Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
powering a Walthers Rotary Dump
  • Member since
    June 2007
  • 3,549 posts
Posted by Flashwave on Wednesday, January 21, 2009 10:20 PM
A long time ago in a Galaxy far far away, I remember seeing an article on powering the Walthers Rotary Coal Dump. But I can't find it now. I've been in the MR Mag indext, to no avail. Does anyone know of an article taking about doing this and offer any pointers
-Morgan
  • Member since
    April 2003
  • 5,440 posts
Posted by markpierce on Wednesday, January 21, 2009 10:35 PM
No, but you are really, really asking for trouble.  First, do your couplers allow them to be rotated when the dump is operated?
Be practical and place the rotary dump in a semi-enclosed building and let it mask the fact you aren't actually rotating the darn thing.
Mark
  • Member since
    November 2007
  • 1,089 posts
Posted by BlueHillsCPR on Wednesday, January 21, 2009 11:22 PM
It seems like it will be quite a job to tackle, but I have seen a video of one in operation.
Paul Mack motorized a Walthers Rotary Dumper.  I don't think it ever made it into a layout though.
Paul doesn't really provide a thorough explanation of how to motorize the dumper. This thread may give you some ideas how to proceed.  Paul apparently made his own rotating couplers but rotary couplers are available from Sergent Engineering as well.
Good luck.  Be sure to let us know how you make out with it.
Regards,
Kevin
  • Member since
    July 2006
  • 875 posts
Posted by jasperofzeal on Thursday, January 22, 2009 1:30 AM
TONY
"If we never take the time, how can we ever have the time." - Merovingian (Matrix Reloaded)
  • Member since
    June 2007
  • 3,549 posts
Posted by Flashwave on Thursday, January 22, 2009 8:13 PM
BlueHillsCPR
That's what I'm using.
Just to tell, The Dump comes with a plastic toothing on the dumper itself, and two small plastic gears. I think there's a shaft to go through the gears. I can tell you now that both Dad and I were afraid of chewing the plastic teeth up. There's just no motor. Have thought about hand cranking it too. Bu where it's sitting, that requires a long crank.
-Morgan
  • Member since
    July 2004
  • 133 posts
Posted by ford86 on Thursday, January 22, 2009 10:39 PM
I have about 60 cars equipped with the sergent rotary couplers, the way we powered it was with a old switch motor with kitbashed mounting and linkage. it worked fairly well the first 2 or 3 trains of 25 cars that got dumped....after that we ran into the problem with the coal material we were using was clogging the gears and eventualy worn them down, overall the dumper lasted about 10 trains of 25.
Unfortuanly we were using a black sand blasting material for its weight which also chewed up the gears so it now requires a rebuild, a soft coal looking material (rubber maybe) would reduce this problem but if you can afford it the way to go would be to get the end pieces cnc'd out of metal
One other problem we ran into was the parts which the dumper ends fit into in the bottom of the kit would occasionaly open up and would not hold the dumper in.  A simple nut and bolt would keep those closed
  • Member since
    November 2007
  • 1,089 posts
Posted by BlueHillsCPR on Friday, January 23, 2009 12:02 AM
Those Sergent couplers look pretty sweet.  I had never heard of them before but now I wonder why more people are not using them.  They are even more prototypical in looks and operation than Kadee, are they not?
I am sure there has to be a way to work around the few problems with automating this dumper.  I would like to be able to do something similar on my layout eventually.
  • Member since
    July 2004
  • 133 posts
Posted by ford86 on Friday, January 23, 2009 10:25 AM
The sergent couplers are designed to be a direct replacement for the coupler assembly on the e&c/lbf cars, the down side it that the dummy rotary can only mate with a dummy sergent coupler or a scale kadee coupler.
One problem we ran into with the cars were when we first installed the dummy sergent coupler to mate with the rotarys there was not enough play for the coupler to swing back and forth on the non rotary end (would derail) so we replaced them all with scale kadee's which greatly improved the trackability of the cars, along with that we also had to fine tune the truck lean and make sure they were completely free moving.  In addition we had to get the car up to 6-8 ounches total empty by filling the bottom tubs with lead weight or metal shot otherwise the empty strings would derail.
The minimum curve radius was 34 inches
  • Member since
    June 2007
  • 3,549 posts
Posted by Flashwave on Friday, January 23, 2009 2:43 PM
BlueHillsCPR
And stronger. (My slightly educated opinion anyway) It's held closed by Gravity, not a spring that can will work itself out eventually.
On the coupling itself, Sargent refers to being able to sometimes couple up dummy and live couplers (planned to be used on full roaster anyway), is this true? Could/should we use live Sargents on the B end of the car, or whichever end is not the rotator?
-Morgan
  • Member since
    January 2008
  • 2,622 posts
Posted by Packer on Friday, January 23, 2009 3:12 PM
Morgan, the prototypes only have one rotary coupler on the end that's colored differently.
I've though about having some sort of coal operations other that a loads-in loads-out powerplant, because I wanted to model the empty part. I haven't quite figured out how to make it so I could empty cars that aren't normally dumped (most of mine are 3 bays or 100 tons that have doors on the bottom, don't have any coal gons) and what to use for coal. The problem I have with the sergants is that the rotary ones aren't made to be universal. If they were, I'd probably have some coalporters (and some SD40-2)
I guess this'll work for ore trains too.
Vincent
Wants: 1. high-quality, sound equipped, SD40-2s, C636s, C30-7s, and F-units in BN. As for ones that don't cost an arm and a leg, that's out of the question....
2. An end to the limited-production and other crap that makes models harder to get and more expensive.
  • Member since
    June 2007
  • 3,549 posts
Posted by Flashwave on Friday, January 23, 2009 3:15 PM
Packer
Right, But there's still two couplers. The rotary, which on the model is a dummy, and the non rotary, which I want to know if could be a live and still couple to the rotaries
Packer
Not so much. Ore cars are so much shorter, you'd have to make sure that the cars fit perfectly on the dumper, lest you try to tilt half a car and dump the whole train on it's side. I suppose cest possible if the all fit right. Walthers did also promote this for woodchips
-Morgan
  • Member since
    January 2008
  • 2,622 posts
Posted by Packer on Friday, January 23, 2009 3:36 PM
Flashwave
Well, I think I found the answer on their FAQ page:
"Q: Will Sergent Engineering Couplers mate with conventional HO scale dummy couplers?
A: Sometimes. Most (but not all) dummy couplers are designed using the profile defined by the NMRA's RP-21.1 issued in 1957. This contour is about 25% larger than an actual scaled down version of the prototype. A little creative work with a file can usually result in a dummy knuckle that will reliably mate with the prototype contour used by the Sergent Engineering Couplers. The Glatzl dummy couplers offered by Sergent Engineering do however mate with Sergent Engineering's operational couplers with no modifications."
Flashwave
Maybe the using rotaries on ore cars will need thinking and tinkering.
Vincent
  • Member since
    July 2004
  • 133 posts
Posted by ford86 on Friday, January 23, 2009 6:50 PM
The sergent rotarys will mate to a live coupler, the scale #58 kadee coupler and the #5 will not
  • Member since
    June 2007
  • 3,549 posts
Posted by Flashwave on Saturday, January 24, 2009 5:34 PM
Packer
Flashwave
I do need to make a correction on something. Hanging off the rotay platform will not dump the whole trian, but it might dump a car in the wrong place. Let me see how Ore cars fit on my dumper, if it works then your clear to get one, if not, you aren't out any $$$
-Morgan
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
