Trains.com
How to add a rectifier to #445 Lionel Switch Tower?
  • Member since
    September 2008
  • 43 posts
Posted by ballastbob on Tuesday, February 9, 2010 10:08 AM
 Id like to quiet down the operation of my Lionel Switch Tower by adding a full wave bridge rectifier (4 amps, 50 volts).  Im using an isolated control rail section. The tower, however, has three terminals: one for power, one for the control wire and one for the light.  How do I make the connections to the rectifier in this situation?
Bob
  • Member since
    December 2001
  • 10,096 posts
Posted by lionelsoni on Tuesday, February 9, 2010 4:08 PM
You will need to isolate the coil and the lamp from each other.  Right now they share a common return through the frame of the accessory.  (If this proves to be not so simple, you might consider abandoning the original lamp socket and finding a place to install another with insulated terminals, like this one:  http://www.radioshack.com/product/index.jsp?productId=2062369 .)
Power the lamp directly from whatever accessory supply you are using.  Power the coil through the bridge rectifier, that is, with + and - connected to the coil and ~ connected where you used to have terminals 2 and 3.
Bob Nelson
Join our Community!
Our community is FREE to join. To participate you must either login or register for an account.
Search the Community
FREE EMAIL NEWSLETTER
Get the Classic Toy Trains newsletter delivered to your inbox twice a month
