Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
How to rewheel an old AHM/Rivarossi steam engine!
  • Member since
    June 2005
  • 4,368 posts
Posted by Darth Santa Fe on Tuesday, August 24, 2010 4:32 PM
Hello all! I finally got my parts from Bowser, and now I'll show you how to put new wheels on an old Rivarossi steam engine!Big Smile Why? Because Rivarossi used plastic wheels with traction tires and large flanges, which would sometimes crack or not be centered on the axle well, and sometimes ran rough. They also can't be used on less than code 100 track. And now lets get to it!Big Smile
Step 1:
The first thing that needs to be done is to get all the parts needed. For this project, I used Bowser 80" Box Pok drive wheels (Greenway Brass and Mantua will also work), two light and one medium, none geared. I also used two Bowser 804 hex screws, K&S 5/32" brass tube, and 3/32" brass tube.
Step 2:
The Bowser axles will be mounted in brass bearings made from the 5/32" tube, because Bowser's axles are smaller than Rivarossi's. I used a 5/32" round file to open the axle slots so the new bearings can be fit in. To make sure the axles are in exactly the same place, I put the bottom plate on and opened each hole until I could slip the brass tube in.
Step 3:
Once the slots were opened enough, I took the bottom plate off and filed the slots open the rest of the way so the tube could slip in from the top (bottom?). It's a good idea to remove the worm and idler gear before doing any of this, because you don't want steel shavings getting into the gears!
Step 4:
Originally, I was going to cut the tube in half and mount it like Mantua's removable bearings. This was going to be more trouble than it was worth, so I instead mounted full tubing on each axle. Before pulling any wheel so I could get the tube on, I made a score mark on the axle and wheel so they could be lined up easily. To make each bearing, I used a cutting disk mounted on a motor-tool to cut each piece out, got rid of any burrs on the ends, and reamed the openings out with a large phillips screwdriver. Rivarossi originally mounted the middle axle slightly higher than the other two, so it never touched the track. To fix this, I filed the rise stamped into the bottom plate off and put a good size spring between the frame and axle, so now all of the wheels make contact with the track. And because the new wheels are all metal and each axle is electrically grounded to one wheel, those dumb ol' Rivarossi plungers can be removed (keep all grounded wheels to the appropriate side!).Big Smile
Step 5:
The middle of Rivarossi's axles is conveniently 5/32" in diameter, so mounting the gear to the Bowser axle is pretty easy. I soldered the gear directly to a small piece of brass tube, which can later be mounted to the axle with a strong glue or epoxy.
Step 6:
Unlike the other two axles, the geared axle needs a smaller bearing on each side of the gear. I still only removed one wheel to get all three parts on. First came the left bearing. Then I put a small drop of liquid super glue on the middle of the axle, and slowly slipped the gear over it while turning it to make sure the glue spread all around and didn't pool to one side (which could get into the bearing if you're not careful). I ran another very small drop of liquid super-glue around the other side of the gear using a wire to make sure it filled any possible gaps, and wiped off possible excess with a paper towel over my finger nail. Once the gear was on, the other bearing could be slipped on and the wheel pressed back in place.
Step 7:
To mount the siderods, I used the original Rivarossi screws on the outer drive wheels and the Bowser 804 screws on the inner wheels. The Rivarossi screws are slightly larger, so I had to drill the hole in each wheel with a #53 (1.5mm) drill bit, and carefully tap each RR screw into the wheels a little at a time (with oil!!). This was the most tedious part of the project. And since RR's middle wheels have an extension coming out for the siderods and valve gear, I had to cut out new pieces to use with the 804 screws, which were made from 3/32" brass tube cut to around 3.5 to 4mm in length. Once all of that was done, the siderods could be mounted, and both eccentrics can actually be mounted at the correct angle now.Big Smile I used everything but the dark blue steel washers, since the Bowser wheels don't need them. At this point, everything should be oiled and tested, and if it all works smoothly, move onto Step 8.
Step 8:
Rivarossi was notorious for using undersized weights in their steam engines, which is why almost all of them use tires. The Bowser wheels don't have tires, so more weight is needed. I don't have all the fancy tools needed for casting nice parts, so I cast new weights from lead shot in an aluminum foil mold (folded many times!) and used a blow torch to melt them. I hammered each weight to shape until it could slip into the shell without much trouble. The rear one over the gearbox is held in by a generous amount of aluminum tape, and the main one is mounted with the original screws. I found that drilling lead is very difficult because of the softness, and it will heat up, conform to the shape of the drill bit, and harden over it, making it very difficult to get the bit out. With all the new weight, the Hudson weighs almost double what it did before.Big Smile
Step 9:
Time to reassemble!Big Smile If all was done right, your Rivarossi should run nice and smooth, and have sufficient traction to pull a decent load. One thing I noticed is that the metal wheels provide better counter-balance for the side rods, eliminating most of the characteristic shaking and possible thumping of the plastic wheels.Big Smile And if smaller flanges are needed all around, the rest of the wheels shouldn't be hard to replace.
My Dreyfuss Hudson is now a very smooth runner, and I'm a lot happier with its performance now.Big Smile The Bowser wheels (which I'll paint later) are more realistic for the most part, and they make very little track noise. The gearing is already excellent, and with a better universal and motor, this steam engine could run silently and nearly as well as a more expensive one.Big Smile Finishing this project only took a few hours total, and it would've taken even less time if I knew what I was doing!Big Smile
_________________________________________________________________
  • Member since
    July 2006
  • 3,312 posts
Posted by locoi1sa on Tuesday, August 24, 2010 6:17 PM
 Great job Darth.
 Maybe MR could do a future article on one of your projects?
    Pete
 I pray every day I break even, Cause I can really use the money!
 I started with nothing and still have most of it left!
  • Member since
    August 2006
  • 50 posts
Posted by yesterdaysradio1 on Wednesday, August 25, 2010 6:25 PM
What did you use for pickups on the insulated wheels?
Jerry
  • Member since
    June 2005
  • 4,368 posts
Posted by Darth Santa Fe on Wednesday, August 25, 2010 8:04 PM
The Hudson is wired so the engine picks up from one rail and the tender from the other, so I didn't use any additional pickups.
  • Member since
    July 2006
  • 1,983 posts
Posted by SteamFreak on Thursday, August 26, 2010 1:04 AM
 Aside from better performance, it's amazing what a difference those Bowser drivers make aesthetically. It looks like a completely different loco. I always thought their Hudson's appearance suffered from the pizza cutter flanges more than most, for some reason. I think most of the shaking in these locos came from uneven traction tires, which could be pretty severe, but solid metal drivers should help nonetheless.
 Those flanges look they might have about .010" clearance between them, so I hope the bearings are snug. You're braver than I am, because I'd be afraid I wouldn't keep the axle slots perfectly parallel.
Great work, Darth!  Now you don't have to worry about that added weight causing the steel frame to wear out the brass axles, and you can actually get some driver spin. SmileThumbs Up
  • Member since
    June 2005
  • 4,368 posts
Posted by Darth Santa Fe on Thursday, August 26, 2010 10:28 AM
I've tried replacing the traction tires to make it smoother, but in my case it was just bad wheels. Believe it or not, the flange diameter of the Bowser and Rivarossi wheels is identicle, so clearance isn't a problem at all.Big Smile
I've been working on replacing the rest of the engine's wheels. I'm also going to try putting a spare FK-130SH motor in, since the can motor in this one seems to be from around the middle of their quality control (runs fine, but it's noisy and squeeks in reverse).
  • Member since
    June 2005
  • 4,368 posts
Posted by Darth Santa Fe on Friday, August 27, 2010 3:29 PM
I've now finished with remotoring and changing out the pilot and trailing wheels.Big Smile
The FK-130SH motor is small enough that I was also able to add a 16mm Genesis flywheel after removing some plastic from inside the shell. I also had to remove the original motor bracket. The new motor is mounted on some sort of foam-rubber material with super glue. The NWSL coupling was an extra one I had on hand, and I'll probably replace it with the next size up eventually.
Most of the replacement wheels are Intermountain 33" freight car wheels, which have had their axles modified to fit (I also had to make new brass bearings for the front truck like I did with the drive wheels). The rear axle is made from leftover NWSL 40" wheels, mounted on a slightly shortened Athearn Hi-F axle, and with the ends ground into needle-points. Replacing all these wheels would've been a lot easier with axles that were flush for the front truck, and had proper width needle-points for the rear truck. The rear wheels should also be 42" instead of 40" like I used.
I brush painted the drive wheels Model Master Aluminum, since that looked pretty close to the color used on the real ones and other higher quality models.
The new wheels are definitely more realistic than Rivarossi's.Big Smile
Sure makes a good looking model!Big Smile The siderods still need a little more adjustement, but I'm a lot happier with my Hudson now!Big Smile I'm still going to get BLI's brass hybrid when it comes out, but that doesn't mean I'm going to put this one away. I'm just going to have two really nice Hudsons for the layout.Big Smile
  • Member since
    July 2003
  • 5,743 posts
Posted by simon1966 on Friday, August 27, 2010 4:13 PM
Darth, I have really enoyed following this, not sure I would have plucked up the courage to do it myself!  Great looking results if you don't mind me saying.
Simon Modelling CB&Q and Wabash See my slowly evolving layout on my picturetrail site http://www.picturetrail.com/simontrains and our videos at http://www.youtube.com/user/MrCrispybake?feature=mhum
  • Member since
    July 2006
  • 1,983 posts
Posted by SteamFreak on Saturday, August 28, 2010 2:11 PM
 It looks awesome, Darth. Another FK-130 to the rescue.
Does it run without any hitches or binds? Also, I guess there was enough play between the axle and idler gears so that the axle gear could be raised the tube thickness and not overmesh them? My Pacific has the same gearing, and the mesh already seems a little tight.
  • Member since
    June 2006
  • 9,577 posts
Posted by cudaken on Saturday, August 28, 2010 4:17 PM
  Branden, you should start a repair business. I enjoyed looking at what you have done, even tho I will probably try something that advanced.
                  Ken
I hate Rust
  • Member since
    August 2010
  • 11 posts
Posted by FirstCavArmyVet on Sunday, August 29, 2010 6:27 AM
LOL I agree there Ken. Brandi and I got baptised into our first steam engine. We were sent a Bachman Niagara 4-8-4 with tender by Flynn. Brandi and I love it so much we setup a small track in our bedroom and laid there watching it go in circles for about 2 hours the other night. Now I'm all into the steam locomotives (however I still have my love for the diesels).
I know one thing, if I ever get one in need of repair like that, I'm boxing it up and sending it to Darth LOL. I don't have the tools, or patience for a job like that (thanks U.S. Army) LOL
  • Member since
    October 2004
  • 745 posts
Posted by HarryHotspur on Sunday, August 29, 2010 7:36 PM
cudaken
                  Ken
Considering what you've done with cars, I'd say you would be a resident expert here in short order.
- Harry
  • Member since
    April 2003
  • 4,261 posts
Posted by Medina1128 on Monday, September 13, 2010 8:46 AM
I have to echo what's already been said; I don't have the tools or patience to take on an undertaking like you've done. I can already see that the wheels would get put back on, a strip of track glued to a nicely finished block of pine and put on a shelf as a static display. Congrats on your results.
  • Member since
    June 2005
  • 4,368 posts
Posted by Darth Santa Fe on Tuesday, September 14, 2010 11:38 AM
Thanks all for your comments and compliments.Big Smile
SteamFreak, there's still a hint of binding in the siderods, but I've gotten it all worked out well enough that it's not even noticable while running. I actually found that the axle and idler gears were already meshed pretty tightly with the stock axle, so I made sure when I was openeing the slots that the new axles would rest in exactly the same place. It sounds hard, but doing it the way I showed actually made it pretty easy.Big Smile
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
