Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Suitcase connectors for wiring?
  • Member since
    November 2002
  • 4,648 posts
Posted by jacon12 on Friday, October 5, 2007 9:46 PM
I don't remember the 'correct' name for these devices, I've only seen them referred to as suitcase connectors.  I'm wondering how reliable they are for connecting track feeder wires to the main buss.  I looked around Lowes Home Improvement but didn't see them, perhaps don't stock them.
Anyone used them and can recommend them... or not?
JaRRell
 HO Scale DCC Modeler of 1950, give or take 30 years.
  • Member since
    November 2003
  • 151 posts
Posted by medic_149 on Friday, October 5, 2007 9:59 PM
I have used these repeatedly in car stereo instalation without failure. Never had one come open, or lose power. I plan on using them on my main buss. There are several different types of them. You can find them in the automotive section at walmart or any autoparts store like autozone. The ones I use, clamp on the main wire, and have a male spade type connecter that plugs in.
these are the kind I use most.
these are also good for wire close to the same gauge, but hard to adapt for large gauge to small gauge such as 22 ga wire feeders to 14 gauge main buss.
these are the only 2 types of connecters I have used. others may have some better info.
  • Member since
    June 2007
  • 705 posts
Posted by UP2CSX on Friday, October 5, 2007 10:20 PM
Before you decide to use suitcase connectors, please at least try Posi-Tap connectors. Thet are easier to use, especially in tight spaces, because they require no crimping. You can tie in up to four 22 gauge wires to one bus wire with one Posi-Tap. They are fast, reliable, and the results are stonger than soldering. I've used them to wire 59 streelights and building interior lights in about half the time of any other method I've ever used. I have no connection with them, just a satisfied customer. You can find out more about them at http://www.posi-lock.com/posiplug.html
Regards, Jim
  • Member since
    November 2002
  • 4,648 posts
Posted by jacon12 on Friday, October 5, 2007 10:30 PM
Thank you for the information and the photos, they'll be a help in locating them!
JaRRell
  • Member since
    November 2002
  • 4,648 posts
Posted by jacon12 on Friday, October 5, 2007 10:32 PM
Jim, I had forgotten about these.  Not that I've used them, but I have heard of them.  I like the idea of connecting for feeders , that might be especially helpful around my turntable area.
Thanks,
JaRRell
  • Member since
    July 2003
  • 1,008 posts
Posted by jwar on Friday, October 5, 2007 10:35 PM
I have been around the so called suitcase connector for years, but only in automotive and truck wireing, it was also the first items I checked out if I had a poor connection. Also if the sliding connector spade is crimped at an angle it will partualy cut the second wire. I did think about using them, but saved the expense and got out the ole sodering gun, of which in my personal openion is soooooo much better, and cheeper too..and never a doubt of a good connection....or I would check out as csx stated above, the posi tap...Just my 2 cents...John
John Warren's, Feather River Route WP and SP in HO
  • Member since
    July 2006
  • 1,943 posts
Posted by Vail and Southwestern RR on Friday, October 5, 2007 10:39 PM
One brand name for the suitcase connectors is Scotchlok (though there are many Scotchlok connectors that are not suitcase connectors).  Some people swear by them, some swear at them.  I believe the key is proper installation, the 'connector' part is to be put in place first, then the 'suitcase'.  Don't try to push the connector into position by just pushing down the cover.
Here is an example:
http://products3.3m.com/catalog/us/en001/utilities_telecom/electrical_contractors/node_GSLQW8MSW6be/root_GST1T4S9TCgv/vroot_GSBCDFDZ1Zge/gvel_RZZJLFZNT6gl/theme_us_electricalcontractors_3_0/command_AbcPageHandler/output_html
Jeff But it's a dry heat!
  • Member since
    December 2002
  • 1,511 posts
Posted by pastorbob on Friday, October 5, 2007 10:41 PM
Installed DCC in 1999, used suitcase connectors for the power bus and the cab bus, have had no problems 8 years later.  Still use them on new work too.
Bob
Bob Miller http://www.atsfmodelrailroads.com/
  • Member since
    November 2002
  • 4,648 posts
Posted by jacon12 on Friday, October 5, 2007 10:46 PM
John, I agree with you on the expense part.  But, the reason I'm looking into these is that, while in the middle of a benchwork remodeling, I noticed I ain't all that good at soldering under the bench.  Now where the track feeder connects to the rail, no problem... but I'll bet 1 out of 4 of my under the bench connections were no good, thus I'm looking into alternatives 'cause I'm a terrible solderer..  :)
JaRRell
  • Member since
    October 2006
  • 883 posts
Posted by jktrains on Friday, October 5, 2007 10:47 PM
JaRRell
You picked a subject that people have very strong opinions on, pro and con.  I've seen this subject debated numerous times in numerous places.
I've used the suitcase connectors (3m brandname is Scotch-Lok) to make feeder connections on modules I've built.  IMO, they are a fast, reliable way to connect track feeders to a power buss, especially in DCC where you're not worried about block wiring.  They have been mentioned in numerous articles.  The primary one that comes to mind is one a few years back by David Barrow, of Cat Mountain fame, in his domino series of articles.  He is a very experienced modeler and I figure if they're good enough for him then well you know.  They have have been used in a recent MR project layout.
As I said, I've used them or provided them as part of mdules I've built for the 4-H group.  This gives the kids/parents a way to do wiring with out needing to solder.  Just make sure you use the right size wires in the right connector.  They are color coded.  While HD or Lowe's may only stock the yellow, blue or red ones.  3M does make them that use 20ga for the tap and 14ga for the run.  They are much harder to find, a little more expensive, but you should be able to mail order them off the internet if you look hard enough.
  • Member since
    October 2005
  • 1,464 posts
Posted by larak on Friday, October 5, 2007 10:50 PM
JaRRell
Scotchlock is the best brand. Made by 3M corp. If you use the proper size and crimp correctly they work fine. Sizes are written on the boxes.  Some off brands do not work so well. Caveat emptor.
Karl
The mind is like a parachute. It works better when it's open.  www.stremy.net
  • Member since
    July 2003
  • 1,008 posts
Posted by jwar on Saturday, October 6, 2007 12:51 AM
JeRRel..was just my personal observations of a product in heavy industry. I would go with what ever fits your needs and then go for it. In the home inviorment of a train room they should never give you a problem as they are properly crimped. However forgive me as I am bias about them as I feel they are an emergency repair item as there are far better products out there, as I said, in a home enviorment they should work fine.... Yee Gads..I guess Im a suitcase biggot LOL. Take care JeRRel...John
  • Member since
    February 2005
  • 12,914 posts
Posted by tomikawaTT on Saturday, October 6, 2007 1:22 AM
I noted in passing, "I'm not that good at soldering under the benchwork."
I absolutely, positively DETEST soldering under the benchwork - so I bring all my wiring out to the aisle side of the L girders and do my soldering while seated in a comfortable chair in the aisleway.  Actually, most of my wiring is run from terminal block to terminal block and I do quite a bit of "soldering" with a socket wrench.  All of my real soldering is done from the top down, a lot of it pre-wiring prior to installation.
When it comes to pain-free electricals, a little pre-planning saves a lot of grief.
As for suitcase connectors, count me in the camp of folks who swear at them.  My background is aircraft maintenance, and any aircraft electrician who used them for any purpose aboard anything airborne would do so at risk of his FAA certification.  When it comes to flying machinery, "Good enough," - isn't.
  • Member since
    July 2006
  • 1,943 posts
Posted by Vail and Southwestern RR on Saturday, October 6, 2007 1:45 AM
So far I have not used them, though I may as time goes on.  I've been using wire nuts.  It does require cutting and stripping the wires, but after that they are pretty easy to use.  And it isn't hard to add or subtract.  I don't have any real objection to soldering, but I have been using child labor (actually older teen) to do a lot of the wiring, and have been haappier with the results with the wire nuts than soldering.  Getting the 14 gauge hot takes a bit of patience and preparation.
I think that installed correctly there should be no trouble with the IDCs, in a model railroad environment.  Every phone cable, network cable, ribbon cable, etc., is in the same technology family, though these try to be a bit more general purpose.
  • Member since
    June 2004
  • From: Orig: Tyler Texas. Lived in seven countries, now live in Sundown, Louisiana
  • 25,640 posts
Posted by jeffrey-wimberly on Saturday, October 6, 2007 7:16 AM
I've tried the suitcase connectors and didn't like them. I also don't like soldering under the bench. I came upon a comprimise that works well for me. Instead of securing may power buss wires directly to the bottom of the layout, I have them hung by wire loops 3 to 5 inches below the bottom of the layout. With the wire in this configuration I can get to it easily and soldering is not a problem.
Running Bear, Sundown, Louisiana
          Joined June, 2004
Dr. Frankendiesel aka Scott Running Bear
Space Mouse for president!
15 year veteran fire fighter
Collector of Apple //e's
Running Bear Enterprises
History Channel Club life member.
beatus homo qui invenit sapientiam
  • Member since
    March 2016
  • 1,447 posts
Posted by Eriediamond on Saturday, October 6, 2007 7:16 AM
Oh-Oh! I'm in trouble if my trains start flying. Laugh [(-D] Just a little humor Chuck. Not flame thrown at you. Being a pilot, I total agree with you about there use in aircraft. I'm against there use in automotive use too.
  • Member since
    June 2004
  • 25,640 posts
Posted by jeffrey-wimberly on Saturday, October 6, 2007 7:27 AM
Hear, hear! I used them once in a fuel pump installation. I'll never do that again!
          Joined June, 2004
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Saturday, October 6, 2007 7:40 AM
See also this forum thread:
http://www.trains.com/trccs/forums/1217657/ShowPost.aspx
Good Luck,
-John
  • Member since
    October 2006
  • 406 posts
Posted by Train Master on Saturday, October 6, 2007 7:54 AM
Want some free advice? DO NOT USE THEM.
David Parks
I am the terror that flaps in the night!
  • Member since
    June 2007
  • 705 posts
Posted by UP2CSX on Saturday, October 6, 2007 9:54 AM
Some people seem to do fine with suitcase connectors and others don't. I'm part of the don't crowd. [):] If you are going to use them, spend the money to get real ScotchLoc connectors. Don't get the no-name brands at auto stores. They will fail frequently on installation, usually right after you've got all the wiring secured in place and then you have to track down the failed connection. Once you find it, you have to cut it off, waste a connector and start again. That's why I went to Posi-Tap. No stripping, crimping, and it's east to visually verify you have a connection. If you are running a power bus, you also never have to cut the main bus wires, which is the thing I don't like about using wire nuts. Just screw it on the bus, strip the end of the feeder, slide it through the second half of the connector, screw them together, and your done. Even if you do something wrong, you just unscrew the connector and try again - you never waste a connector or have to recut wire. I really hate wiring but Posi-Tap's have made me only annoyed by wiring. Big Smile [:D]
Regards, Jim
  • Member since
    July 2006
  • 1,279 posts
Posted by Pathfinder on Saturday, October 6, 2007 3:37 PM
Strange, not a single mention of the October 2007 MR article that actually discusses this very issue.
Look at Page 78, the DCC Corner column that covers Good Wiring Practices to get a true perspective on your options.  It is a good article by Mike Polsgrove and worth a read.
Oh, and on Page 51 there is an under-layout picture that shows lots of suitcase connectors on Steven Barkley's layout.
Keep on Trucking, By Train! Where I Live: BC Hobbies: Model Railroading (HO): CP in the 70's in BC and logging in BC
  • Member since
    January 2007
  • 92 posts
Posted by woodlandtoots on Saturday, October 6, 2007 3:59 PM
Amen to that. I run all my cables that way. I drill a hole from the top down, and do all my connections to the track first, then feed the cable through the hole, cross it underneath the layout by way of the loops (and cable ties), and then finish the connections sitting in a chair. No way am I going to do soldering upside down under the layout. (I did plenty of that when I was still doing electrical assembly work for a living and physically I want no more of that)
Woodlandtoots
  • Member since
    November 2002
  • 4,648 posts
Posted by jacon12 on Saturday, October 6, 2007 6:12 PM
Jim, I sent the Posi-Tap folks an email asking about their product and this is the reply.
"They are great for Model RR, but, only with stranded.  It would be worth it to change to stranded wire for the time you will save."
JaRRell
  • Member since
    January 2002
  • 3,119 posts
Posted by jfugate on Saturday, October 6, 2007 6:40 PM
Posiplug connectors are 50 cents to a dollar each, while 3M suitcase connectors at an auto supply store will cost you 15-20 cents each. Big price difference between the two technologies. For model railroading, I can't see the reliability of posiplug would be 5 times better, so the "return on investment" isn't there.
I've used 3M suitcase connectors on my HO Siskiyou Line for over 10 years now, with not one failure ever. And we run op sessions each month, so the layout is used to run trains regularly.
As to whether or not you would trust building an airplane with these, I also expect wire nuts used in house wiring are NOT used in airplanes either, but that doesn't stop house electricians and it's allowed by code.
Joe Fugate Modeling the 1980s SP Siskiyou Line in southern Oregon
  • Member since
    June 2004
  • 25,640 posts
Posted by jeffrey-wimberly on Saturday, October 6, 2007 7:15 PM
Joe, you said the prime thing in one sentence, that you use 3M suitcase connectors. Many of the suitcase connectors sold in auto supply stores are cheap knock-offs of the 3M product and don't work even half as well. I found this out through personal experience with the cheaper products. The 3M connectors work well, the knock-offs don't.Smile [:)]
          Joined June, 2004
  • Member since
    December 2006
  • 1,207 posts
Posted by stebbycentral on Saturday, October 6, 2007 9:06 PM
If I had answered this thread yesterday I would have given them my unqualifed approval.  Tonight I'm not so sure, since I spent most of this morning rewiring a failed suitcase connection. Last year when I relocated a wall in the basement I also installed a new 120v outlet.  Having used suitcase connectors with success on my layout, I decided to employ them in a little house wiring.   After running a length of Romex up to the ceiling box where all of the existing outlets merge, I used the connectors to tie the new lines into an existing pair of lines.  At the time it seemed to be a more elegant solution than peeling the electrical tape off of the existing wire splices and resoldering them.  Well it worked for about a year, but this AM when I went to fire up the PC in the basement, I discovered I had no power!  Odd given the fact that there were no tripped breakers, and every other outlet in the basement was working.  Starting with the outlet itself I traced the dead circuit all the way back to the ceiling box.  Apparently one of the suitcase connections failed.  I ripped them both out, peelled off the tape and soldered the leads onto the old wires. The outlet and the PC is back in operation.   So it appears that you should not employ these devices on heavier guage wires.
I have figured out what is wrong with my brain!  On the left side nothing works right, and on the right side there is nothing left!
  • Member since
    July 2006
  • 1,943 posts
Posted by Vail and Southwestern RR on Saturday, October 6, 2007 9:18 PM
I don't believe that either the suitcase connectors or the soldering are code approved for what you are using them for, in 120V wiring.
  • Member since
    August 2007
  • 425 posts
Posted by GTX765 on Saturday, October 6, 2007 9:23 PM
On the subject of wiring I have a stupidDunce [D)] question, I am setting up my wiring this weekend. I am just using the two wires from the zepher right now but going to do wiring since I am runing more trains.
 My questions is when you run the two bus wires, the black and the red what do you do with the ends? I know one end goes into the terminal but the other end? Do you loop it or cap it off or what? This is my first layout and I am no pro. Can some one post a picture of your wiring? I have a 5x9 with two main line ovals with multiple switches. Thanks
  • Member since
    July 2006
  • 1,943 posts
Posted by Vail and Southwestern RR on Saturday, October 6, 2007 9:29 PM
For that size of layout, there's no problem just taping off the ends and tying them up out of the way.
  • Member since
    August 2007
  • 425 posts
Posted by GTX765 on Saturday, October 6, 2007 9:30 PM
Ok thanks, sorry for my ignorance. I am not good with electrical.
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
