Layouts and layout building
Benchwork, scenery, track, and more. If you're building a scale model train layout, this is where to go. If you're new here, please read our forum policies.
Last post 11-22-2009 9:41 PM by Blazzin. 9 replies.
Rate:
Sort Posts:
Page 1 of 1 (10 items)
11-21-2009 9:15 PM
Offline Mchavez215
Not Ranked
Joined on 09-26-2003
Omaha, NE
Posts 18
Painting mortar
Hello - I would like some info. on painting mortar on a painted brick buildign facade.  I read information on uisng a wash of light grey and then rubbing it off, but my model is painted and I am afraid of a thinner wash pulling the painted brick color off too.  Any suggestions - maybe I will be OK with the thinner wash.  But I wanted to ask before I mess up my model.  Thanks!
11-21-2009 9:45 PM In reply to
Offline skagitrailbird
Not Ranked
Joined on 12-11-2008
Sedro Woolley WA
Posts 135
Re: Painting mortar
Under normal circumstances it would be unusual for the base coat of paint to pull off.  Is there any particular reason for your concern?  What type of paint did you use?  What material is the building made of?
Most of my buildings are plastic and I use Floquil solvent based paint.  After letting it dry for a day or two I paint full strength Polly Scale dust over the bricks, wait a few minutes, then wipe it off with a damp (rung out well) rag.  You can vary the interval between painting and wiping to get very faint mortar lines or well weathered brick.
Good luck!
11-22-2009 6:23 AM In reply to
Offline Mchavez215
Not Ranked
Omaha, NE
Posts 18
Re: Painting mortar
I used Testors on plastic.  This morning I tried the thinned wash and it pulled the base coat off.  I tried white chalk and that works, but I can't "fix" the chalk - I tried fixitif and that just colors the chalk the same as the base brick color.  Thanks, Mark
11-22-2009 10:38 AM In reply to
Not Ranked
Sedro Woolley WA
Posts 135
Re: Painting mortar
 Mark,
 By Testors, I assume you mean anamel, using paint thinner or mineral spirits for thinning & clean up.  What type of paint did you use for the mortar wash?  What type if thinner for that?  If using enamel and paint thinner for the wash, it sounds like the base coat had not fully cured and the paint thinner "attacked" the uncured base coat.  One may need to let the base coat fully cure for at least several days.  better yet, use an acrylic water based paint for the mortar wash.  It should have no effect on the enamel.
 Roger
11-22-2009 11:19 AM In reply to
Offline Blazzin
Not Ranked
Joined on 06-14-2008
Posts 296
Re: Painting mortar
  Mark,  I am in the same position.  My approach is not an expert Model "Railroader' or builder.  But my knowledge on paints can / might be helpful.  It might spring forth new ideas for you or any other reader.  I am in means an expert.
  My attack plan.. is to use.. 'Craft Paint' as in 'Doc in CT'  thread.  Doc gave a nice demonstration on doing the mortar.  But as far as your case.. and mine.. I figure if I use the Craft paint (water soluble) .. in a water down base.. I should be able to lightly give a mortar.. weathering finish.  My approach .. although you didn't .. is to preserve the original finish.. by using Testors Dullcote.  Once that is on, as far as I am concerned.. even if I do the Craft paint wrong, I can lightly wipe it off. After I am finished with that particular coat of a watered down mortar finish.. I'd probably put another light coat of Dullcote .. to protect that application.  Then if you want to go back and do some more.. or add various colors to give more depth to the bricks.. you can do so.. and if you don't like.. wipe it off lightly. Then when all done.. apply the last finish of Dullcote.  One thing I didn't mention,  I will 'mask' off the windows..and other things.. that the Dullcote might ruin. As far as masking tape.. I use the green painters tape.. instead of the blue.  The green is a finer tape.. with no 'crinkles' like the blue painters tape.  One other thing.. Doc in CT thread.. he uses the craft paint .. thick.. and with a jabbing motion.. pushing .. and shoving the paint into the cracks to produce the mortar look.  He lets that dry and then rubs it off with a alcohol swab.. very little water.. and erases the excess.  I would like to give you a photo.. of one I need to do.. but right now.. I am working on 3 models.  Here is my first attempt on mortar.  I am happy.. but I have gone through the whole spectrum of paints.. and found the Craft paint to be the most forgiveable.. and easy clean up.  Good luck.
Keith
11-22-2009 2:39 PM In reply to
Offline Doc in CT
Not Ranked
Joined on 02-04-2009
Enfield, CT
Posts 599
Re: Painting mortar
Blazzin:
 Keith,  what thread was that?
Sounds like the technique of Nick (nbrodar) in this thread: http://cs.trains.com/trccs/forums/p/162279/1787636.aspx#1787636
I've never used this approach (more of a thin wash, dry, and wipe method).
Alan
(doc-in-ct)
11-22-2009 3:07 PM In reply to
Offline Mchavez215
Not Ranked
Omaha, NE
Posts 18
Re: Painting mortar
Awesome!!  Thanks!
11-22-2009 4:03 PM In reply to
Offline Mchavez215
Not Ranked
Omaha, NE
Posts 18
Re: Painting mortar
Roger- Thanks.  The acrylic paint is working great!  I thought a water-based paint would bead up on the enamel - but it is working!  -Mark
11-22-2009 4:20 PM In reply to
Offline rrebell
Not Ranked
Joined on 07-13-2006
west coast
Posts 750
Re: Painting mortar
Better yet use a watered down white waterproof ink and wipe off the excess. It will dull the brick a little also and be permanent.
11-22-2009 9:41 PM In reply to
Offline Blazzin
Not Ranked
Posts 296
Re: Painting mortar
  Tom, and right you are.. this is the thread.. didn'T have time to check it to see if its the same.
http://cs.trains.com/trccs/forums/t/162279.aspx
I saw your name at the bottom.. thought it was your thread. Sowry.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
