Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
digitrax delima!!!!!!! please help
  • Member since
    May 2008
  • 52 posts
Posted by KEKALIGHTING on Thursday, July 30, 2009 10:36 AM
Hey there guys,
I have a nightmare I am trying to figure out.
I have a dt-400r  5amp digitrax booster.
Lastnight I tried programing a digitrax dz125 in one of my old kato units.  I went through the steps to program the decoder with a 4 digit address.
much to my suprise the engin takes off at the highest speed the loco can achive. I start with the throtle at speed 00, then as soon as I increase it to 01 the loco speeds off. There is no difference if you are at 01 or 99 it stayes at the fastest speed possible. Also I noticed the lights dont respond to the on off function they are just off.  I have double checked my wiring and no problems there.
I have done over 50 n scale decoder installs and this is the first time I have seen this. Any thoughts?
Thanks,
Frank
  • Member since
    May 2008
  • 52 posts
Posted by KEKALIGHTING on Thursday, July 30, 2009 11:01 AM
I can read the address.  I am going to meter the connections on the motor to the chassie and see if that could be the problem. I am at work now so when I get home I will have to try. I will let you know.
  • Member since
    February 2006
  • 1,987 posts
Posted by jbinkley60 on Thursday, July 30, 2009 4:41 PM
KEKALIGHTING
Hey there guys,
Thanks,
Frank
Turn off analog compatability support in CV29.  I've had this happen before.  Since I turned off analog compabaility on all of my units, I have never had another run away.
Engineer Jeff NS Nut
Visit my layout at: http://www.thebinks.com/trains/
  • Member since
    May 2008
  • 52 posts
Posted by KEKALIGHTING on Friday, July 31, 2009 4:47 AM
Engineer Jeff
That was it. Thank you so much.
  • Member since
    February 2006
  • 1,987 posts
Posted by jbinkley60 on Friday, July 31, 2009 6:47 PM
I am glad it workd for you.  It's a trick I learned the hard way a number of years back.  It almost cost me a new Atlas Gold Dash 8.
  • Member since
    December 2002
  • 1,511 posts
Posted by pastorbob on Tuesday, August 4, 2009 8:39 AM
I learned the same trick with NCE many moons ago.  My diesels will never run on DC anyway.
Bob
Bob Miller http://www.atsfmodelrailroads.com/
  • Member since
    May 2004
  • 23 posts
Posted by jwilliam33 on Saturday, August 8, 2009 12:08 PM
CV29 is set to 0.  Any other thoughts?
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Saturday, August 8, 2009 1:22 PM
CV29 at 0 is an invalid value. If you are using an address of 127 or less, CV29 should be 2. If you are using an address greater than 127, CV29 should be 34. Either setting has DC turned off, basic operation without a speed curve, and using 28/128 speed steps.
Also I will add that I have NEVER seen this "instant takeoff" issue with any brand of decoder I've used (Digitrax, NCE, TCS) when DC conversion was turned on. The odd runaway when powering on the track, yes, but if the loco was stationary and I advanced the throttle to step 1, I never had any of the suddenly take off. It COULD be caused by invalid value sin other CVs, which is why I ALWAYS reset a new decoder as the first step in programming it. There are many more CVs than are documented, reserved for manufacturer use, and who knows what values do what, or what may have been set int he decoder for factory testing. Just reset first, and then program, so you knwo you will be starting with a clean slate. WHen even the lights don;t work, somethign is very wrong, and CV29 bit 2 (DC conversion) is NOT goign to fix the behavior of the lights. But CV29 with some unsupported value - who knows what the loco will do. Setting a proper value would clear it up - and resetting the decoder would definitely set a proper value AND a known address - 03.
                                --Randy
Modeling the Reading Railroad in the 1950's
Visit my web site at www.readingeastpenn.com for construction updates, DCC Info, and more.
  • Member since
    February 2006
  • 1,987 posts
Posted by jbinkley60 on Saturday, August 8, 2009 4:24 PM
All of my locomotives are set to CV29=34 or CV29=35, depending upon direction.
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Saturday, August 8, 2009 4:32 PM
As are my road engines - silly P2K making their GP-7's 'backwards' Big Smile  But my switchers all have 2 digit cab numbers so they are all at 6. Luckily no on had the idea that the cab end of an S-1 is 'front' so I didn't have to use 7.
                           --Randy
  • Member since
    February 2007
  • 2,134 posts
Posted by CSX Robert on Saturday, August 8, 2009 7:43 PM
0 is not an invalid CV29 value. 0 means 14 speed steps, analog conversion off, forward normal direction of travel, and 2 digit addressing.
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
