Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Bachmann Spectrum Decoder Choices
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Thursday, August 23, 2007 4:19 PM
I have tried numerous searches, plus consulted the web, all to no avail. What DCC Decoders are designed for Bachmann Spectrum Diesels? I removed the shell on one, and all I saw was a light board in the top of the shell. How are decoders installed in these loco's? Does a DCC Decoder replace the light board? Do I need to disassemble the loco further to hard wire? I am at a loss. Pleas help!!!!
Thanks!
  • Member since
    August 2004
  • 10,027 posts
Posted by loathar on Thursday, August 23, 2007 7:52 PM
http://www.ncedcc.com/
Go to products/locomotive decoders.(click through a couple pages to get to HO decoders) They have the Bachman DCC replacement boards. I don't think they have specific Spectrum units. You could call and ask for your application.
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Monday, August 27, 2007 9:52 AM
I have a pair of GP-30's and a pair of FM H16-44's. They are Spectrum units, but when I remove the shells, all I see is a heavy 2 piece weight that needs to be split to get to the motor, and a light board in the top of the shell. Is that light board replaced with a decoder? There is not a plug anywhere on the loco. None of the DCC manufacturers sites I visit list anything for Spectrum diesels. I have visited the NCE site, as that is what I run in my other units, but they have nothing. I am not interested in sound at this time. I have P2K units that take a plug in decoder, and I have some Athearn Blue Box units that I hardwired. I can't believe there is so little info on what I thought to be a fairly common line of products. maybe I will contact Bachmann and see if they can help.
  • Member since
    July 2003
  • 13,757 posts
Posted by cacole on Monday, August 27, 2007 10:16 AM
Older Bachmann Spectrum diesels require total disassembly to install a decoder because they were not DCC ready in any respect.  The motor has wipers that contact the two frame halves for electrical pickup.  These wipers must be isolated from the frame halves, and that requires that the frame be taken apart to get to them so the decoder's gray and orange wires can be soldered to the contacts.  You are then faced with the problem of finding a way to connect the decoder's black and red wires to the frame halves.
Sometimes you're better off to just forget about putting a decoder into these old engines and purchase a new one.
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Wednesday, August 29, 2007 8:43 AM
Thanks for the help and input. I found the info I needed at another site. These loco's are not DC ready, but they are new and I got them for a good price. I will be installing the NCE DSR13 decoders in them as I have done with my Athearn BB units. Almost the same procedure, so I should not have any problems. They work for me, and as this is just a hobby for me, replacing all of my $15 to $25 new loco's from Ebay bargains over the last few years with $75 to $150 units just isn't practical or feasible.
  • Member since
    July 2006
  • 3,312 posts
Posted by locoi1sa on Wednesday, August 29, 2007 5:48 PM
  You could also check out Train control systems web site.  WWW.TCSDCC.com.
  They have pictures of instals that are very helpful.
 I pray every day I break even, Cause I can really use the money!
 I started with nothing and still have most of it left!
  • Member since
    May 2007
  • 147 posts
Posted by Steve_F on Thursday, August 30, 2007 4:57 AM
It’s a shame so many modelers put the Bachmann H16-44s into the too hard basket when it comes to decoders. Not so long ago I installed NCE D13SR decoders into 5 of my small fleet.
 I hard wired (soldered) the power leads (Red & Black) to the truck pick-ups via a wire I used to connect the front & rear wipers and cut off the part of the wiper that connects to the frame.
I isolated the motor by cutting off part of the wiper that connects to the frame and soldering the orange & grey wires to the remaining bit on the motor then wrapped some insulation tape around the motor contacts for good measure.
For the head lights I cut the middle out of the original light boards de soldering and removing the pick-ups and leaving the mounting holes in the outer pieces so they could still be mounted in their original positions with the original bulbs and wired them with 270 ohm resistors (I don’t like the lights too bright especially on older locos). I put the resistors on the blue wires to keep a uniformed practice with other locos that use LEDs.
I used double sided foam tape to attach the decoder to the top of the frame and positioned it to fit in the space left from cutting the middle out of the original board.
These locos were my first attempt at fitting decoders to any loco, I did heaps of research online to figure out how it was done so this may or may not be the best way to do it but it worked for me and may give some ideas to anyone wanting to give it a go.
Hope this helps someone.
Steve
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Thursday, August 30, 2007 6:29 AM
Steve,
That is exactly the same info/procedure I found. This is the same process to use in all of the Spectrum split frame loco's. Not much work, but then again, with the popularity of the newer and more expensive units, it's easy to see that many just want to drop a load of cash for something that is ready to go as is than to actually work on something. I don't think paying double or triple the price just because a piece is DCC ready is worth it if that is the only difference. I haven't noticed any other  significant changes between my DCC ready units and these older ones.
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
