Electronics and DCC
The place to discuss wiring for DC and DCC controlled model train layouts. If you're new here, please read our forum policies.
Last post 07-04-2009 1:21 AM by rrinker. 7 replies.
Rate:
Sort Posts:
Page 1 of 1 (8 items)
06-30-2009 10:19 PM
Offline dobo
Not Ranked
Joined on 08-29-2007
Posts 6
atlas mark 3 turnouts
Hello i recently picked up 12 ho scale atlas mark3 turnouts, these have the metal frogs what kind of wiring must be done for a strictly DC layout? Is thre any special wiring need at all? are these rute selective?
thank you
mrk
06-30-2009 11:04 PM In reply to
Offline davidmbedard
Top 50 Contributor
Joined on 03-26-2004
Calgary, Alberta, Canada
Posts 5,074
Re: atlas mark 3 turnouts
 If you would like powered frogs, then you have some extra wiring to do.
Otherwise, its lay and play.
David B
07-01-2009 2:23 AM In reply to
Offline WSOR 3801
Top 500 Contributor
Joined on 12-06-2004
WSOR Northern Div.
Posts 1,092
 Here is a Mark 2 still in the package.  Your Mark 3 should be similar.
There are two screw holes, one on either side of the metal frog.  A screw goes through a hole, then a wire gets hooked up if you want a powered frog.  This requires some extra wiring and a switch.  The frog is dead as the switch comes out of the box.  Atlas switches are not power routing out of the box.  All routes get power.
07-01-2009 8:27 PM In reply to
Online rrinker
Top 25 Contributor
Joined on 02-14-2002
Reading, PA
Posts 7,530
 Mark 3's unfortunately are not threaded (at least not the Code 83 ones). And the metal is not somethign that takes solder. However, there is some hardware that comes with the Snap-Relay (which apparantly you can buy from Atlas seperately - the hardware, not the relay) tha tmakes it easy to hook up a wire to the frog. Or DIY with a small screw, nut, and ring terminal and forget about threadign anything into the frog hole.
                                            --Randy
07-01-2009 10:18 PM In reply to
Offline nbrodar
Top 100 Contributor
Joined on 06-20-2005
Phoenixville, PA
Posts 3,125
 Out of the package, the Mark 3 turnouts are not power routing, and have dead frogs.   No modifications are need for DC operation.   Just remember that both routes are live, and short wheelbase locomotives and those with only one truck power pick up may stall on the dead frogs.
Nick
07-02-2009 11:46 PM In reply to
Offline NYC-Big 4
Not Ranked
Joined on 07-06-2008
Ohio
Posts 27
Short wheelbased locomotives such as 0-4-0's will stop or hesitate, depending on the speed, through a number 6 or greater turnout.  I haven't had problems with a number 4 turnout but they are mainly in the yard areas.  The number 6 turnout will need to be powered since the frog is longer and has a longer dead zone.  If your switch machines have the appropriate connections, no problem, otherwise you can use the Atlas Snap Relay as a supplement to the switch machine.  Just make sure the wirng is connected right.
07-03-2009 10:52 PM In reply to
Online larak
Top 500 Contributor
Joined on 10-03-2005
Ulster Co. NY
Posts 1,177
I've successfully tapped several of these in staging. (I prefer the look of Shinohara for visible track).  Pretty easy. Can't seem to recall if it was a 2-56 or 4-40 thread though. I ran in a brass screw from the bottom side. You can either wrap a wire or solder to the screw. Feed the frog from the aux contacts on the associated tortoise.
My only issue was pushing too hard on one and the frog came loose. A bit of CA fixed it.
Karl
07-04-2009 1:21 AM In reply to
Online rrinker
Top 25 Contributor
Reading, PA
Posts 7,530
An 0-80 brass screw and nut will fit through the hole in the Atlas frog with no pressure, no drilling, and no tapping. Put the nut on top, tighten it down, and solder to the screw head.Or use a miniature ring terminal, soldered in the comfort of the workbench, and no heat will need come near the frog - they do tend to pop off easily when warmed or if pushed too hard.
                                            --Randy
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
