Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
double deck railroads pros and cons
  • Member since
    January 2008
  • 66 posts
Posted by trainfan504 on Tuesday, March 10, 2009 1:46 AM
 I have around 12x12 feet to do my ho layout in and I was wondering if any body could tell me both the pros and cons of double deck model railroads?Confused
  • Member since
    September 2003
  • 10,621 posts
Posted by dehusman on Tuesday, March 10, 2009 6:31 AM
In 12x12 the major challenge will be finding enough room to get between the two levels.  In most cases you need 12-14" between levels.  At 2% grade that would require 600 inches of run to gain 12" of rise.  Its 48 ft  or 576" around your room, if you figure the track will average a foot from the wall thats only 528 in.  So you will need a lap and a 1/4 of solid grade to make the transition.
If you put in a helix, a 24" radius helix is about 50" in diameter and has a footprint that will take up 12.25% of your floor space.
It can be done, you just have to be willing to accept the challenges to do it.
Dave H. Painted side goes up. My website : wnbranch.com
  • Member since
    January 2008
  • 66 posts
Posted by trainfan504 on Tuesday, March 10, 2009 7:10 AM
 I willing to do it because I want to keep my staging below the main level so I don't have to worry about taking up layout space.
  • Member since
    November 2006
  • 64 posts
Posted by jimmylow on Tuesday, March 10, 2009 7:56 AM
Dave,
I have a slightly smaller room than trainfan; 11.5ft x 10.5ft. I am modelling in N-scale and will do a double deck. Looks like helix is the only way to go to get the 12 inch gain. I will have 2 helices at Algoa and at San Antonio end in my layout (see http://rosenberg-meet.blogspot.com/2009/03/operational-layout-open-for-comments.html)
I am planning to have doube tracks in the helices with 15" and 16.4" radius.
Btw, I would like to know what would be the ideal height for the upper level? I am Asian 5' 9" (175cm) and averagely my friends are around 165-170cm in height. The upper level must be comfortable for me and my friends when we run our sessions.
Thks
Jimmy
Jimmy Low, Kuala Lumpur Rosenberg Meet in N-scale (http://rosenberg-meet.blogspot.com)
  • Member since
    September 2003
  • 10,621 posts
Posted by dehusman on Tuesday, March 10, 2009 10:01 AM
trainfan504
Completely different animal.  If you are planning staging under the layout you only need 6-8" separation (since viewing/scenery isn't required).
Having had under layout hidden staging I would suggest looking at staging hidden behind a low backdrop/view block.  It takes up more footprint, but it is waaaaaaay easier to work on and with.
  • Member since
    January 2008
  • 66 posts
Posted by trainfan504 on Tuesday, March 10, 2009 12:54 PM
 yes, all I want the lower level for is staging and the main layout is on top. I have looked at hidden staging but I don't think I have the room ,that is why I want to do the lower level staging.
  • Member since
    September 2004
  • 1,951 posts
Posted by wedudler on Tuesday, March 10, 2009 1:02 PM
 There's a good book at Kalmbach, by Tony Koester,
Designing & Building Multi-Deck Model Railroads.
 BTW, between staging and first level I've less space:
You see about 2'' for staging and 2'' for the boxes from my Westport. But you need good work. I've nearly zero derailments in this area.
But now I run into a problem, one Tortoise makes trouble. I have to remove one segment from Westport. A bigger task.      Smile
Wolfgang
Pueblo & Salt Lake RR
Come to us http://www.westportterminal.de          my videos        my blog
  • Member since
    January 2008
  • 66 posts
Posted by trainfan504 on Tuesday, March 10, 2009 1:40 PM
 that is excatly what I was planning on doing!!!!
  • Member since
    February 2005
  • 7,982 posts
Posted by pcarrell on Tuesday, March 10, 2009 1:49 PM
If it's just for staging, another way to go that would take up much less room would be a train elevator.  An old car scissor jack would be a good starting point.  Power it with an electric motor if you like and set a train length track (w/roadbed of course) on cabinet rollers, and you're in business!
Philip
  • Member since
    April 2003
  • 5,440 posts
Posted by markpierce on Tuesday, March 10, 2009 1:57 PM
wedudler
If one doesn't have front and bottom access to observe/repair/replace any turnout and its switch machine, he is asking for big trouble.  You might get away with turnouts along the front edge if you have access from the side, as well as bottom access if there is under-track switch machine or linkage.
Mark
  • Member since
    February 2006
  • 177 posts
Posted by steveiow on Tuesday, March 10, 2009 5:10 PM
I was going to go double deck in much the same sort of space in HO.I read Tony's book and decided against it.
I thought there would be too much railway for one man to control and my carpentry ain't up to making a helix.
Steve
  • Member since
    May 2005
  • 1,496 posts
Posted by tgindy on Tuesday, March 10, 2009 7:22 PM
 This is being linked to the other "Double Deck" thread now running for easier cross-referencing at "General Discussion"...
http://cs.trains.com/trccs/forums/t/149648.aspx
Conemaugh Road & Traction circa 1956
  • Member since
    January 2008
  • 66 posts
Posted by trainfan504 on Tuesday, March 10, 2009 10:36 PM
 thats a Great Idea!!!!!
  • Member since
    January 2008
  • 66 posts
Posted by trainfan504 on Tuesday, March 10, 2009 10:38 PM
 Thanks for all of the great info GUYS!!!!
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
