Wife's mother got sick so had to put her on Saturday night Cresent out of Atlanta so wouldn't have to drive her all night. There were a lot of small items noticed that irritated several passengers.
1. Got a good fare on AMTRAK website however as usual no sleeper space available. She checked after Gainesville but there were not any no-shows.
2. Arrived at station 1 Hr before scheduled departure after 45 min traffic delay.
3. Only one agent working with 5 pass in line ahead of us doing tickets and bag checking. 2 Baggage handlers were not checking bags.
4. Decided to use Quik-Trak to print out tickets but unit would not read bar code on the confirmation slip I printed out at home. Had to dig out her credit card to initiate Quik-Trak. Got tickets and told people behind us (alot arriving then due to traffic delay) be prepared to do same (turned out unit would not read any of preprinted confirmations).
5. Got in agent line no additional pass in line as bag handlers they said couldn't check bags and they then disappeared
6. Agent informs us too late to check bags (45 min before departure) that bags would have to go on Sunday's train (unacceptable due to train change).
7. Several people behind us same thing even though they complained about traffic problem. (we didn't).
8. Train arrived 2 minutes early although site later posted it 4 minutes early.
9. Now it gets very interesting. ATL's platform is about 1200 ft long with the 200 ft NE section under the station lobby but not very well lighted.
10. Train front stops about 200 ft SW of stairwell (another 100 ft SW)(300 NE ft not used)
11. About 25 people start detraining.
12. 2 full baggage carts (ancient steel tires high platform type) go toward baggage car blocking one side of platform to passengers.
13. At 15 min before departure boarding announcement, started down stairs (equivalent to 3 flights) with wife's bags and several people followed me. Over 60+ passengers boarding.
14. Went around bag carts and got to assigned car.
15. Heard attendant tell crew member water hose too short (hoses located on far SE side of train).
16. Attendant (very good according to wife) assigned seat, I took bags up in car, securred same, and returned to lobby again avoiding bag carts. Carts returned with arriving baggage.
17. 5 minutes before departure time gate closed.
18. Final passengers got on board 2 minutes before departure time.
19. At dep time train pulls up about 200 ft, water added to car(s), then train leaves 5-6 minutes late.
This dizzy dance brings up several questions.
21. When will there be more sleepers?
22. Why only one agent for 60+ passengers?
23. Referencing one agent why are bag handlers not able to check bags?
24. Why are confirmation bar codes so jammed together that some Quik-Trak units cannot read codes?
25. Possible reason of stop so far SW.
a. Locomotives need fuel -- NO-- None added front #98 - 1710 Gallons FOB, second #? 1400 gal (HEP unit)
b. The water units are all located starting about 600 ft SW. If loco ever needs water then train would stop even farther SW.
26. Why are water hoses too short?
27. WHY are water units (1ft x 1ft x 2 ft tall) not located farther NE? This is a NS double track under the lobby with the platform splitting the tracks. A no customer third pocket track also goes under the lobby SE of the main tracks for another 2000ft + NE and 2000ft+ SW. Certainly there could be installation of additional water service units?
28. If the additional water units were installed couldn't additional lighting be installed NE of the stairway for at least the baggage car to be out of the way and passenger not having to walk around them? There are the problems associated with southbound trains having to take the carts all the way to the SW end but stopping the southbound train farther NE would mitigate the problem somewhat.
29. Wouldn't sleeper passengers like not hikiing 1000+ ft to their car?
30. Why was departure time shown on time even though all servicing and final departure 5 - 6 minutes late? Note: next 2 stations showed late arrivals and departures maybe because time could not be recovered.
31. Why is it that the bag check time is posted as 30 minutes in the timetable but ATL has one small sign stating it is 1 hr for ATL? Why couldn't the ticket confirmation also state the 1 Hr for this and other station where it is necessary?
32. Why not eventually install a larger - faster passenger/bag elevator to speed those passengers and bags?
If this a measure of performance around the AMTRAK system and it probably is then Mr. Boardman needs to get observers to document these minor items. Then he can initiate corrections. This would better on time performance for example if all these items were corrected in ATL a 15min turn appears possible. This also may improve passenger satisfaction which is congressionally mandated.
