Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Alclad 2 - Metalizing Passenger Cars. Photos accompanying
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Sunday, February 3, 2008 4:24 PM
Hello Crew,
Please forgive the photo quality as I'm still learning how to use a digital camera. You can click to enlarge most of the photos.
The first photo is a " before" scene.  One of my unmodified Rivorossi streamlined cars with no interior.
This is one of the cars after I cut off the skirts, repainted in gloss black and shot with Alclad II.  A painted interior has also been added. I applied a thin coat of semi-gloss to tone down the sheen depth slightly. I took this one outdoors and didn't take into account the trees casting shadows on the car's sheen.  My goof!Dunce
These are a diner and observation lounge cars. The "blueish" hue on the dining car is from the reflection of the sky. All of these cars have modified IHC interiors.
This one was taken indoors under florescent lighting.
During the process do not touch the shell(s) with your bare hands. Wear latex gloves if you must move them. I cut out a paint stand for my passenger cars from a styrofoam block that housed a new computer at my job.  So once the shell is on the that block, I won't have to touch it until the paint job is complete.
1. Wash your shells thoroughly in warm, soapy water.   Dawn or Ivory Liquid soaps work very well and leave no residue.
2. Make sure the surface is smooth and doesn't feel slippery. It's better not to scuff the surface unless absolutely necessary.  If so, "very lightly" scuff the surface in one direction  with a 3M gray scotch pad (available at most Home Depots).
3. Mask off the interior walls and all window openings.  Final clean the surface with wax/grease remover.
4. Air brush needle size should be either medium or fine. Apply 1 to 2 thin coats of high gloss black paint to the exterior.  I've been using Scale Coat II Gloss Black #S-2010 (add a few drops of white to give it a charcoal look) in the 2 oz jar.  Mix 1 part thinner to 1 part paint. Air Pressure at 20-25 psi. Practice applying the black on scrap styrene or junker rolling stock first. The key here is that the final finish appear smooth and slick.  Allow a minimum of one week for the paint to cure thoroughly.
5.  Alclad II Chrome:   Airbrush needle size: fine preferable but medium will work. Air pressure: between 12psi and 15psi seems to work best.  The fan width should be very narrow.
Lightly spray each coat in long strokes, as if you were using a slim paint brush.  Don't dump it on! After your first coat, wait 10 minutes. Yes, it looks dark gray, don't worry, that's normal Wink <img src=" />.  Apply your 2nd coat. Make sure you get into the little crevices around the diaphrams. After you finish this 2nd coat,  WALK AWAY from the shell and don't look at if for at least 15 minutes.  Come back and check it out.  If it's still a bit dark, apply a 3rd thin coat of the Alclad.  You'll likely be smiling when you finish. Don't worry if it looks too shiny.
6.  Wait 1 day and apply ONE thin, even coat of acrylic based Gloss Clear coat. This will tone the shine down slightly.  If using solvent based clear, wait at least 4 days.
7. After letting the clear cure a day or so, apply your decals.
8. Apply another thin coat of gloss clear to seal your decals.  Your model's finish should be similar to my Rivorossis' finish.
Decision time.  If you want your cars finish to appear more "aged" then add another coat of gloss clear, and so forth.
However before toning down the sheen too much, check photos of the prototypes.  The Santa Fe, Atlantic Coast Line, and CB&Q did a nice job of maintaining their streamlined cars' overall appearances.
High Greens Big Smile <img src=" />
"I like my Pullman Standards & Budds in Stainless Steel flavors, thank you!"
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Sunday, February 3, 2008 4:28 PM
A few more shots.
Again, here I toned the sheen down just a tad, with a thin coat of clear.
I've had modelers ask me about paint metalizing finishes being too shiny and toylike.  I just show them prototype photos, like these below, and that pretty much erases all concerns......
  • Member since
    July 2004
  • 2,477 posts
Posted by lvanhen on Sunday, February 3, 2008 4:30 PM
Great job Antonio!!Thumbs Up [tup]Thumbs Up [tup]
Lou V H Photo by John
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Sunday, February 3, 2008 4:38 PM
Thank you!  My Metroliners are next in line.
My dilemma......
No, I have not applied decals yet.  A friend noticed that these Rivorossi cars have rivets along the windows and rounded vestibule door top openings. Since then, I've looked at many photos and can't find prototype streamliners exactly like these. I was hoping that CB&Q, SAL, ACL, Southern, or NYC had this design but none of them did.
A freind of mine thinks that it's likely that Rivorossi got these from Budd blueprints of 1939 series streamliner cars that, when actually built, were modified and didn't have these rivets or the rounded vestibule door tops.  Anyone have any info?
  • Member since
    August 2004
  • 10,027 posts
Posted by loathar on Sunday, February 3, 2008 4:54 PM
NICE! Gotta love that Alclad!
  • Member since
    January 2002
  • 1,661 posts
Posted by GAPPLEG on Sunday, February 3, 2008 7:13 PM
Antonio , which Alcad metallic color did you use, looks good , I've used chrome on cars of course not trains.
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Sunday, February 3, 2008 8:43 PM
Thank you Ivan, Loathar Wink [;)]
Yes, Gappleg. That's the one! It's product number ALC 107.  IMHO, in looking at photos, the chrome finish resembles polished stainless steel more than the Alclad stainless steel formula, itself.
  • Member since
    July 2006
  • 1,233 posts
Posted by Hoople on Sunday, February 3, 2008 8:55 PM
Me like the shiny.
Mark.
  • Member since
    April 2005
  • 3,590 posts
Posted by csmith9474 on Sunday, February 3, 2008 10:24 PM
Thanks for getting the pics up. I guess you remember when I experimented with the stainless, and didn't like it. I am going to try the chrome next, especially after seeing your results. My wife is going to Honduras for four months this summer, so I will have plenty of time to get to  the Sunset Limited project, and I will hopefully get some pics up of the results of my first cars around July.
BTW, it looks like the FP-45s should be out very soon!! I can't wait, especially after seeing some pics of the finished warbonnet models.Tongue [:P]
Smitty
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Monday, February 4, 2008 10:53 AM
The metalized car on the left is is one of the Rivorossi's. The non-metalized car on the right is a Walthers SCL Budd car, which I would like to metalize.  I'll do more shots outdoors as paint finishes appear differently under flourescent light
Go for it CSmith.  I think you won't be disappointed.  Remember to take your time and allow the black to cure thoroughly before applying the ALC 107.
My goal is to eventually metalize the Walthers Budd cars.  IMHO they're already beautiful but need that sheen to capture the look of the prototype surface finish.
I still have the Metros and 4 E&B Valley New Haven 8600 series coaches to metalize first.  I'm strongly considering leaving the Metros with a high sheen as even under Penn Central ownership the prototypes were kept reasonably clean.
  • Member since
    July 2003
  • 5,743 posts
Posted by simon1966 on Monday, February 4, 2008 10:57 AM
Antonio, these look superb.  Great job on the interiors as well.  With all the research you have made into this subject over the years, you should write a book!
Simon Modelling CB&Q and Wabash See my slowly evolving layout on my picturetrail site http://www.picturetrail.com/simontrains and our videos at http://www.youtube.com/user/MrCrispybake?feature=mhum
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Monday, February 4, 2008 8:04 PM
Thank you Simon.  I'm humbled by your encouraging words, but I give the credit to our fellow member, CMarchand, whom I've known for many years.  His knowledge and enthusiasm of American passenger trains influenced me to take modeling "varnish" a notch higher.
But the cool factor about this is that it's is easy to do if one already knows how to apply solvent or acrylic based paint with an airbrush.  Just takes a little patience to yield some pleasing results.
My intent with this thread is to stir up more interest in this aspect of modeling. (CSmith, hint-hint!)
  • Member since
    April 2005
  • 3,590 posts
Posted by csmith9474 on Monday, February 4, 2008 11:08 PM
Big Smile [:D]
Smitty
  • Member since
    March 2003
  • 723 posts
Posted by BigRusty on Tuesday, February 5, 2008 1:35 PM
I am going to hold off on doing my NH 8600s until I see your pics. I will probably do the Walthers and TPS Budd Lounges for the Senator consist I am working on first. I need to do the interiors first when I get the research done on the interior colors.
Modeling the New Haven Railroad in the transition era
  • Member since
    February 2004
  • 2,055 posts
Posted by farrellaa on Tuesday, February 5, 2008 4:20 PM
Not to sound stupid, but just what is Alclad II and where can you get it? I have been very disappointed with the finish on most of my streamliners (Concor and Athearn). I would like to try this method.
Life is what happens while you are making other plans!
  • Member since
    June 2007
  • 3,549 posts
Posted by Flashwave on Tuesday, February 5, 2008 5:44 PM
And does it come in an airosol can
-Morgan
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Tuesday, February 5, 2008 5:56 PM
Here's the website.  Here in my neck of the woods I've found Alclad model painting products in Hobby Town stores.
http://www.alclad2.com/index2.html
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Wednesday, February 6, 2008 6:35 PM
Rusty,
Are your 8600s the Eastern Car Works kits?
  • Member since
    March 2003
  • 723 posts
Posted by BigRusty on Wednesday, February 6, 2008 6:55 PM
Antonio, I have about 6 of the coaches and 2 each of the Combine Parlor cars bought from the NHRHTA. I am considering kit bashing one of the coaches to a parlor car and resin casting about 20 of them.
  • Member since
    March 2005
  • 1,512 posts
Posted by philo426 on Wednesday, February 6, 2008 7:34 PM
That Alcad is bright but Bare Metal Foil is brighter
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Wednesday, February 6, 2008 7:58 PM
BigRusty,
I wasn't aware that the Society produced HO scale cars! Do they still produce the 8600s and are they kits or RTR?
Philo,
That is indeed bright. Impressive!
An HO streamliner applied with the Bare Metal Foil would definetly need to have the finish "notched down" slightly.
  • Member since
    January 2005
  • 6,241 posts
Posted by Jumijo on Thursday, February 7, 2008 6:08 AM
Antonio,
How fragile is the Alclad finish (i.e. handling), and what type of clear coat do you apply over yours? Also, I've heard of people painting Alclad over Future. Do they do this instead of laying down a base black coat?
Jim
Modeling the Baltimore waterfront in HO scale
  • Member since
    March 2003
  • 723 posts
Posted by BigRusty on Thursday, February 7, 2008 2:36 PM
Check the NHRHTA web site for a list of HO kits available.
http://www.nhrhta.org/.
I am sure they are out of the coaches, but still have the Combine/Parlor/
Also have the great baggage and rpo car kits.
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Thursday, February 7, 2008 5:20 PM
 Jumijo wrote:
Antonio,
Jim
Jumijo,
Great question.  IMHO, Alclad should be clearcoated because finger prints will dull it almost immedietly.  However, in our case applying clear is beneficial, appearance wise, because the Alclad II Chrome is actually quite reflective.  When coated with clear, the sheen is toned down slightly to the point where, imho, it closely resembles the polished stainless steel appearance that we see on Budd, Pullman Standard, ACF, and Bombardier streamlined passenger cars.
Clear coat should be applied in a "thin", even coat on this finish.  Remember, the more coats of clear applied, the more sheen will be lost.
Future works great as a first gloss coat to seal the Alclad and to apply decals as well.  Be aware though that Future, reportedly, gums up inside of the airbrush if not flushed out immedietly after one finishes spraying it.
As mentioned before, after installing decals:
1. For the "As delivered" brand new look, it's a simple matter of applying one thin glossy clear coat or Future Floor Finish after you've applied your decals.  Sovlent based Floquil and Testors Clears work fine.  I use Acrylic based PolyScale and Badger thinned an extra 15%.  I test my paints and clears on a junker box car body shell first.
2. For a "been on the road a few years but well maintained"  look, apply a total of 2 to 3 thin coats of gloss clear. If you want your car to look more weathered, just add successive coats of clear until you see the result you want.  Caution, too many clear coats and the Alclad will look like an ordinary silver.
Once the clear finish has hardened, you can handle the car (with care of course) with no adverse effects to the Alclad II Chrome.
BigRusty,
I'll send the society an email and inquire about those passenger cars. Thanks!Big Smile [:D]Thumbs Up [tup]
  • Member since
    December 2003
  • 1,829 posts
Posted by Southwest Chief on Thursday, February 7, 2008 5:45 PM
Looks great Thumbs Up [tup]
I was going to go the Alclad route for my Amtrak Southwest Chief Superliners, but looks like Walthers is doing the hard part for me with the new IVb factory "plated" Superliners.  Hopefully they'll make all styles of Superliners and paint schemes in the upcoming years.
Matt from Anaheim, CA and Bayfield, CO
Click Here for my model train photo website
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Friday, February 8, 2008 9:01 AM
Thanks for the link. Good to see that Walthers is metalizing these beautiful new cars.  BLI did a decent job with the California Zephyr series cars.  However, I do realize that metalzing will add to the cost of the models.
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Saturday, February 9, 2008 7:05 PM
BTW:
Although not prototypically exact, I'm considering decalingr them for one of the other railroads that I like, such as the Southern or Florida East Coast.  I can claim the old "Freelance License".
  • Member since
    July 2006
  • 329 posts
Posted by Charlie on Saturday, February 9, 2008 9:23 PM
Antonio FP45, the Rivarossi Budds are models of Reading Crusader cars.
Consist of Reading Crusader
1 Chair Obs
1 Chair car
1 Diner
1 Chair car
1 Chair Obs
Charlie
MP 53 on the BNSF Topeka Sub
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Sunday, February 10, 2008 10:14 AM
Charlie,
Please, tell me more about this.
I have only one photo of the Reading Crusader. It's in an 1950s book titled: "Trains, Tracks, and Travel".    It's a distant shot showing a streamlined Reading steamer hauling a string of what appear to be Budd cars.
I looked on the web for other shots of the Crusaser and found more black and white shots of the steamer.  I finally found an interesting color shot of ex-Reading Observation car that is similar, but not exact in appearance to the Rivorossi observation car.
Here's the link (scroll down to see the car when get there)
http://www.readingrailroad.org/news/images/news07_crusader.jpg
  • Member since
    July 2006
  • 329 posts
Posted by Charlie on Sunday, February 10, 2008 11:14 AM
 AntonioFP45 wrote:
Charlie,
Antonio, the Rivarossi cars represent post-war Budd cars while the Reading Crusader cars were pre-war Budd cars. The observation is a former Reading Obs but, the fluting above the windows has been removed and replaces with Stainless Steel Sheathing. Also, the skirting has been modified from its original configuration. The most important things to look at are the window arrangements and the fluting is correct for the road/manufacturer. There isn't a whole lot of information on the Crusader as only two trainsets were produced. To make these cars correct for Pre-war cars, you would need to replace the vestibule doors with the doors from Concor, Athearn cars and remove the fluting that wraps up over the door and runs between the upper fluting and windows.
Charlie
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
