuesday, October 6, 2009 12:41 PM
I'm trying to install Tortoise switch machines and Peco turnouts.  The switch machines work fine, but they don't seem to have the power to switch the turnouts.  Any ideas on what I'm doing wrong?  Thanks.
  • Member since
    February 2008
  • 8,877 posts
Posted by maxman on Tuesday, October 6, 2009 1:42 PM
HO scale Peco?  They have a spring that will allow you to move the points by hand and keep them tight against the stock rails.  The Tortoise has to overcome this spring.  If the Tortoise is throwing completely, then it is likely that you need to use a larger diameter wire than the one the Tortoise is supplied with because the original is bending.  Most people remove the Peco spring when they have some alternate method, other than finger power, to actuate the turnout.
However, it is also possible to reduce the spring tension and keep the spring in place so that you don't lose it.  The Peco instructions should have a section on replacing the spring.  There are two tabs that you have to bend up to remove the spring retainer.  If you just loosen these tabs and slide the retainer to the direction opposite to the position you found it in, and then tighten the tabs, you should find that the tension has been reduced but you will still have the spring in case you want it.
Note that the above pertains to Peco code 100.  If you have code 83 that might be a turnout of a different color.
  • Member since
    January 2001
  • 406 posts
Posted by donhalshanks on Tuesday, October 6, 2009 1:58 PM
I had same problems on some turnouts and solution for me was as Maxman outlined.... stronger wire on the Tortoise.  I didn't have Peco, but the Tortoise was more than the usual distance below the road bed.  Heavier green wire used for flower arrangements bought at Michael's or any store with artifical flowers worked fine.  I had to enlarge the hole in the Tortoise to accept the larger diameter wire.  Easy to do.
Hal
  • Member since
    March 2007
  • 2,751 posts
Posted by Allegheny2-6-6-6 on Tuesday, October 6, 2009 3:37 PM
 As mentioned remove the spring clip it's easily over looked. I use .047 music wire form K&S engineering stock # 502. I have no idea why they call it music wire as it's used to operated control surfaces on R/C planes etc.
You will need to drill out the hole on the Tortoise to accommodate the larger wire. I typically use this when I want to remotely mount a switch machine but don't have the room to do so directly under the turnout. I can operated a turnout up to 2 feet away without flexing the wire. The secrete is put the wire inside a brass tube slightly larger then the wire and secure the tube to the bench work. Some guys claim you need to run the lighter stuff Circuitron gives you to keep tension on the switch once it's thrown but I have yet to have a problem.
Just my 2 cents worth, I spent the rest on trains. If you choked a Smurf what color would he turn?
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Tuesday, October 6, 2009 6:32 PM
 In case you were curious - model railroaders and rc plane people are just small users of music wire - it really IS used for musical instruments
http://en.wikipedia.org/wiki/Piano_wire
                               --Randy
Modeling the Reading Railroad in the 1950's
Visit my web site at www.readingeastpenn.com for construction updates, DCC Info, and more.
  • Member since
    October 2009
  • 2 posts
Posted by arizonaredneck on Wednesday, October 7, 2009 12:37 PM
Problem solved - the spring was the issue.  Many thanks to all who took the time and trouble to help.
  • Member since
    March 2007
  • 2,751 posts
Posted by Allegheny2-6-6-6 on Wednesday, October 7, 2009 4:19 PM
rrinker
                               --Randy
 No offense Randy but no not interested at all..............lol I get all the unwanted music knowledge from my 16 year old step son who is in the high school marching band but doesn't play an instrument figure that one out. I hear more useless crap at the dinner table about , metronomes (I guess their little ugly guys who live in the subway) bars scores, times, bla bla bla.
It's real purpose is for operating r/c planes and trains there is nothing else  important............lol
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
