General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 11-18-2009 1:38 PM by maxman. 3 replies.
Rate:
Sort Posts:
Page 1 of 1 (4 items)
11-18-2009 10:49 AM
Offline willjayna
Not Ranked
Joined on 12-31-2008
Posts 95
Styrene Question
I am planning on purchasing a HO Scale Athearn C44-9W and turning it into a Norfolk Southern paint scheme but before I paint I need to relocate the front headlight and number boards. I am going to get some styrene strips to use as filler for the holes vacated by the old light and boards.
My question is what should I use, I am assuming styrene strips would work the best but how thick should they be. I don't care if the strips protrude into the cab of the loco as long as they are flush on the outside.
Will
11-18-2009 11:04 AM In reply to
Offline dehusman
Top 50 Contributor
Joined on 09-20-2003
Omaha, NE
Posts 5,425
Re: Styrene Question
For the lights, get some sprue from a plastic model, grab each end of a piece and hold the middle over a candle, soldering iron or someting small and hot.  When the plastic begins to soften, pull it to form two long tapers.  After it cools, stick the tapers into the holes and glue in place then trim.
11-18-2009 11:16 AM In reply to
Offline Silver Pilot
Not Ranked
Joined on 05-15-2009
Posts 326
dehusman:
one small change to Dave's recommendation.  Instead of wait for the sprue to cool, if you insert it into the headlight hole while it is still soft you'll get a better seal all the way around the openning and need less sanding and filler to get it perfectly smooth.  You could also reheat the sprue to soften it.
11-18-2009 1:38 PM In reply to
Offline maxman
Top 500 Contributor
Joined on 02-15-2008
Posts 1,202
Not being an NS fan, I'll go ahead and ask:  Looks like Athearn will have an NS version of this engine coming out in late December of this year.  If that model has the detailing in the proper place, would it not be better to wait and save yourself a little work?
http://www.athearn.com/Products/Default.aspx?ProdID=ATH78854
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
