delivery48:Need help-Some time ago there was an article on buildind a paint spray booth.
I built a booth from these plans, and it has served me well for the small amount of spray painting that I do. You'll find that the fan/blower is the most expensive part of the project.
If I remember correctly, the author of the article actually did some research and/or testing to determine the proper size of blower, as opposed to those who will suggest that window fans or kitchen exhaust fans are adequate. Also the booth was made from sheet metal, which makes it durable and easily cleanable, and resistant to the inevitable paint/solvent spill that will occur. I had tried making a booth out of plywood, and that just didn't work for me. I can't see that the use of a cardboard box is a very practical idea.
A word of advice....I recently found that the furnace filter makers have changed the design of the filters, which slightly changed the overall dimensions of the filter enough so that it would not fit into the holder at the back of the booth. I had to make a slight dimensional modification to the holder. I suggest that you buy a filter of the specified size (10 X 20?) and size the booth holder portion to fit.
Regards
