Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
guard rail for bridge track
  • Member since
    November 2006
  • 68 posts
Posted by john2wilm on Saturday, February 20, 2010 11:59 AM
 I am adding a deck bridge to the layout and have the bridge track with out any guard rail. I want to add the guard rail. Am wondering how far to extend the guard rail into the regular track after coming off the bridge? Any help would be appriciated.
Thanks
John
Modeling the ACL/SAL merger as if it happened in the early 80's. Moving goods in and around the Carolina coast. Check out Facebook page/carolinacoastrr
  • Member since
    July 2006
  • 7,670 posts
Posted by rrebell on Saturday, February 20, 2010 12:07 PM
In real life it was to the end of the bridge at least and varied on how far past, seen it from a few feet to a car length or more and the ends I have seen everything from slightly bent in and down to an actually point (never understood why it would end in a point because by then the cars would have been almost totally derailed anyway).
  • Member since
    November 2008
  • 1,205 posts
Posted by grizlump9 on Saturday, February 20, 2010 12:52 PM
 i always figured guard rails and timbers were not intended to prevent derailments, but to keep the train from falling off the bridge if it did.
grizlump
  • Member since
    April 2007
  • 289 posts
Posted by odave on Saturday, February 20, 2010 1:07 PM
I've found the prototype pictures at www.historicbridges.org to be really helpful in figuring out stuff like this.  Just browse around the site and you'll find several examples.
Here's one from the site showing bridge track and guard rails
--O'Dave
  • Member since
    April 2003
  • 5,440 posts
Posted by markpierce on Saturday, February 20, 2010 1:13 PM
rrebell
Probably because trains ran in both directions on the bridge so either end could be the beginning of the guard rails.  Coming to a point, the guard rails would most likely keep the wheel sets parallel to the track.
Mark
  • Member since
    July 2004
  • 5,199 posts
Posted by bogp40 on Saturday, February 20, 2010 1:13 PM
Use the next smaller size of rail for the guard rails. Code 0 guard rail for 83 mainline. I like to use the extended guard rails as additional bridge anchoring. I do this by spiking/ CAing those rails to the approach to the bridge abutment.
Modeling B&O- Chessie  Bob K.  www.ssmrc.org
  • Member since
    July 2004
  • 5,199 posts
Posted by bogp40 on Saturday, February 20, 2010 1:26 PM
The "gremlins" must be hard at work today. Couldn't edit or delete my previous post.
Those rails should be "CODE 70" not "0"
I won't allow the guard rails to touch. This will prevent any unwanted shorting on the bridge itself.
  • Member since
    January 2001
  • 63 posts
Posted by obermeyern on Saturday, February 20, 2010 10:21 PM
 On the section of line I model, I measured two bridges roughly 10 miles apart and they both had the guard rail starting at 60 feet from the bridge. Hope this helps.
 Nate
  • Member since
    February 2005
  • 12,914 posts
Posted by tomikawaTT on Saturday, February 20, 2010 11:47 PM
Which railroad is that, Nate?
Reason I ask is that different railroads have different standards.  Some only install guardrails on through bridges, where a derailed car might damage the bridge structure.  Others use them on everything that is more than a few centimeters above the surrounding area.  A few didn't use them at all.
In Japan, where really tight radii are not uncommon, I've seen guardrails (at flangeway clearance) carried all the way through the curve, on the inner rail only.  The object seemed to be to take the stress off the outer rail by bringing the inner wheel flanges into play.
I have also walked through an out-of-service tunnel which had guard rails full-length.  At one end they extended on across a beautiful concrete spandrel arch bridge on a curve - a fine piece of engineering for a line which was built to support construction of a dam and was taken out of service (but not pulled up) after the dam was completed.  (I suspect the guard rails continued through the tunnel at the other end of the bridge, but didn't cross it to find out.  That tunnel ended in an active yard.)
Check on-line for the bridge standards of your prototype railroad.  They might prove informative.
Chuck (Modeling Central Japan in September, 1964 - with lots of bridges and tunnels, all with guard rails)
  • Member since
    February 2007
  • 553 posts
Posted by el-capitan on Saturday, February 20, 2010 11:52 PM
 I looked this up in the ATSF system standards vol 1. ATSF standard was 45' from point to bridge. I also found some other interesting stuff that you may also find interesting. Please enjoy this daily dose of useless information.
The General manager had the option of extending guard rails up to 300'
The points were # 10 frog points.
Guard rails are spaced 10" on center away from main rail. (I'm not sure how this compares to NMRA)
The guard rail begins to taper inward 1'-8" away from the bridge.
Using the same weight of rail for the track and the guard was acceptable. (good because I don't want to order more rail)
The front of the point is beveled at 45 degrees (relative to the horizon)
No tie plates are used beneath the guard rail.
 On double track mains that had dedicated directions of traffic (like a highway), points were only required on the leading end of the guard (before the bridge). The unpointed end of the guard rails (after the bridge) ended 10' after the bridge without any bends.... never heard of this before. I wonder if this ever existed outside the standards,
 Check out the Deming Sub by clicking on the pics:
Deming Sub Deming Sub
  • Member since
    February 2002
  • 533 posts
Posted by CascadeBob on Sunday, February 21, 2010 4:52 AM
 I have a section of N scale ME bridge flex track that comes with two loose pieces of smaller code guard rail.  Is there a preferred adhesive to use to hold these guard rails in place when installing them?  Any tricks to simplify the installation?
Thanks,
Bob
  • Member since
    July 2004
  • 5,199 posts
Posted by bogp40 on Sunday, February 21, 2010 11:22 AM
CA works for a quick bond, however, Pliobond is a great alternative. It produces a very stong yet flexable bond.
  • Member since
    January 2004
  • 13,375 posts
Posted by doctorwayne on Sunday, February 21, 2010 11:31 AM
Here's the CN bridge at 20 Mile Creek, on the Grimsby Subdivision:
  • Member since
    January 2001
  • 63 posts
Posted by obermeyern on Sunday, February 21, 2010 12:43 PM
 The railroad I am modeling is the Missouri Pacific.  The bridges were installed in the 60's so I would imagine the 60 feet was the standard for the railroad at that time.
Nate
  • Member since
    July 2006
  • 3,312 posts
Posted by locoi1sa on Sunday, February 21, 2010 3:05 PM
 I pray every day I break even, Cause I can really use the money!
 I started with nothing and still have most of it left!
  • Member since
    July 2006
  • From: 4610 Metre's North of the Fortyninth on the left coast of Canada
  • 9,352 posts
Posted by BATMAN on Sunday, February 21, 2010 11:37 PM
 I may be wrong here, but with all my poking around in the wilds of western Canada exploring rail lines (especially C.P. ) I've noticed that
1. Guard rails seem to be old used rail that has been torn up through regular maintenance.
2. The distance from the end of the bridge to where the guard rails end depends on how long the piece of rail was when they pulled it off the car.
3. The ends of the guard rails are often different lengths. Sometimes by several feet.
 When miles from civilization the railroads don't seem to worried about appearance just as long as the purpose is served. Nearer urban areas things definitely get neater and tidier including guard rails that are cut to the same length.
        Brent
Brent
"All of the world's problems are the result of the difference between how we think and how the world works."
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
