Railway design, construction, and gardening
A place to discuss trackplan, building, and design questions. You may also discuss gardening matters here. If you're new here, please read our forum policies.
Last post 09-15-2009 6:22 AM by lownote. 12 replies.
Rate:
Sort Posts:
Page 1 of 1 (13 items)
07-09-2009 6:19 PM
Offline Optisailorusa
Not Ranked
Joined on 07-09-2009
Posts 9
Garden Track Choice
Hi all,
I am looking for track to start off my Garden railroad. I already have some LGB brass track but it is not enough and I have a big lawn to circle. I am looking for about 50 feet or more of track and that is costly. If anyone knows of some good buget track that would be great.
Thanks,
Optisailorusa
07-09-2009 8:25 PM In reply to
Offline ttrigg
Top 200 Contributor
Joined on 02-27-2004
North, San Diego Co., CA
Posts 2,157
Re: Garden Track Choice
Less expensive track? You joined the hobby about 4 years too late for that. In the last 3~4 years the price of rail has jumped by about 350%~400%. China has been buying up a big chunk of the world's supply of copper/brass, causing the massive increase in prices. I would suggest cruising through all the advertisements in GR mag, especially their websites. Book mark them all and check everyone every week. You just might find a special limited time pricing somewhere. Other than that, the next best bet would be to wait until January for the "3 for price of 2" or "4 for price of 3" sales.
07-10-2009 7:12 AM In reply to
Offline two tone
Not Ranked
Joined on 07-14-2006
Shire Counties UK
Posts 531
Hi Welcome to the forum,      Track keep an eye on ebay there are some good offers on there, as you have LGB brass try and keep what you need to the same make. hpoe this helps.
07-10-2009 1:28 PM In reply to
Offline dwbeckett
Top 500 Contributor
Joined on 06-13-2006
Oakley Ca
Posts 917
Hi and welcome to large scale railroading, A good source is your local hobby shop if they do consignments. That's what happened to my brass track, I am using all stainles steel.
Dave
07-10-2009 2:51 PM In reply to
Offline Greg Elmassian
Not Ranked
Joined on 08-21-2005
North Coastal San Diego
Posts 329
If you are sticking with brass, the new AML track is some of the lowest cost out there, and many people have purchased it and are very happy.
Regards, Greg
07-10-2009 4:43 PM In reply to
Offline smcgill
Not Ranked
Joined on 07-11-2003
S.Easton , Mass.
Posts 427
Welcome! If your trying to keep the LGB look, try Axel he sells track that is very close. He has flex track and the usuall pieces. https://www.train-li-usa.com/store/index.php Good luck Sean
07-10-2009 11:00 PM In reply to
Offline ttrigg
Top 200 Contributor
Posts 2,157
http://www.train-li-usa.com/
That works out to about $6.50 per foot (rail plus ties), then add another fifty cent to a buck per foot or so for your road bed.
07-13-2009 1:17 PM In reply to
Not Ranked
Posts 9
Hi all,
Thank you very much for the welcome and the advise. I have been watching ebay quite regularly now but I am not sure that I want to get in to flex track as I would like it to be simple to replace and repair. Next question. What would you recommend doing to keep the track togeather? Track Clamps? Gorrila Glue? or something fairly simple. Thanks,
Optisailorusa
07-13-2009 1:41 PM In reply to
Not Ranked
Posts 329
 You did not state battery or track power. For battery power, use the stock slide on joiners. For track power I ALWAYS recommend rail clamps. You can go from inexpensive to expensive, and the quality follows the cost.
Low end: Aristo
Middle: Train-Li
High end: Split Jaw
(my opinions)
Regards, Greg
07-13-2009 10:31 PM In reply to
Not Ranked
Posts 9
I am using a track powered system for a small garden layout. I am on a fairly tight buget but I would like something that lasts and holds.
Thanks,
Optisailorusa
07-13-2009 11:34 PM In reply to
Offline ttrigg
Top 200 Contributor
Posts 2,157
Optisailorusa
It has been said many time in many places on this forum. But I'm gonna risk it again.
"Over power the power supply. Oversize the curves. Buy entirely too much track. Buy twice the number of turnouts you figure you will need. Then when that one engine comes along that you just cannot live without, you have already done all the "upgrading" needed to accommodate. The best part of it is that you finished your "upgrading" before another large increase in the prices hit!"
In my case I used 5 ft flex rails. I soldered the rails (see Tips and Tricks in current issue of GR) into 10 ft sections. I use Split Jaw clamps to join the longer sections. (cost cutting measure) I run track power and have no problems.
p.s. extra track and turnouts can easily form a temporary yard until needed elsewhere. (and it will be properly "aged"/"patinaed" by then.)
09-14-2009 10:30 PM In reply to
Offline chistech
Not Ranked
Joined on 09-15-2009
Posts 2
I have to believe I lucked out. I just picked up two loads of used track. 1st lot is LGB flex track brass. Over 550' with ties and an additional 80-100' in bare rails needing ties. Also came with SJ clamps for every joint. 6 large remote switches. Paid $500.00  2nd lot is 650' of AC SS rail. Flex rail and some sectional pieces. 4 #6 remote switches. $1,800.00. All the track is used but in pretty much excellent condition. I've been waiting to build my railroad until my entire yard was done with landscaping other than the area for my trains. I kept watching the price of track go up. This coming year is when I'm going to get the railroad started so I called a local garden railroad designer for some advise and mentioned I needed track. He set me up with the first lot and I found the other lot thru a Ebay add of a local guy. Made a call and bought the lot. Here in New England the SS is the way to go but people have used brass for years with no trouble. This is my first post but I will be posting more as the railroad begins to take shape.
09-15-2009 6:22 AM In reply to
Offline lownote
Not Ranked
Joined on 11-10-2007
Posts 130
 Good score!
 I have a mix of brass and stainless track, about half and half, and to be honest I haven't seen a big difference between them. Stainless might be a little better for me, but not much. Other people report  that stainless is dramatically better. I think it depends heavily on where you live and what very local things give you problems. My experiences with track conductivity vary a good bit with the seasons. In general you can't really go wrong with stainless
 As far as track joiners, I'd say yes clamps are the best if you are goign to run track power, but I still have some sections of track connected by Aristo's screw joiners, and they are still working just fine. If cost is an issue, in my experience you can add clamps gradually, as needed. It's possible to let the perfect be the enemy of the good--just because clamps are better, doesn't mean not having clamps won't work
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
SUBSCRIBER AND MEMBER LOGIN
E-mail Address:
Password:
Remember me
My Profile
Screenname: (get your screenname)
Search Community
in
