Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Older Athearn U Boat DCC conversion With Video
  • Member since
    October 2006
  • 2,934 posts
Posted by C&O Fan on Wednesday, May 6, 2009 9:19 AM
My next project after i finish my Bachman 2-6-6-2  DCC sound
conversion will be an older Athearn Uboat
I found this thread with some photos of a 40-2 conversion but are there any others
http://cs.trains.com/trccs/forums/p/144152/1601766.aspx
My first thoughts are to make a dummy loco the sound unit
and put the decoder in the powered unit
TerryinTexas
See my Web Site Here
http://conewriversubdivision.yolasite.com/
  • Member since
    February 2002
  • 13,892 posts
Posted by wjstix on Wednesday, May 6, 2009 12:45 PM
A good 1/2" by 1" oval speaker packs plenty of wallop and fits in most any engine.
Stix
  • Member since
    October 2006
  • 2,934 posts
Posted by C&O Fan on Wednesday, May 6, 2009 2:22 PM
davidmbedard
 My question is why?  There is plenty of room in there for a motor and sound decoder....
David B
Well I found out if it take the thick plastic glass out of the cab a high bass circular baffle will fit
inside the cab of the dummy
Pointed down
or pointed horizontally
down the length of the shell
TerryinTexas
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Wednesday, May 6, 2009 6:37 PM
Though I've been gradually getting rid of my old Athearn blue box units,  I have a U33B (SCL) that I bought new some years back.  Its had almost no running time.  I've decided to weather and detail the body, keep it powered, install LED lighting, and install a Lok Sound unit with a high bass speaker using the method recommended by CMarchand.  I'm going to drop in a spare motor that came out of a P2K SD45 that, fortunately, has a low current draw.
Nice thing about the old Athearn U-boats is that due to the radiator housing structure, the excess hood width is not as noticeable as it is on the Blue Box EMD hood units.
"I like my Pullman Standards & Budds in Stainless Steel flavors, thank you!"
  • Member since
    October 2006
  • 2,934 posts
Posted by C&O Fan on Thursday, May 7, 2009 9:43 AM
AntonioFP45
Snip
Snip
Ok i give up who is CMarchland
I see Loc Sound makes 2 decoders for this loco
And several for the later dash series
72845 GE FDL-16, 16 cylinders, with turbo charger, 2chime air horn U25, U28, U30, U33, U34, U36
72846 GE FDL-16, 16 cylinders, with turbo charger, 2chime air horn, dynamic brakes U25, U28, U30, U33, U34, U36
But at this Point i'd be inclined to go with a Tsunami
Since i was so badly burned on Loc sound on my H-8
Unless i could hear it first
Do you have any links to sound samples ?
TerryinTexas
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Thursday, May 7, 2009 7:24 PM
 Hi C&O,
CMarchand is a fellow forum member whom is also a good friend of mine.  Below is one of his threads:
http://cs.trains.com/trccs/forums/p/80499/1300038.aspx#1300038
He's been in the electronics field as a career for over 30 years and is a well known DCC expert here in the Tampa Bay area.  Just drop him a PM if you have any questions. He installed the LokSound system in my Genesis SD45-2.  The sound is great and the motor control smooth.
I"ve only heard the Diesel Tsunami GE U-Boat on YouTube, but I was impressed.  Especially since the famous "chug-chug" throb of the prime mover was quite audible.  I'm considering getting a Tsunami for my Genesis FP45.
Unfortunately, in my case, the Diesel Tsunami doesn't come with the appropriate horn for the Seaboard Coast Line U-Boats, which for me is important.  Carl took a prototype sound sample of a Leslie RS5T-RR0 horn, carefully edited it and uploaded into my SD45-2.  The surprised looks on peoples faces when I actuated the horn with an NCE controller at a club one day said it all.    CoolThumbs Up
  • Member since
    October 2006
  • 2,934 posts
Posted by C&O Fan on Saturday, May 9, 2009 10:04 AM
While waiting for the decoder to show up i changed the lighting from the old
huge athearn bulb to a pair of grain of wheat bulbs
one for the lower hood and one for the upper lights and number boards
and as you can see the cab remains dark
This would actually be a good fiber optic application
time will tell if the bulbs melt the plastic
I just tucked the upper bulb under the plastic lense insert
then taped it in place
TerryinTexas
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Sunday, May 10, 2009 9:51 AM
 NIce going C&O.   You got rid of the traditional "Engine crew getting fried in the cab" look that's been synonomous with Athearn Blue Box units for decades ClownTongueWinkCool
  • Member since
    October 2006
  • 2,934 posts
Posted by C&O Fan on Sunday, May 10, 2009 10:45 AM
Yesterday I spent some time wiring up an 8 pin receptacle
like this
http://www.litchfieldstation.com/xcart/product.php?productid=999002983&cat=174&page=1
So that when i get the decoder i should be able to just plug it in
Now I have to figure out where i can place a speaker
TerryinTexas
  • Member since
    October 2006
  • 2,934 posts
Posted by C&O Fan on Monday, May 11, 2009 6:42 AM
Here is a sound sample for the Tsunami
For this loco
TerryinTexas
  • Member since
    December 2004
  • 21,484 posts
Posted by MisterBeasley on Monday, May 11, 2009 8:14 AM
If you use LEDs instead of grain-of-wheat bulbs, you will not have to worry about melting the plastic.  You will also get a lower current draw, effectively infinite life, and a more powerful straight-ahead beam of light.
I've just put a Tsunami into a Proto GP-9.  I'm really happy with it.
It takes an iron man to play with a toy iron horse.
  • Member since
    October 2006
  • 2,934 posts
Posted by C&O Fan on Monday, May 11, 2009 1:29 PM
Well all that is true but i didn't have any LEDs but i did have some 16 volt bulbs
and i also didn't have any resistors and am not sure which ones the Tsunami uses
TerryinTexas
  • Member since
    December 2003
  • 9,642 posts
Posted by AntonioFP45 on Monday, May 11, 2009 5:11 PM
C&O Fan
For this loco
No ifs, ands, buts, or "ho-hums" about it................That's a chugging GE U-Boat! CoolThumbs Up  That brought back some fond memories.  Thanks for the link C&O.  Nice job,  Soundtraxx!
Regarding  LEDs:  Minatronics Yeloglo White (Ultrabright 3mm):  Part # 12-310-05  Cost $7.95  Comes with 5 LEDs and appropriate resistors.
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Monday, May 11, 2009 8:52 PM
Neither of the two values of resistors the Yeloglo LEDs come with are appropriate for DCC. Use 1K ohm. I use the Yeloglo LEDs exclusively, and by the time I am done converting my locos I will have a small bundle of those resistors they supply.
                              --Randy
Modeling the Reading Railroad in the 1950's
Visit my web site at www.readingeastpenn.com for construction updates, DCC Info, and more.
  • Member since
    October 2006
  • 2,934 posts
Posted by C&O Fan on Tuesday, May 12, 2009 9:44 AM
rrinker
                              --Randy
Good to know Thanks Randy
I wrapped the wires with some painters tape to clean up the mess a bit
TerryinTexas
  • Member since
    October 2006
  • 2,934 posts
Posted by C&O Fan on Tuesday, May 12, 2009 5:20 PM
I Drilled 2 holes and cut 2 notches for the wires to slide into the holes on both locos to connect the speaker in the dummy engine to the speaker in the powered loco
After sliding the wires in the notches to the holes when the body is placed back on the frame the coupler pocket closes the end of the notch trapping the wire in place
I used Micro connectors for the wires but would have had to Drill really big holes for them to pass thru
The notches are just slightly bigger than the wire and don't look too bad
Sorry the picture is blurry but you can see the holes and the slots run from the opening for the coupler pocket over to the hole
once in place The wires don't look too bad
Here a view from the side
TerryinTexas
  • Member since
    October 2006
  • 2,934 posts
Posted by C&O Fan on Wednesday, May 13, 2009 5:50 AM
Finished the install  and shot a short video of lash up
the sound coming from the dummy loco is just different enough to make it sound like 2 different
locos
I used a High base 1 inch circular speaker in a round inclosure in the dummy
pointed down the length of the shell front to back
The powered loco has a smaller rectangle speaker pointed down from the top of the shell at the back end of the shell
You can see the number boards are lit but the cab is still dark
Those V16s must have pistons the size of garbage cans to make a chugging sound like that
After I shot the video I increased the momentum to make the engine rev up a little more before the loco moves
TerryinTexas
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Wednesday, May 13, 2009 7:18 AM
 GE prime mover nomenclature doesn't lend itself to easily telling the physical size of the diesel (neither does EMD's new one), but EMD's old one was easy - 645-series is 645 cubic inches PER CYLINDER. Somewhere I still have the issue of Car adn Driver from the 80's where they did a 'road test' on a GP50 and explained the displacement and horespower in terms of how many Corvettes it was. Big engines liek that are just amazing. Now, where's that Youtube video of the GE throwing a rod... look that one up, it's pretty impressive.
                                                  --Randy
  • Member since
    October 2006
  • 2,934 posts
Posted by C&O Fan on Wednesday, May 13, 2009 7:32 AM
rrinker
                                                  --Randy
When doing some research on which decoder to buy
I found this
http://www.geocities.com/wbd641/U30.html
TerryinTexas
  • Member since
    February 2008
  • 8,908 posts
Posted by maxman on Wednesday, May 13, 2009 9:03 AM
C&O Fan
If you're interested in this sort of information, the following website has some relevant facts: http://www.thedieselshop.us/DataU33B.HTML
  • Member since
    October 2006
  • 2,934 posts
Posted by C&O Fan on Wednesday, May 13, 2009 9:56 AM
davidmbedard
 Well done!  It sounds great.
To get the unit to rev up before it moves, you can do 1 of 2 things...
1.  Adjust the speed table so that the motor wont get any current until a certain speed step.
2.  Use the motor disconnect feature and run the motor with functions...
David B
Thanks for the Kind words !
I Used Decoder Pro and did number 1
TerryinTexas
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
