Trains.com
Motive power Vs. tonnage
  • Member since
    January 2009
  • 1,326 posts
Posted by BerkshireSteam on Friday, November 6, 2009 3:27 PM
Wondering how motive power has compared over the locomotive generations in amount of tonnage an engine can pull?
As the same question, how did the amount of tonnage an engine can pull compare between a 4 axle unit and a 6 axle unit of the same model?
Particular engines of interest are F7, GP/SD7, GP/SD9, GP30, GP38, GP/SD40, GP60, B/C40-8, RS3, B/C30-7, U25B, C420, C424, C628
  • Member since
    May 2003
  • 25,292 posts
Posted by BaltACD on Friday, November 6, 2009 4:56 PM
The tonnage ratings of 1st & 2nd generation diesel locomotive have been lost to the pre-computerized archived.  Current ratings for several territories
Territory                SD402  SD50 C40-8 ES44DC SD70AC CW44C CW60AC
WB Mountain          2100   2500  2700   2900      3450       3650       3950
EB  Mountain          2900   3450  3750   4050      4750       5050       5500
Flatland                  8550 10150 11100 11950     14100     14950     16200
Never too old to have a happy childhood!
  • Member since
    February 2005
  • 2,366 posts
Posted by timz on Friday, November 6, 2009 6:07 PM
All the engines have their ratings of continuous tractive effort, which is supposed to determine the maximum tonnage any diesel can haul over any given piece of dry track. For a 62:15 F7 that's 40000 lb; for a 62:15 SD40-2 it's 83000 lb. So the SD is supposed to be able to match a pair of F7s. Can it always live up to that? Us fans don't have much idea about that.
It's a different question what the different engines can haul at, say, 50 mph.
  • Member since
    September 2003
  • 4,422 posts
Posted by DSchmitt on Friday, November 6, 2009 10:45 PM
From The Railroad- What It Is And What It Does  by John H Armstrong
"Over most of the speed range, tractive force is limited by engine horsepower, and the curve is the same for both types of units.  The four-axel unit will actually haul a little more tonage because it has some 55 tons less of its own weight to pull along.
The difference shows up below about 23 mph, where adhesion required by the lighter unit to develop tractive force corresponding to its horsepower begins to reach the limit or reliable traction -- 16 to 18 percent. To keep the engine from being "slippery" its control circuitry is arranged to cutback its power at lower speeds.  The six-axel unit thereby moves out in front in haling capacity..  With 50 percent more traction motor thermal capacity, the C-C unit can "lug" that much more tonnage up a grade where low -speed horsepower is needed."
I tried to sell my two cents worth, but no one would give me a plug nickel for it.
I don't have a leg to stand on.
  • Member since
    December 2008
  • 28 posts
Posted by monon99 on Monday, November 16, 2009 10:19 PM
 Here's an example from my territory - an 8600 ton grain train required 5 sd40-2s or just two c40-8s - big difference! The easy calculation of horsepower vs. tonnage is gone now with all the advances in adhesion management and AC traction which have greatly increased the tonnage a locomotive can pull - at least until the computer fails then all bets are off and its back to sand,feel and listen for engine speed and wheel noise and hope you can make it!
  • Member since
    March 2008
  • 3 posts
Posted by BB-61 on Saturday, December 5, 2009 7:47 PM
I have found this website to be helpful in answering these type of questions:
http://www.alkrug.vcn.com/rrfacts/hp_te.htm
BB-61
  • Member since
    February 2016
  • 176 posts
Posted by Tugboat Tony on Sunday, December 6, 2009 4:02 AM
we base power for trains on Tons per axle,where 1 axle = 10,000 lbs of tractive effort.  i.e. a SD40-2 has 7.1 equivelant axles, computes out to 71000 lbs tractive effort, a GP 40 has 50000 lbs, for 5 axles
C40-8 is 10.1 (101,000)
B40-8 7.8
GP38 4.5
GP39 4.5
SD70 10.4
C44-9 11.5
C44AC-12.1
C60AC 12.1
SD90/43 MAC  11.6
SD80MAC  13
SD90MAC  12
SD70ACE  12
  • Member since
    September 2002
  • 525 posts
Posted by enr2099 on Sunday, December 6, 2009 7:01 PM
 At CN we use horsepower per ton. 2.2 hp per ton to get trains over the hills on the old BC Rail. CN will add power or remove tonnage to ensure the Hp/T meets the requirement for the sub.
Tyler W. CN hog
Join our Community!
Our community is FREE to join. To participate you must either login or register for an account.
Search the Community
Newsletter Sign-Up
By signing up you may also receive occasional reader surveys and special offers from Trains magazine.Please view our privacy policy
