Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
newbie pros and cons of n vs ho ?
  • Member since
    December 2009
  • 2 posts
Posted by m244 on Friday, December 18, 2009 9:49 AM
 Recently inherited n gauge trains some track turn outs 4 power packs built a 4x8 table 1/2 " ply . trying to decide to keep it n or go ho any thoughts would be helpfull. thanks,m244
  • Member since
    July 2006
  • 5,084 posts
Posted by G Paine on Friday, December 18, 2009 10:03 AM
Sign - Welcome
If it was my decision, a lot would have to do with the quality of the N scale models you inherited, also if it would be a road name and timeframe that you would be interested in modeling. By timeframe, I mean what era the equipment would have run. If you are interested in modern railroading, it probably would not make nuch sense to keep steam locomotives.
It would help to know the manufacturer of the locomotive and rolling stock; often visible on the bottom.
George In Midcoast Maine, 'bout halfway up the Rockland branch
  • Member since
    December 2004
  • 21,484 posts
Posted by MisterBeasley on Friday, December 18, 2009 10:05 AM
HO:  Larger items are easier to work on, and to see.  There is generally more equipment available.  Sound is becoming very common.
N:    You can put more trains in the same amount of space.  Sound is still rare, because of the difficulty of fitting decoders and speakers into the engines.
There is a lot of very good modelling being done in both of these scales.  If you can get to a train show and see some operating layouts, or visit some layouts (either home or club) in your area, you can get a feel for what each of the scales looks like.
That 4x8 table is pretty minimal in HO, while it's a decent sized layout in N.
It takes an iron man to play with a toy iron horse.
  • Member since
    April 2003
  • 4,261 posts
Posted by Medina1128 on Friday, December 18, 2009 10:08 AM
I havve to agree with everything MisterBeasley said. I cound have really run some long trains if I'd used N scale in the space I have now, but I have a hard enough time putting HO stuff on the track.
  • Member since
    February 2005
  • 12,914 posts
Posted by tomikawaTT on Friday, December 18, 2009 10:17 AM
MisterBeasley
There are also more parts and raw materials available if you get into the model-building side of the hobby, and they can be handled with normal-size fingers and seen without a jeweler's loupe.
You can also 'loosen up' the same layout as a very compact HO track plan in the same space, and the result will look a lot more like the real world.
The cost of filling x square (feet, meters, whatever) with N scale layout is higher, but N scale can be done convincingly in about 1/4 the number of square (units.)  Basic layout design principles are the same for both; HO just needs more space to achieve the same result.
Chuck (Modeling Central Japan in September, 1964 - in twice-N, 1:80 scale, aka HOj)
  • Member since
    March 2007
  • 947 posts
Posted by HHPATH56 on Friday, December 18, 2009 10:17 AM
Walther's N scale structures and rolling stock availability has increased tremendously. Personally, I prefer HO , for size and ease of handling, (on my 24'x24' around the garage loft room), but you can squeeze in a lot more "model railroading" by using N scale, especially, if your available space is limited. Is this to be an island layout, a peninsula, or what do you propose ? As you will see, many use a central background divider, to give you double sided background space, and implication that trains appear to come from distant locations. I happen to have combined HO and N scale, for the purpose of "forced perspective. The N scale dogbone loop is along one wall, on a rough gray 2"x2". I use the continuous panorama of SceniKing 11"x7" section around my entire layout. They would be ideal for a center panel background. I matched the sky blue, (of the tops of all the SceniKing sections) electronically, at the paint store. Bob Hahn
  • Member since
    October 2001
  • 17,574 posts
Posted by BRAKIE on Friday, December 18, 2009 10:46 AM
Mr.B wrote:Sound is still rare, because of the difficulty of fitting decoders and speakers into the engines.
Actually that is dated information.A lot of the quality DCC ready N Scale locomotives is "plug and play" and there is a lot more N Scale sound these days..Even the decoders are smaller.
As far as working on  N..I am 61 and still don't need to use my glasses or a opti visor..
Larry
Conductor.
Summerset Ry.
"Stay Alert, Don't get hurt  Safety First!"
  • Member since
    January 2005
  • 273 posts
Posted by bobwrght on Friday, December 18, 2009 10:55 AM
If you are into Steam you will find alot more available in HO.
Bob
  • Member since
    June 2007
  • 8,892 posts
Posted by riogrande5761 on Friday, December 18, 2009 11:13 AM
4x8 may be the minimum size HO layout but it is terribly restrictive with those utra sharp curves.  If you want more flexibility on what you can run, I suggest going with a 5x9' layout which would get you 24-inch minimum curves.
Rio Grande.  The Action Road  - Focus 1977-1983
  • Member since
    June 2007
  • 8,892 posts
Posted by riogrande5761 on Friday, December 18, 2009 11:18 AM
Does the tooling still exist?  Time for Athearn to step in once again, buy it and start making models based on old FR/E&C/LBF tooling, but maybe upgraded.
  • Member since
    August 2006
  • 3,130 posts
Posted by dstarr on Friday, December 18, 2009 11:31 AM
A subject of discussion between modeler since the beginning of time.  Objectively, the smaller N scale allows more railroad (track , structures, and scenery) in the same space.  The larger HO scale is easier to kit bash, scratch build, or modify rolling stock and structure models.  If you are a model builder, HO will be rewarding.  If you are an operator, into ready to run equipment, and you want long trains, N is rewarding. So much for objective.
 Then there are subjective factors, namely which scale do you LIKE better.  You will probably be happiest going with the subjective factors.  It is a hobby after all.
  • Member since
    October 2004
  • 8,639 posts
Posted by Texas Zepher on Friday, December 18, 2009 11:59 AM
m244
  I'll start by asking, "what is it about the N-scale that would even put you into a decision mode?".  Is there something about it that you already don't like, or something about HO that you really do like?  There has to be something that made it not a "no brainer" to keep the N.   If we knew that we could direct our comments to help based upon the issue causing the question to be ask.
Having modeled in both - at the same time, I can highly recommend NOT doing that.  Definitely choose one or the other and stick to it.   Other than that all I can do is repeat what the others have said.
N-scale
1.  Women find them cute and you will get a lot more support.
2.  much more layout/trains in same space.
3.  much less detail on individual pieces of equipment / structures.  <-this is why I switched
4.  electronics and sound - as has been pointed out it is getting better but still not anywhere close to the options in larger scales.  Plus on-board sound has to have that much smaller speakers - HO is bad enough - as size goes down eventually sound quality goes to that of a greeting card. The physics of sound and the biology of the human ear does not "scale down".
HO scale
1. Most wide range of equipment / structures / track avaliable both old and new.  If we actually stopped and did a scientific survey.  Since the 1970s there is probably more stuff avaliable in HO than all the other scales combined.
2. 4 x 8' is almost the minimum for a continuous run loop of track - needs much more space than N.
3.  Big enough one can get some fine detail (like scale 3/4" hand rails) on cars and locos.  Try painting the face on an HO scale man vs an N scale man.
O scale - the king
1.  I wish I could afford it!
  • Member since
    February 2001
  • 1,519 posts
Posted by n2mopac on Friday, December 18, 2009 12:00 PM
I can only share my personal experience. I started into model railroading as a hobby in my mid 20's after being a life-long rail fan. I started in HO, but my job required several moves 3-4 year apart for a while, so building a layout was difficult. Frustrated, I decided to buy some N scale equipment an build a portable layout that I could move with me (4'x4'). This was a great starter layout. The result was that I fell in love with N scale. Now I have a larger layout (17'x17') but am still modeling in N scale. I sold all of my old HO stuff several years ago except a loop of track and a short train that I run around my Christmas tree. I scratchbuild and kitbash in N scale. I don't find it as difficult as many seem to think it is. The truth is, in N scale you can often "suggest" detail on a model that you don't have to actually build and end up with the same quality look. Long story short, I've been modeling in N scale for 15 years and have no intention of turning back. Ron
Tags: HO , N
Owner and superintendant of the N scale Texas Colorado & Western Railway, a protolanced representaion of the BNSF from Fort Worth, TX through Wichita Falls TX and into Colorado.
Check out the TC&WRy on at https://www.facebook.com/TCWRy
Check out my MRR How-To YouTube channel at https://www.youtube.com/c/RonsTrainsNThings
  • Member since
    December 2009
  • 2 posts
Posted by m244 on Saturday, December 19, 2009 7:03 AM
Thank's to all .  I've decided to go with the  " n " .  There's plenty of track,  switces, turnouts , engines , rolling stock etc. thanks again for the suggestions. and oh yea MERRY CHRISTMAS
Mac
  • Member since
    April 2001
  • 3,150 posts
Posted by CNJ831 on Saturday, December 19, 2009 8:02 AM
I think that a lot of folks are missing the really critical point with their advice. The governing factor in the choice is really the hobbyist himself, rather than the space and available equipment.
Aspects I see as critical here are those like is the hobbyist young or old; does he still have good eye-hand coordination; is his eyesight really good, or has he already reached the stage where glasses are a constant necessity to accomplish everyday tasks? Likewise, just what are the aspects of the hobby he thinks he might wish to persue? Is it just watching trains run, or does he want them to "do" something instead. Does he like the challenge of building things, or is he a store-bought-only kind of guy; has he perhaps an interest in electronics/computers? And in particular, what sort of cash does he have readily available to spend on a hobby?
All these questions weigh heavily on any decision and should be addressed ahead of scale and equipment considerations. Most definitely, in our hobby the individual is the deciding factor, not the choice of scales.
CNJ831
  • Member since
    June 2003
  • 8,204 posts
Posted by IRONROOSTER on Saturday, December 19, 2009 8:04 AM
 Use what you have to get started.  But be open to change.  Over the years I have worked in all the scales except Z.  They all have advantages and disadvantages.  But it really is what you like to do.  Personally I find S to be the right size - big enough to be easy to work on, trains have a nice presence on the layout, yet small enough to have a nice layout in an average basement.
Enjoy
Paul
If you're having fun, you're doing it the right way.
  • Member since
    October 2001
  • 17,574 posts
Posted by BRAKIE on Saturday, December 19, 2009 9:27 AM
davidmbedard
BRAKIE
Actually, I have to agree with MrB.  The issue is that there is only 1 player in the N scale plug and play sound market.....MRC.
  The problem with the sound in N scale locos is 3 fold.....
1.  MRC decoders have a horrible reliability or life rating.  They tend to do what they want or die at a moment's notice.
2.  MRC sound decoders have horrible sound quality.  They also lack in the world of adjustment, having three sound levels of loud, louder and white-noise.
3.   Putting a quality sound decoder into an N scale loco (Soundtraxx Tsunami 750 or LokSound Micro) involves removing a lot of the weight from the loco, hence making them poor electrical pickup performers....which is essential in sound-equipped locos.
If you are looking to have sound in your locos, absolutely go with HO or larger scales.
David B
David,There are other ways to enjoy sound in N Scale.Try adding sound to a dummy locomotive,tender or a trailing boxcar/baggage car..In the wee scale one needs to think outside the box.
About the MRC sound..I have notice the HO sound decoders works quite well in the analog mode but,isn't worth a hoot in the DCC mode..
Larry
Conductor.
Summerset Ry.
  • Member since
    September 2006
  • 678 posts
Posted by dale8chevyss on Saturday, December 19, 2009 8:36 PM
IRONROOSTER
Enjoy
Paul
I think what I'd like about S is that if I decided to do a huge farm layout (I like tractors and such) then S would be easier because tractors tend to come 1/64 a whole lot easier than they do 1/87th.
Modeling the N&W freelanced at the height of their steam era in HO.
 Daniel G.
  • Member since
    September 2013
  • 2,505 posts
Posted by caldreamer on Saturday, December 19, 2009 9:26 PM
I agree that HO has more products available, but N scale has enough for anyone and more coming out all the time.  My new N scale layout which I am in the process of building will have an operating hump yard, intermodal yard, docks and a fully integrated steel mill.  You can not fit all that in a space 36 X 12 1/2 feet in HO.  The mountain division will rise from 43 inches to 62 inches with a maximum grade of 2.42 percent.  For me the layout potential of N scale out weigh any advantages HO might have.
  • Member since
    March 2009
  • 802 posts
Posted by rjake4454 on Sunday, December 20, 2009 2:14 AM
The smaller scales like N can be nice, but the smallest I go is HO. Even when I pick up an HO caboose, I still feel like I am handling an extremely small train model. I'm starting to wonder if HO is "half 027" if even that, rather than half the size of regular O gauge.
True, you can fit a lot more track in with the smaller scales, I may be in the minority here, but I think the smaller the scale, the more detailed scenery you need to make the trains look realistic. Personally, I like to run trains on a bare plywood table surface, sure I add ballasting, lighting, things of that nature, but I'm more into running trains than building an exactly scale environment.
Plus, most of the smaller scales are plastic models. I model steam, so I prefer the hefty feel of die cast metal engines.
  • Member since
    October 2001
  • 17,574 posts
Posted by BRAKIE on Sunday, December 20, 2009 8:09 AM
rjake4454
No more then HO..
In fact due to the size you can get by with a "oops!" and it may go unnoticed by your visitors. Not so in HO where every "oops!" sticks out like a sore thumb..
Some of my better ISLs was built in N Scale using a minimalist approach.
Larry
Conductor.
Summerset Ry.
  • Member since
    June 2003
  • 8,204 posts
Posted by IRONROOSTER on Sunday, December 20, 2009 8:14 AM
dale8chevyss
IRONROOSTER
Enjoy
Paul
Not to mention the Ertl farm set.
Enjoy
Paul
  • Member since
    March 2007
  • 192 posts
Posted by fluff on Sunday, December 20, 2009 12:44 PM
thoughts on an around the walls layout? 12x10 feet on an 18 inch shelf. one of the 10 ft. sides is 12 inches wide. enough for HO?  24 inch minimum radius  if HO...thanks
  • Member since
    November 2002
  • 4,075 posts
Posted by fwright on Wednesday, December 23, 2009 11:23 AM
fluff
Something to consider:  a 12" deep shelf accommodates 5 parallel tracks in HO - and nothing else.  Structures (even partials or semi-flats), trees, shrubs, roads, autos, platforms, and all other scenic elements will decrease the number of tracks that can be fitted on that shelf.
Where my HO shelf layout decreases to 12" deep, I try to maintain 3 or less tracks in any given cross-section.  Even then, I have to be very careful what scenic and structure elements I plan for a given spot.  Where my shelves can be deeper (16"), I have a 4 track maximum.  And this is with HOn3 and HO 1900-era rolling stock, which is less overwhelming to a given scene than modern prototype models would be.  The narrow gauge really requires the same space as the standard gauge to better simulate the "spread out" effect of many narrow gauge prototypes where flat land was available.
Worth studying is Scott Perry's Heart of Georgia track plan, which is essentially an HO shelf layout on 12" shelves (see http://hogrr.blogspot.com/2009/12/heart-of-georgia-track-plan.html).  Note how partial structures are used extensively.  Iain Rice is a proponent of eye-level, narrow shelf layouts, and he believes very strongly in framing and presenting the layout with a backdrop, "ceiling" over the shelf with lighting in the ceiling, and sectioning off scenes with framed edges.
my thoughts, your choices
Fred W
  • Member since
    December 2002
  • 1,261 posts
Posted by emdgp92 on Wednesday, December 23, 2009 12:56 PM
fluff
Oddly enough, I have a 16x10-foot shelf layout in my basement. However, it's built sectional-style. That is, if I have to move, I can easily take it apart. Each section measures 2x6 feet, with a 4x4-foot square corner. There's plenty of room for track and scenery. Because the layout is in the corner, it leaves the rest of the room free for other things...such as my model cabinet, work bench, TV, etc.
Even though my main interest is HO, I have a small selection of N scale equipment. So far, that 'layout' consists of a loop of Kato's Unitrack. I'd been curious about N, but until one of the local shops (Esthers) had their "flood salvage" sale awhile back, I'd never taken the plunge. Ended up with a Kato E8, RDC, an Atlas U25B, and a couple dozen freight cars. While I was at it, I put some buildings together.Let me tell you, after several hours of working on an N scale building...the HO scale parts look huge!
  • Member since
    March 2007
  • 192 posts
Posted by fluff on Friday, December 25, 2009 10:00 AM
thanks guys....Fred....thank you for the link to that track plan. that is what i have been looking for!  i have n scale set up now in the room, but i really like this plan. i like a fair amount of track and sidings and enjoy a long run with as many cars as possible within reason. i guess i could do it in N or HO? i have several layout books, but haven't found exactly what i wanted, until now. thanks again for the Christmas present!
  • Member since
    October 2001
  • 973 posts
Posted by jmbjmb on Friday, December 25, 2009 3:36 PM
Fluff, I'm doing almost exactly that.  My space is 12x12, almost identical to the theoretical bedroom space used in MRP over the years for their room size designs.  Three walls are 12 inch shelves, with the final wall being a 2x8 town.   In my case I'm modeling branch line ops along the three narrow benches with only the small town at the end, so the  lack of side by side tracks isn't a problem for me.  In the region I model, from an eye level view, you seldom get great panoramic visits beyond the tracks.  Rather there's a wall of trees on either side anyway, so the shelf is realistic.
 As for the origianl question, I've been in both N and HO.  Both are good, depending on the your desires.  Overtime, I've grown more interested in the work of the crew on the ground so larger scales fit my goals.  In fact, I keep trying to figure out how to fit 1/4 scale into the room to get even more massive effect.
  • Member since
    July 2006
  • 1,080 posts
Posted by desertdog on Friday, December 25, 2009 3:54 PM
You may want to take a look at what Lance Mindheim does with HO shelf layouts. Lance has done some great layouts in both HO and N: http://www.lancemindheim.com/ John Timm
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
