General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 11-06-2009 12:54 AM by jasperofzeal. 30 replies.
Rate:
Sort Posts:
Page 1 of 3 (31 items) 1 2 3 Next >
11-04-2009 7:41 AM
Offline mobilman44
Not Ranked
Joined on 09-17-2003
Southeast Texas
Posts 1,828
Let's talk Couplers - HO Knuckles....................
Hi!
As some of you may recall from my previous postings, I've spent the last year building a new 11x15 two level HO layout.  In the last couple days, I finished the DCC wiring of the main level outer main, which is essentially a large loop.  My construction method is to lay a portion of track, wire it, and test it thoroughly before moving on to more track.
Soooo, I brought out some of the 150 cars and made up a 16 car train (along with a BLI 2-10-2 and RSD-15) to test the new trackage.  Note that these 150 cars (I've got about 300 more) all have knuckle couplers and Intermountain wheelsets and have been checked out a couple of years ago.
Well, I soon found that some of the cars would just not stay coupled - or be very difficult to couple in the first place.  Each of these cars had "non-Kadee" couplers!  Now I've been a KD advocate for decades, but several kits (and a few ready to run) cars I've bought in the last 8 years come with "other" couplers.  I figured they would be OK, but now I just don't think they stand the test of time.
Sooo, it looks like these cars are going to the RIP track, and I'll open up that big pack of KD whisker couplers and replace the "rubber" ones.
Am I the "lone ranger" with this situation, or have you had similar problems????
ENJOY,
Mobilman44
11-04-2009 7:47 AM In reply to
Offline jeffrey-wimberly
Top 10 Contributor
Joined on 06-21-2004
Sundown, Louisiana
Posts 13,327
Re: Let's talk Couplers - HO Knuckles....................
 Every time I get a new Bachmann or Athearn car (that's mostly what's available here) they always have couplers from 'some other' supplier. They get Kadee couplers just as soon as I have time to change them out. At the moment I have some tank cars that need shelf couplers. I'll order them as soon as I have the funds.
11-04-2009 7:56 AM In reply to
Offline Driline
Top 200 Contributor
Joined on 07-04-2006
Bettendorf Iowa
Posts 2,047
 Nope, I have the same problem as you.Those couplers may look good, but they just don't work as reliable as the Kadees. Change them out.
11-04-2009 7:58 AM In reply to
Offline ndbprr
Top 50 Contributor
Joined on 09-10-2002
Posts 4,964
As the old saw say's, "You've used the rest.  Now use the best".  Kadee and only Kadee for me.
11-04-2009 8:02 AM In reply to
Offline pastorbob
Top 500 Contributor
Joined on 12-03-2002
Posts 859
My practice since 1960's was to put Kadee on anything I bought.  that practice continues today, and I keep an inventory of the shelf and the 5's on hand.  Each new piece of equipment is checked when purchased and it goes to the work table before entering service to remove the junk and put in Kadees.
Other than a lost knuckle spring once in a while, I don't have failures.  Oh, I also make sure they are at the right height with a gauge before turning them loose on the railroad.
Bob
11-04-2009 8:05 AM In reply to
Offline dknelson
Top 50 Contributor
Joined on 03-20-2002
Milwaukee WI (Fox Point)
Posts 4,817
We are at least beyond the absurd ritual of opening up an HO kit and the first action was immediately tossing out the horn hooks , or buying a ready to run item and first thing removing the horn hooks and throwing them away.
Not all non-Kadees are equally objectionable in my experience.  At least as of now my attitude has been to give the non-Kadees a chance with the notion that if they fail they will definitely be replaced by an official Kadee product.
Dave Nelson
11-04-2009 8:11 AM In reply to
Offline simon1966
Top 50 Contributor
Joined on 07-07-2003
Metro East St. Louis
Posts 4,381
First up let me say that I prefer to use Kadee's myself.  However, not all the "other" brands are as bad as each other.  Those that use the plastic filament knuckle spring are borderline worthless.  These can fail with a car in storage as I discovered when some were left in a box that resulted in the filament getting deformed into a wide open setting.  Having said that, some of the McHenry couplers that use real metal springs for the couplers are not too bad.  They are not as strong as the Kadee and simply don't do well for long heavy trains, and most certainly don't hold up well in accident situations.  But for shorter, less weight trains in certain applications they have worked well for me.  In particular they have held up well in some cheap IHC passenger cars.
11-04-2009 8:36 AM In reply to
Offline MisterBeasley
Top 10 Contributor
Joined on 12-02-2004
Bedford, MA, USA
Posts 9,626
dknelson:
I just bought a pair of Walthers "platinum line" cabeese.  The couplers weren't Kadee, but they seem to fall in the "acceptable until they fail" category.  But, there was still a package of horn-hooks in the box.  And no matter how many times I find horn-hooks, it never fails to make me chuckle.  Thanks, Walthers, for adding a smile to my day.
11-04-2009 8:42 AM In reply to
Offline grizlump9
Top 500 Contributor
Joined on 11-08-2008
Posts 815
 looks like coupler controversy is akin to the "better mousetrap" syndrome.  nothing beats the old victor snap trap and a piece of cheese.
 i personally find that the different makes of couplers don't "play well together" and like others, i replace the clones with an original Kadee at the first sign of trouble. some of the odd balls work ok for a while but it is safe to say that all of them will probably get changed out eventually.  i use the number 5's with the original style metal centering spring in the draft gear box and when properly adjusted, they give dependable service and are almost bullet proof.
 even then, an occasional balky one requires a little nudge to get it centered properly but that is a lot easier to do in HO scale than when i worked with the 12"=1' ones.
 Kadees may not be the best "value" as some define it and a lot of guys are happy with the clones but i see it like buying a Cadillac automobile or IBM computer.  they might cost more but few people complain about them after they own one.
 if i were still in the market for more rolling stock, i would gladly pay an extra buck for cars and locos that come equipped with original Kadee couplers instead of some of the junk that is on a lot of them now.
grizlum
11-04-2009 11:59 AM In reply to
Offline ATLANTIC CENTRAL
Top 500 Contributor
Joined on 01-26-2009
Maryland
Posts 1,228
To echo many of the comments here, EVERY car and loco on my layout has genuine Kadee couplers.
AND, I personally use only the orginal standard head couplers, no semi scale versions for me. Using NMRA standard track and wheel sets results in an amount of possable side play that requires the larger couplers for reliable coupling. The smaller "gathering range" of the semi scale couplers and NMRA track standards does not provide reliable enough coupling in my opinion.
All the "clones" suffer from one or all of several faults. Most are larger and looser than the Kadee, creating too much train slack action and larger distances between coupled cars. The ones with plastic knuckle springs are famous for loosing their "spring" and none are up to the weight of even 50 car trains for extended periods of time.
In addition to only using Kadee couplers, most of my rolling stock has Kadee sprung metal freight trucks outfitted with Intermountain wheel sets. After much testing this was found to be the freeest rolling and best tracking truck to be had.
Sheldon
11-04-2009 3:17 PM In reply to
Offline kog1027
Not Ranked
Joined on 10-06-2002
Central Florida - US
Posts 159
Again, I don't pull couplers off of RTR cars.  Too likely to break something.
I measure with a coupler height guage and adjust where needed.  I also test wheels for rolling and roundness, trucks for proper flex.
So far I've not encountered issues with the Clone couplers once they've been tested.
I have replaced couplers that fail testing for one reason or another.  I used regular McHenry's until I ran out, then  scale McHenry's and now scale whisker Kadee's ( Those are what my LHS had in stock. ), they all seem to work just fine together.
Over on the Atlas forums they are talking up Segents, which are nice but don't interoperate with Kadee's or Clones.
Mark Gosdin
11-04-2009 3:30 PM In reply to
Top 500 Contributor
Maryland
Posts 1,228
kog1027:
Mark Gosdin
Mark,
How long are your trains? With short trains the clones seem to work OK. Those of us running 35 car, 50 car or even longer trains generally find them to be a problem.
Sheldon
11-04-2009 3:39 PM In reply to
Offline markpierce
Top 50 Contributor
Joined on 04-04-2003
Union-Garratt Loco (Mark in Martinez, CA)
Posts 4,392
grizlump9:
Professional rodent catchers tell me peanut butter is the preferred bait.  I didn't think to ask whether chunky or creamy style is best.
Mark
11-04-2009 4:29 PM In reply to
Offline ford86
Not Ranked
Joined on 07-26-2004
Posts 117
Every car I build or buy goes through the "new car" routine, weight cars to nmra specs, replace all couplers with kadee's or the walthers proto max metal couplers (those are just as great btw) gauge the wheels/coupler height and change out cars that have those real roller bearings or plastic wheel with intermountian for the sole purpose of being able to put a small stamp resistor on one axle for detection.
 I have found that the "other" couplers that are made from plastic dont hold up very well to properly weighted trains, either a coupler would snap pulling up a grade or a operator would do a high speed ram and the knuckle would actually bend back over the side.
11-04-2009 4:43 PM In reply to
Offline jfallon
Not Ranked
Joined on 01-02-2006
Va. Beach, VA
Posts 256
 I have only one exception to my own "Kadees or don't run" rule, I have used the extended McHenry couplers on some IHC/Rivarossi passenger cars. I have a N&W Powhatan Arrow set that gets run once in a while as an excursion train, and the knuckle couplers let me run it with Athearn Heavyweights. The McHenrys are a pop-in replacement, so I don't need to try and body mount the couplers. Yeah, I'm lazy that way .
        John
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
