Trains.com
Cutting down 022 switches
  • Member since
    July 2009
  • 951 posts
Posted by servoguy on Sunday, April 25, 2010 12:28 AM
I did something over the last few days which might be interesting to some of you. I took six 042 switches (these are the manual versions of the 022 switches for O-31 track) and cut off part of the track and made them smaller. They are now the size of the 23010 and 23011 switches. I cut 1 7/8" off of the straight part of the switch and 3 1/2" off of the curved part (measured along the outside curved rail. This makes it possible to make a yard or a siding with the tracks much closer together than is possible with a standard 022 switch. I used the 042 switches for two reasons: I had some sitting around without a job to do, and the inside curved rail on the 042 switch is a single piece while the same rail on the 022 switches is two pieces. To cut down the switches, I completely disassembled the switch, removing everything including the rails. I then cut the plastic base. Then I cut the rails as necessary. It is necessary to cut the plastic base where it is inside the rails so that you can insert pins into the rails. With the cut down switches, the center to center (c-c) between two adjacent tracks is 5.25" rather than 8.375" as it is with unmodified switches. I installed 022 switch motors on the two switches I put into my layout. This required that I add 3 wires, one for power and two for the non-derailing feature. I used the two very short rails near the frog for the non-derailing feature. The inside curved rail on an 022 switch is split in such a way that using it for one of the cut down switches would have resulted in a piece of the rail not having much holding it in place. That is why I used the rail from the 042 switch. Bruce Baker
Tags: O-22
  • Member since
    January 2007
  • 362 posts
Posted by jmkk on Sunday, April 25, 2010 8:09 AM
Here is a shot of my yard. There are 14 cut down 0-22 switches. I cut mine mith a 4 1/2" abbrassive wheel. Then I drilled out the plastic so I could install the pins. No disassembly required.
Jason
 B&O  =  Best & Only
  • Member since
    July 2009
  • 951 posts
Posted by servoguy on Sunday, April 25, 2010 12:59 PM
I didn't have access to an abrasive cutoff wheel, so I had to do it the hard way. Yours look good. How did you deal with the short curved rail? How did you hold it down, or was this not necessary? Bruce Baker
  • Member since
    February 2010
  • 640 posts
Posted by Timboy on Sunday, April 25, 2010 3:11 PM
  • Member since
    November 2007
  • 126 posts
Posted by gopherstate on Monday, April 26, 2010 8:58 AM
Bruce, I have been cutting switchs for a few years now with great results. I use a band saw with a fine metal cutting blade. I have cut all types of switchs from old 022 to new 027.  The cut down switchs make a much more compact yard possible.
  • Member since
    December 2001
  • 10,096 posts
Posted by lionelsoni on Monday, April 26, 2010 5:23 PM
Here's how I cut O27 turnouts to get 2 7/8-inch track spacing:  http://cs.trains.com/trccs/forums/p/36520/469380.aspx#469380
Bob Nelson
  • Member since
    July 2009
  • 951 posts
Posted by servoguy on Monday, April 26, 2010 6:50 PM
Bob, I just laid out your yard using some switches and track out of a box. It does get the tracks close together. I don't know if you could 022 switches for this due to the size of the switch motors. Bruce Baker
  • Member since
    March 2009
  • 1,029 posts
Posted by submmbob on Monday, April 26, 2010 8:35 PM
 Bruce
I'm interested to see what the switches look like when cut down. Could you post some pictures?
Bob
Bob
Tucson, AZ (aka the Ol' Pueblo)
Home of the Mt. Graham & Arizona Eastern Boiler Shops
  • Member since
    July 2009
  • 951 posts
Posted by servoguy on Tuesday, April 27, 2010 1:55 AM
I need someone to tell me how to post a picture.  I tried a method that was posted on the forum some months ago, but it didn' work.
Bruce Baker
  • Member since
    July 2009
  • 951 posts
Posted by servoguy on Wednesday, April 28, 2010 12:02 AM
Cut down 022/042 switches compared to a standard 022.  The switch motors are not installed on the cut down switches.
 Same picture.
Closeup of cut switches
A cut down switch instaled in my layout.  The straight part has not been cut on this switch.  This was the first switch I cut.
The second switch I installed in my layout.  The two tracks coming out of the switch are separated to clear one of the feet on my bed.  The tracks are going under the bed.
Now I have some pictures of the layout in my bedroom.  You can see the tracks going under the bed.
Next picture to the left of the first one.
Further to the left.
On the other side of the bed.
And now aroun the corner and going down the hall to the spare bedroom.
About half of what is in the spare bedroom.  That is a Type V.
To the left of the first picture.
To the left again.
To the left again.
Looking back toward the door
There are 50 switches in the layou.  40 of them are on the mainline.  It takes a train running at moderate to slow speed 22 minutes to go completely around the layout.
I can run one train around the entire layout or 3 train in my bedroom and 2 trains in the spare room.  I hope to make a video soon.  For that, I will remove the bed.
Bruce Baker
  • Member since
    March 2009
  • 1,029 posts
Posted by submmbob on Wednesday, April 28, 2010 2:06 AM
 Bruce
Looks awesome! When I get to the yard I will have to try cutting some of the switches. Can't wait to see your video!
Bob
Bob
  • Member since
    July 2009
  • 951 posts
Posted by servoguy on Saturday, May 29, 2010 6:31 PM
Somebody asked me about pictures of my layout. They are on this post, not on a post with the subject "posting pictures" Bruce Baker
Join our Community!
Our community is FREE to join. To participate you must either login or register for an account.
Search the Community
FREE EMAIL NEWSLETTER
Get the Classic Toy Trains newsletter delivered to your inbox twice a month
