Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Your Technique for Stripping Bus Wire for Feeders?
  • Member since
    January 2001
  • 406 posts
Posted by donhalshanks on Wednesday, August 2, 2006 5:21 PM
I have a wire stripper which works fine on the ends of wire, to cut and take off the insulation in one motion. (Won't work on the middle of a wire)
I also have the standard stripper with holes for different sizes of wire.
I don't think I have down the right technique to take insulation off the center of bus wire, so a feeder can be soldered on to it.
How do you do this?
Thanks, Hal
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Wednesday, August 2, 2006 5:57 PM
It's quite simple accually...
If your thinking what im thinking that is...
Try this:
First, just get a pair of wire cutters
Take your wire (marked the area you want to strip) And slightly cut through the insulation with it. Then take your strippers with each cut area and go into the middle of your marked area. That should do it for ya... (clean it up with an Xacto Knife if you wish!!!!! ) Good luck
Hope that helps
If you need pictures just contact me at raptor5@comcast.net and i'll see what I can do for ya.
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Wednesday, August 2, 2006 8:44 PM
 You have the wrong tool. Go to Home Depot and get the blue-handled Ideal wire stripper. It strips in the middle of the wire or at the ends, doesn't matter. There are several different size holes in it for different wire sizes, just clamp over the bus wire, squeeze genetly, and it will peel back a section of the insulation without nicking the wire underneath.
                                                   --Randy
Modeling the Reading Railroad in the 1950's
Visit my web site at www.readingeastpenn.com for construction updates, DCC Info, and more.
  • Member since
    June 2006
  • 88 posts
Posted by MIKE0659 on Wednesday, August 2, 2006 9:12 PM
We just used the Xacto knife. Run it around the wire at the two ends of the area you want to expose, then slice the insulation lengthwise and pull it off. You can actuallt put the knife against the wire, with your thumb on the other side and roll the wire with your other hand to cut around it.
The danger with using wire cutters with stranded bus wire is that you take the chance of cutting some of the strands which effectivley cuts down the size of your bus wire and its current carrying capacity.
Insert the part from the laywers about Xacto knives being sharp and that you should be careful, blah, blah. You get the idea.
Roanoke & Western Railway Company
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Wednesday, August 2, 2006 11:13 PM
My Teeth, the Dentist loves me, been using my teeth as wire strippers for over 40 years, so long as you keep them clean they do a great job.
  • Member since
    January 2005
  • 1,114 posts
Posted by Tom Bryant_MR on Thursday, August 3, 2006 6:22 AM
I use #12 solid wire, small wire cutters and an exacto.
Be safe.
  • Member since
    June 2003
  • 2,047 posts
Posted by claycts on Thursday, August 3, 2006 9:21 AM
                                                   --Randy
YES, YES, YES!!! Do not waste your time and money this is the answer. Works on #10 up to #22, does not knick the wire and leaves a perfect strip to solder to. One squeeze is one strip.
Take Care George Pavlisko Driving Race cars and working on HO trains More fun than I can stand!!!
  • Member since
    November 2002
  • 763 posts
Posted by jwils1 on Thursday, August 3, 2006 10:39 AM
Use Posi-Taps.  No stripping, no soldering, quick and easy.
Jerry
Jerry
Rio Grande vs. Santa Fe.....the battle is over but the glory remains!
  • Member since
    January 2005
  • 752 posts
Posted by jxtrrx on Thursday, August 3, 2006 11:12 AM
Jerry
Jerry,
What's a Posi-Tap?  Is that a "suitcase" connector?
-Jack My shareware model railroad inventory software: http://www.yardofficesoftware.com My layout photos: http://s8.photobucket.com/albums/a33/jxtrrx/JacksLayout/
  • Member since
    January 2001
  • 1,774 posts
Posted by cmrproducts on Thursday, August 3, 2006 11:16 AM
They make a wire stripper (available at Home Depot - Lowes) that grips the wire insulation and just pulls it apart.  I have found this type to work on most sizes of wire from the phone wire up to #8.
I just use this stripper to pull the insulation apart at the point on the buss wire that I want to solder the drops and wrap the drop wire around the buss and then solder it.  The heat from the soldering makes the insulation on the buss wires push back together and basically insulates the solder joint.  I off-set the drop wires on the buss wires so I do not have to ever wrap tape to insulate the joint.
A Much faster method than cutting with an x-acto knife and much less chance of getting cut.  Been there.
As for using methods which are not soldered when the air line industry strats to use them then I MIGHT think about using them (NOT)
Solder never fails! - Unless YOU don't know how to solder!
BOB H - Clarion, PA
  • Member since
    November 2002
  • 763 posts
Posted by jwils1 on Thursday, August 3, 2006 11:20 AM
No, it's a device that that has screw-in connectors that piece the wire's insulation.  I got mine in the auto department at Wal-Mart.  Here is their website:
www.posi-products.com
Jerry
Jerry
  • Member since
    January 2001
  • 1,774 posts
Posted by cmrproducts on Thursday, August 3, 2006 11:26 AM
So how much are these Wal-Mart specials?
BOB H - Clarion, PA
  • Member since
    November 2002
  • 763 posts
Posted by jwils1 on Thursday, August 3, 2006 11:34 AM
BOB H - Clarion, PA
Don't recall the cost but certainly more expensive than soldering.  But, they are well worth it to me as I don't like soldering under my layout and don't like to have to strip the insulation.
Jerry
Jerry
  • Member since
    January 2001
  • 1,300 posts
Posted by Sperandeo on Thursday, August 3, 2006 4:34 PM
I do use "suitcase" connectors, so I don't have to strip, solder, and re-insulate bus wires. The proper name for these is "insulation displacment connector," abbreviated IDC. The only brand I use and the brand I recommend is Scotchlok by 3M. I buy them from Mouser Electronics, www.mouser.com. If you search on that site for Scotchlok IDCs you'll find them right away. Mouser discounts for quantity, and the IDCs are cheapest by the hundreds.
The two sizes I use are no. 567 (brown) for 10-12AWG wire on the through or "run" side and 14-18AWG wire on the stub or "tap" side, and no. 558 (red) for 18-22AWG wire on both sides.
There's an expensive tool for compressing the U-shaped "knife" that cuts into the wires, but cheap Robo-Grip cam-action pliers will do the job very well. Channelocks work okay too.
IDC connectors quickly make a solid, insulated splice with a lot less trouble than stripping and soldering.
So long,
Andy
Andy Sperandeo MODEL RAILROADER Magazine
  • Member since
    January 2001
  • 1,774 posts
Posted by cmrproducts on Thursday, August 3, 2006 7:43 PM
Yes the IDC connectors will work (FOR A WHILE) but will eventually fail (UNLESS you have your layout in a controlled environment)(air conditioned and dehudmidifier)  If it is in a humid basement then after a few years the track wiring will begin to degrade.
We had it happen to our Club Lionel display.  We could not figure out why certain blocks would slow the train down.  When we did testing of the connections the problem would go away for a while as we were moving the wires around and it must have caused the minute corrosion at the connector to make good contact with the two wires again and the train would run properly for a few months.
It got so bad we had to set the block toggles for the other transformer and apply more track power to the bad section just to keep the trains running the same speed during several of our shows.  Until we could trouble shoot the wiring.  Then it would just start working OK again.  This kept happenig for several years until we made some track changes and soldered the drop wires to the buss wire.  Problem went away!
And we were using #12 drop wires solderd to the track (Gragraves brand) and had #12 buss wires run from the main terminal board to the track.  All of the buss wires had wire ends crimped and soldered. (notice the soldering thing here)  The only place we took a short cut was with the IDCs connecting the drop wires to the buss wires.
So if you have a wet basement be aware that you WILL have problems just when you don't want them.
BOB H - Clarion, PA
  • Member since
    June 2006
  • 88 posts
Posted by MIKE0659 on Thursday, August 3, 2006 7:58 PM
I'm with Bob H. on this one. No matter how you strip that wire, soldering is the only way to go for a positive connection. We have soldered every wire and joint on our railroad and over a 15 year period have had absolutely no trouble related to poor connections in the wire or rail.
Yes the Scotch (And other brands) connectors work, but you have to consider the problem with dissimilar metals causing corrosion, specially if you have a damp basement/garage. Many people have used them with no problems, but enough have had problems to make me not want to take that chance since it will be a royal pain to go back and re-do all those connections later.
I haven't been on this forum too long, but try a search for any threads concerning those connectors or start a new one to see what other people have expereinced with them.
  • Member since
    July 2006
  • 4,565 posts
Posted by cowman on Thursday, August 3, 2006 9:29 PM
Got my wire stripper at Radio Shack.  Made by Kronus, red handles on the ones I have.  Says it takes 10 - 24 ga wire, easy to adjust for length.  Also has cutter and crimper on the handle.  Cost about $18 if I remember correctly.  Have one from cheap tool catalog, basically the same tool but not nearly as good quality.  Think it is different than rrinker's but does a nice job.  Good luck.
  • Member since
    November 2002
  • 763 posts
Posted by jwils1 on Thursday, August 3, 2006 9:35 PM
Here is one older thread:  RE: Wiring DCC-track power to main buss
You can find others if you search for "suitcase connectors"
Jerry
Jerry
  • Member since
    November 2002
  • 763 posts
Posted by jwils1 on Thursday, August 3, 2006 9:49 PM
Here is another thread that might help (or add confusion)??
RE: DCC Wiring
Jerry
Jerry
  • Member since
    March 2006
  • 202 posts
Posted by conagher on Thursday, August 3, 2006 10:50 PM
I'll drink to that. Teeth provide an opportunity for adjustable cutting depths based upon actual feel, not like what's felt through wire stripper handles covered with rubber, etc.
Plus with Teeth, they're always there for immediate use...like opening an Alka-Seltzer package in a restaurant or even trimming a sharp fingernail when out in the desert.
And you certainly can't eat Prime Rib or pretzels with wire strippers :-)
  • Member since
    August 2005
  • 847 posts
Posted by ShadowNix on Thursday, August 3, 2006 10:58 PM
Yikes...eating copper...mmmmm..  Anyways, I recommend tap ins... SOOO much easier and pretty cheap, really.  They rock and you can reuse them (if you are careful).   Look into them, m8.  You can even find them at Lowe's or Home Depot nowadays.  Ciao.
Brian
"That which doesn't kill you makes you stronger!"
  • Member since
    June 2003
  • 40 posts
Posted by bobwhitten on Friday, August 4, 2006 12:09 AM
I am assuming that you are using solid wire for your bus. Radio Shack sells the wire strippers that you need, the kind that have holes for different wire sizes. Use this type stripper to mark the ends of the piece that is to be stripped away. Once the insulation is cut, simply use the handle end (portion near the jaws) of a your dykes or wireman's pliers to crush the insulation which is being stripped. This is the easiest way to accomplish what you are trying to do and the way a professional electrician would do it.
Bob Whitten
bobandbonnie@earthlink.net
  • Member since
    January 2001
  • 1,774 posts
Posted by cmrproducts on Friday, August 4, 2006 8:32 AM
When you are installing the number of drop wires that I am (over 1600 – due to the fact of having over 2800 feet of track) you would go broke using Posi-Taps, Scotchlocks or what ever!
And I have never found any that liked the big mismatch of wire sizes #12 stranded and #26 for the track drops.  And YES I put track drops on every piece of flex track and drops on all three ends of the turnouts.  That is how you get over 1500 drops.
And I usually connect more than one track drop wire together at a time when I strip the buss wire, so that cuts down on the amount of insulation stripping.  Most layout owners want to only put in enough drops to just get by due to the fact they dislike soldering but fail to remember that the proper wiring is what makes the trains run smoothly (and I mean one of those 1 hour per tie crawling units)  The layout may run great now but what about 3 years from now, 5 years 10 years?  You got tired of it only because the trains were running so bad and you figured it needed to be rebuilt.
With a 2200 sq ft basement to fill up it is going to take me 20 years to get the layout detailed properly so I NEED the trains to run smoothly for 20 years!
If you are only going to have the layout up for a year or 2 then you don’t have to even use Posi-Locks or Scotchlocks – just use good old WIRE NUTS.  If they work OK for house wiring why not for low voltage???? And they are a lot cheaper and work better than the IDCs!
And I keep hearing the old excuse for not soldering is, “I don’t know how to do it very well.”  I can teach anyone, that knows which end of a hot soldering iron to hold, how to solder in less than 5 minutes.  The biggest problem I have found is that most do not have the right type of solder!  Using electronic circuit board solder is the easiest way to solder wires.  It was designed to do this and only this. It has the right type of resin flux already in it so you don’t have to use any other.
And as for the wire strippers that have the various size holes for striping the insulation, I used to use that type all the time.  But the biggest problem I found was that when you were working under the layout you had to be really careful to get the proper hole selected before you tried to strip the wire.  And this was not so easy under the layout usually with less than perfect lighting conditions.  Then you end up nicking the wire and maybe causing a potential place for the wire to eventually break due to the nick in the wire from the wire stripper.
So if you are thinking about purchasing a new wire stripper the type that is self adjusting and just grips the insulation and pulls it apart is the easiest one to use as you don’t have to worry that you are getting the proper hole size for the wire, just place it over the wire and squeeze the handles and the insulation just pulls back!  I have piles of the old type of wire strippers in the tool box that never get used any more!
BOB H – Clarion, PA
  • Member since
    November 2002
  • 763 posts
Posted by jwils1 on Friday, August 4, 2006 8:57 AM
My first thought was......wow, 1500 drops is really overkill!   But, for your situation it very well may be the right thing to do.  But here are my questions:  Is there a difference in the number of recommended track feeders for DC compared to DCC?  Which are you running?  Technically, what happens over a period of time that causes a reduction in perfomance when too few feeders are used?
I presently have approx. 130 lin. ft. of HO DCC track with just three sets of track feeders.  I've been running it about 6 to 8 months.  Everything runs smooth and slow.  And, I'm using 9" long sections of Atlas snap track.  Am I going to have problems down the road?
Jerry
  • Member since
    January 2001
  • 1,300 posts
Posted by Sperandeo on Friday, August 4, 2006 9:41 AM
My standard is to put a feeder on every piece of rail – see page 48 in the September "Model Railroader" for how I do that – so I have a lot of connections to make. I don't think I'm up to 1500 yet: I'm not counting but I haven't bought quite that many IDCs so far. Of course, I'm not finished either.
I use a red connector between the 22AWG rail feeder and an 18AWG drop wire, and a brown connecter between the drop wire and the 12AWG bus. With that scheme the wire sizes match the connectors perfectly.
Scotchlok IDCs were recommended to me by the owner of an electrical contracting firm who used them in his work and found them extremely reliable and fast. I've had some in place for several years now and I've never had a fault in an IDC. As for the cost, I can't buy hobby time, so anything that saves time for not too much money starts to look worthwhile to me.
In addition to wiring for reliability, I'm also wiring my layout into signal blocks as I go. With that goal in mind, the idea of having a large DCC layout running on just a handful of feeder drops simply won't work.
So long,
Andy
  • Member since
    February 2004
  • 51 posts
Posted by johnny.5 on Friday, August 4, 2006 10:39 AM
Hal;
   Bob Whitten has it right, It's an old trick I learned many, many, years ago, and IS the way the pro's do it. If the handle end of you Dykes or pliers are too large for the wire you are stripping, you can use the point end of needle nose with the same result, (handle end provides more leverage and is easier though) I use Splicer's scissors for stripping, but I have years of practice using them. (Retired telephone man)
   Good Luck
   John
  • Member since
    January 2001
  • 1,774 posts
Posted by cmrproducts on Friday, August 4, 2006 11:16 AM
jwils1
 I am running DCC!  But I did this way back when our club was running straight DC.
We found after years that the Atlas turnouts were having dead sections and this was between the rail insulator and the turnout frog (DC blocks).
We would have to solder a jumper wire around the turnout to get the short rails (between the frog and the end of the switch) to get them to work again.
So I decided when I built my new layout I would just put drop wires on each end of the turnout to eliminate this problem before it ever started.
As for the sectional track it will work for a while but if the room varies in temperature and humidity it may cause problems down the road.
My thoughts is that you can never have too many drop wires.  What happens is that as you make changes to the track plan (and we all do) some of the drop wires may get broken off or never get put back on.  Now youhave the potential for poor performance.
N/S rails is not the best conductor of electricity.  The resistance is the problem with DCC as the noise (resistance) will cause the loss of signal and then you lose control of the engine.
BOB H – Clarion, PA
  • Member since
    November 2002
  • 4,075 posts
Posted by fwright on Friday, August 4, 2006 11:28 AM
Good DC and DCC wiring practices are really the same, including turnouts.  The difference is what happens when wiring is not up to the load.  With DC, when wiring is insufficient, you get voltage drops and in worst case, some dead spots.  At the dead spots, or places with too much voltage drop, the train simply stops or stalls.  Current loads are generally lower with DC because of less consisting, and the home-run wiring required for block control, so the voltage drop is actually less.
With DCC, insufficient wiring can cause both voltage drops and control signal degradation/loss.  Voltage drops are greater with DCC because the power bus carries the current load for the entire power district, not just one train.  Once a certain point of signal degradation is reached, the controller can no longer communicate with the decoder.  The margin for resistance in the electrical path from controller through the wiring, rails, wheels, etc., is just less than with DC.
Assuming secure electrical joints in the wiring - one of the issues in this thread - the most common places for degradation in the electrical path are:
- dirt in the wheel to track contact.  Nearly everyone needs to clean their track and/or wheels periodically in some way.  I'm not going to get into the track cleaning method arguments here!  Just note that the nickel silver (or brass) oxidation of rail and wheels of the next point affects this contact, too.  Also be aware that running trains frequently, especially heavier models with metal wheels would/will wear the oxide away.
- rail joiners loosening or oxidizing at their points of electrical contact.  This used to be a real bear with brass rail and rail joiners.  Brass oxide (tarnish) is a non-conductor, and brass is slightly softer than nickel silver.  Over time, a brass rail joiner would loosen just enough so that the joiner edges would no longer pierce the oxide that occurred on the rail webs. The rail joiner would no longer conduct, and unless the next piece of track had a feeder, you would have a dead spot.  Track cleaning and running the trains would not stop the oxide on the rail web or base, and actually helped the rail joiner soften its grip.
Nickel silver oxidizes as well, but the oxide forms much slower and the oxide is somewhat conductive.  Therefore the oxide buildup and rail joiner loosening seldom creates an open circuit, but does increase the resistance in the electrical path.
- the third deterioration over time is wire-to-wire connections.  Corrosion and vibration are the usual culprits here.  For this reason, marine and aviation wiring have the most frequent problems, and why there have been countless attempts to develop wire connection schemes that are inexpensive (both in labor and materials), and resist long term deterioration.  In model railroading, vibration is seldom an issue, so soldered, mechanically-solid joints using solid wire are the most reliable.  They are also the most labor intensive.  Airplanes, boats, cars often have to use stranded wire for it's flexibility and vibration resistance but it is far more susceptible to corrosion, especially anywhere the insulation is pierced or removed.  In a corrosive and/or wet atomosphere, contact of dissimilar metals almost guarantees corrosion if exposed to the atmosphere.  Hence, the long term problems with unsealed IDC's, depending on the environment your layout is in.  There are more expensive IDCs that seal after installation, and that is the point of the Posi-Taps.  To prevent corrosion, when I solder a joint on a car or boat, I seal the joint with electrical tape or shrink tubing.
The rail joiners are going to be your key issue over the long term.  How long?  Depends on what the humidity and salt loading in your air is, how securely your track is mounted, whether you take it apart to make changes, how often you run your trains, etc.  Since my previous layouts (except my 1st which was brass sectional track) used handlaid track, I just skipped the rail joiners completely, which mandated a feeder for every piece of rail.  I used 26 gauge magnet wire soldered to the bottom of the rails.
An alternative to feeders that some use is to install wire jumpers around the rail joints.
my thoughts, your choices
Fred Wright
  • Member since
    November 2002
  • 763 posts
Posted by jwils1 on Friday, August 4, 2006 11:31 AM
Bob H:
Thanks.  This is good info.  I plan to eventually replace some of the sectional track with flex-track, and I'm prepared to add a lot more feeders if necessary.
Jerry
Jerry
  • Member since
    January 2001
  • 406 posts
Posted by donhalshanks on Saturday, August 5, 2006 7:35 PM
Thanks everyone for all of the good information and help. I'm seeing the right pair of wire strippers is important, and I'd already planned to run a feeder to each piece of handlaid rail and turnout parts. I learned a lot from this thread. Thanks!
Hal
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
