Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
JMRI Decoder Pro
  • Member since
    January 2007
  • 551 posts
JMRI Decoder Pro
Posted by corsair7 on Monday, October 27, 2008 6:07 PM
Has anyone used this product? How do you like it?
Irv
  • Member since
    July 2006
  • 76 posts
Posted by mavrick0 on Monday, October 27, 2008 6:25 PM
Great software and makes programming very easy and visual, and when it comes to speed matching there is nothing better IMHO.  Then the fact you can roster all your loco's so if for any reason the decoder losses it's memory you can reset the decoder then program the saved settings back into the decoder.
Even if you don't have an interface to actually have decoder pro program your decoders just being able to see what CV to change to what value will help anyone as well.
  • Member since
    January 2001
  • 6,847 posts
Posted by jrbernier on Monday, October 27, 2008 8:37 PM
Irv,
  Decoder Pro is a 'freeware' program you can download from the JMRI group.  Your DCC system will need an 'interface' to attach it to your computer.  In the case of the Digitrax DCC command stations, the 'Locobuffer USB' will work.  NCE systems either need a serial adapter cable or USB adapter for the command station.
  Decoder Pro allows you to 'program' your DCC engines with a graphical interface on your PC and save the decoder values to a computer file.  It makes short work of programming an engine.  Here are some links for the above mentioned stuff:  It also will allow you to view DCC info from your command station and has a built in 'throttle' - It will work on Window, Linux, and Apple systems.
http://jmri.sourceforge.net/help/en/html/apps/DecoderPro/index.shtml
http://www.rr-cirkits.com/locobuffer-usb/LB-usb-flyer.pdf
Jim Bernier
Modeling BNSF  and Milwaukee Road in SW Wisconsin
  • Member since
    December 2001
  • 1,932 posts
Posted by Stevert on Monday, October 27, 2008 9:35 PM
 I've been using JMRI for about five years now, since about the 1.1.3 release.  It's the best thing that's ever happened to DCC, and it keeps on getting even better still.  Wouldn't be without it.
  Keep in mind, too, that DecoderPro is only part of what JMRI is/can do.  It goes far beyond just programming decoders...
 Steve
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Monday, October 27, 2008 9:38 PM
 Can't say again how awesome this program is - oh yeah, it's FREE! It wouldbe more than worth it just for making decoder programming easier - but then it also stores that information in a database. AND it does way more than just program the decoders.If you have a Digitrax system, the Slot Monitor is hugely useful. And the ability to build panels with the PanelPro component is great.
                      --Randy
Modeling the Reading Railroad in the 1950's
Visit my web site at www.readingeastpenn.com for construction updates, DCC Info, and more.
  • Member since
    October 2004
  • 941 posts
Posted by river_eagle on Tuesday, October 28, 2008 1:06 AM
Don't forget when using a usb interface that FREE 28 Function  throttle that's included in the software. the best zephyr upgade ever created.
When in doubt, rule #1 applies  Central Missouri Railroad Association cmrraclub.com
  • Member since
    January 2007
  • 551 posts
Posted by corsair7 on Tuesday, October 28, 2008 9:44 AM
Thanks, Jim.
And where do I get the 'Locobuffer USB'?
For the moment my computer us not near my layout (the computer is in my office on the second floo of my home ane the layout is in the basement, two flites down). So I expect to locate a programing track next to the computer. How should that be hooked up to the computer?
Irv
  • Member since
    December 2001
  • 1,932 posts
Posted by Stevert on Tuesday, October 28, 2008 12:04 PM
corsair7
Thanks, Jim.
Irv
Irv,
  The programming track doesn't hook directly to the computer, it will still be connected however you have it set up now (usually through separate programming outputs on your command station).  Think of JMRI and your computer as a really, really smart throttle.  You still need your DCC system in order for that "smart throttle" to be able to do anything.
  That said, if your computer is remotely located, and all you want to do is program decoders, you can use a stand-alone programmer like the Digitrax PR2 or PR3, or the SPROG II.  Those devices are designed for that "smart throttle" (computer) type of use, and are supported by JMRI.
Steve
  • Member since
    May 2008
  • 880 posts
Posted by Last Chance on Tuesday, October 28, 2008 7:54 PM
 Ive used it quite some time and it is very well done.
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Tuesday, October 28, 2008 9:26 PM
davidmbedard
corsair7
Thanks, Jim.
Irv
I strongly suggest going to your local 2nd had computer store and picking up the cheapest one you can find.  The whole Idea behind decoder pro is the ability to program and then test your units on the layout.  I can imagine going up and down 2 flites of stairs wont make this a fun process.
Please note that the Locobuffer does NOT give you the ability to test seperately from your Digitrax system, it has to be connected to the Digitrax system.
If you want the ability to program and run away from your DCC system, then you will have to consider something like the QSI programmer.  It is currently supported by JMRI and allows you to test as well as programme.
David B
 Dick has hinted around at that being made an add-on to the Locobuffer-USB for some time now, but I guess he hasn;t gotten around to it, or there isn't much demand to use it as a standalone programmer. The new PR3 from Digitrax does both, buffered PC to Loconet interface and standalone programmer, which makes it pretty much the most universal Loconet interface currently out there. SPROG is a nice programmer, and actually a mini-DCC system, but t does not provide a Loconet interface.
                      --Randy
  • Member since
    June 2004
  • From: From Golden, CO living in Puyallup (Seattle), WA
  • 751 posts
Posted by Renegade1c on Thursday, October 30, 2008 2:02 AM
 i love JMRI Decoder Pro. I will never go back to programming with a throttle ever again. I have used to a computer to program locos from the very beginning. Back in 1997 when we first got our DCC system we also got the PR-1 by Digitrax and it made programming so much easier than trying to figure CV Values. Decoder Pro is so much more advanced than the PR-1 was and it has become a breeze to program any loco.
My friend recently installed a Tsunami Sound decoder in one of his steamers and we were done tweaking it in about 30 minutes. Mind you this included setting it up to run the chuff off of a cam, add momentum and braking, select the correct whistle, adjust the volume, add reverb, etc.
I have the original Digitrax Super Chief, LocoBuffer USB, and a Powerpax unit. I have found this combination will program the most stubborn of locomotives.
It is really nice to be able to simply type in the 4 digit address that you want in Decoder Pro vs having to change cv 17 and 18 and 29 to be able to get a long address on a throttle.
I highly recommend JRMI and am very glad they were able to fight off KAM industries and their illegal patent.
Colorado Front Range Railroad:
http://www.coloradofrontrangerr.com/
flag
  • Member since
    January 2007
  • 551 posts
Posted by corsair7 on Thursday, October 30, 2008 8:31 AM
I've already downloaded Decoder Pro and installed on my office computer. I am awaiting the arrival of a Digitrax PR-3 and the relocation of my programing test track next to my office computer so I can program long addresses into my DCC equipped N-Scale locomotives and set up the lights on them to work properly. At some point the whole set up will be transferred to my train room and connected to my layout which is still under construction and won't be compete for a while due to financial constraints. At that point I'll do more. But right now I jest need to be able to set things up because my trains run only on the club layout for now.
Irv
  • Member since
    July 2006
  • 76 posts
Posted by mavrick0 on Thursday, October 30, 2008 7:19 PM
I'm hoping along with the PR3 you have also ordered a power supply for it.  It will not work without one without being connected to a command station.  I'm using a Digitrax PS12 that I had laying around to run mine.
  • Member since
    October 2004
  • 245 posts
Posted by chessiecat on Friday, October 31, 2008 2:03 PM
After following this post with great interest I have some questions. 1-Will Decoder Pro work on the Vista software and if so which version of DecoderPro should I download?  2- I have the Digitrax Zepher DCC system and a PowerPax hooked up to my programing track now am I to understand that I can hook the Loco Buffer ll between my computer and the Zepher ? 3- Will I need any other cables or adapters to be able to program decoders?
What I plan on doing is using DecoderPro on my laptop and just taking it to the layout and hooking up to my Zepher and using it and the PowerPax to program on the program track. All advice will be appreciated!  Thanks Jim
  • Member since
    June 2004
  • 751 posts
Posted by Renegade1c on Friday, October 31, 2008 2:22 PM
chessiecat
DecoderPro is a Java Based program. As long as you have Java (which can be install on almost all operating systems)  it will work. I currently have version 2.2 of JMRI which i believe (someone correct me if I'm wrong) is the most current (non-beta) version. As mentioned before you will need to have Java installed on your computer.
chessiecat
The loco buffer USB hooks up to a usb port and the other end connects to the loconet jack on the Zephyr. The cables that come with the Locobuffer should suffice.
flag
  • Member since
    December 2001
  • 1,063 posts
Posted by jalajoie on Friday, October 31, 2008 2:27 PM
chessiecat
1- I am using the latest version of Decoder Pro on a Vista PC.
2- The Loco Buffer goes from your computer and plug into Loconet. The PowerPax goes between the Zephyr programming track outputs and the programming track.
3- No.
Jack W.
  • Member since
    October 2004
  • 245 posts
Posted by chessiecat on Friday, October 31, 2008 6:32 PM
Thanks for the information guys. I guess all I have to do is order the Loco Buffer ll and download Decoder Pro and I will be in business. It sure will make it easier to program decoders and keep track of all the cv settings that DCC requires.
Thanks again!   Jim
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Friday, October 31, 2008 6:52 PM
river_eagle
Thanks River Eagle.  Could you (or anyone) expand on this a bit.  I have been using D.Pro for couple of months now, just to speed match locos.  I know the JMRI products can do much more.  Whereabouts in the programme do I go to make my Zephyr the best ever with this virtual throttle (I think that's what it is, no?)
And what other feature is the best thing to use after the D.Pro for programming and the throttle?
  • Member since
    July 2008
  • 1,206 posts
Posted by mfm37 on Friday, October 31, 2008 7:59 PM
Select the "TOOLS" tab and a drop down menu appears. Select "Throttles" and then "New Throttle". A throttle will appear. The function buttons are on the right side. Click on the button to the left of F0. The upper functions 16  - 28 will appear. Use that button on the lower left to toggle back and forth on the function keys.
 BTW, you can open more throttles the same way as the first one.
Martin Myers
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Friday, October 31, 2008 8:49 PM
 Well, if you have any turnouts controlled with stationary decoders, you can create a control panel to operate them in JMRI. That's the "Panel pro" portion of the program. You cna make it simple or go all the way and make it look like a real CTC panel, complete with the levers and lights. If you look on the RR-CirKits web site, there are several PDF and Powerpoint files with clinics from past NMRA conventions that more or less walk you through the process.
                         --Randy
  • Member since
    July 2006
  • 35 posts
Posted by jellybean on Saturday, November 1, 2008 10:18 AM
Hi everyone! I have been reading everyones comments on the decoder pro and would like to know if anything can be done for us MRC Prodigy users? I've read that, and if I understand it correctly, we can purchase a Sprog or QSI programer to do the programing and then just put the engines on the track and "run" our trains. Mostly I would just like to be able to run a consist without all the hassle of trying to get the engines to run in sync. I have a spare computer, Windows XP that has been collecting dust for about 6 months now that I would like to use for the trains.  I started with the original Prodigy, then the Advanced and now I have the Wireless. I have NO complaints with it. My layout is 40' X 14'.
Thank you to all that answer.
Jellybean
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Saturday, November 1, 2008 12:00 PM
 Other than programming the sounds into the QSI decoders, the SPROG is probably your best bet because it also functions as a low-power comamnd station - meaning you can program the settings into your decoder and then test them right there, no back and forth between the layout and program track. The various programmers from the sound decoder manufacturers can program standard CVs on all decoders, but can only load sounds for their brand - so if you have QSI, Loksound, and Digitrax soudn decoders and want to change the sounds, and not just program stuff like lights, consisting, and momentum, you'd need each of their programmers.
                          --Randy
  • Member since
    December 2001
  • 1,932 posts
Posted by Stevert on Saturday, November 1, 2008 3:27 PM
rrinker
                          --Randy
  The Digitrax PR3 is also an option.  It is supported by JMRI, it can program any decoder's CV's, and when used as a CV programmer it operates stand-alone (that is, it doesn't need a Digitrax or any other command station).  For this type of use, you would configure it in JMRI as a stand-alone programmer and simply ignore the fact it can be configured differently to talk to a LocoNet.
   Also, from what I understand, it puts enough current that sound decoders aren't a problem for it.  Mine works fine programming CV's on QSI decoders, but unfortunately I don't have any Locsound or Soundtraxx decoders to try it with.
Steve
  • Member since
    January 2007
  • 551 posts
Posted by corsair7 on Sunday, November 2, 2008 12:31 PM
Of course I ordered a power supply for it.
Irv
  • Member since
    July 2006
  • 35 posts
Posted by jellybean on Thursday, November 6, 2008 4:54 PM
Well I went with Steves suggestion and ordered and received the PR3. I'm going to wait until Saturday to do the install.
Thanks again Steve!!!!
                                                Jellybean
  • Member since
    July 2006
  • 11 posts
Posted by Harris Creek Central on Thursday, November 6, 2008 5:12 PM
Hi Irv:
I think I would be looking for an older PC that is running Windows XP.  I don't know about your area but I think I could most likely find one for FREE up here where I am..  That way you would have a designated computer for your railway..
 Just my thoughts on the subject.
Harvey:
Harris Creek Central http://www.freewebs.com/harriscreekcentral/
  • Member since
    January 2001
  • 6,847 posts
Posted by jrbernier on Thursday, November 6, 2008 6:09 PM
Irv,
  What PS are your ordering and for what?  The current 'Locobuffer USB' does not need a power supply.  The older 'Locobuffer II' has a serial interface and comes with a 'wall wart' power supply.  I put a 'serial to USB' converter cable on it and gave mine to the club(with my 'old' train computer).  My new train computer has the "Locobuffer USB' unit.  USB to the computer and Loconet cable to my Digitrax system.
Jim
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Thursday, November 6, 2008 6:49 PM
 He's getting a PR3 - it needs a power supply to function as a standalone programmer. It does NOT need a power supply to be simply a loconet to USB interface.
                      --Randy
  • Member since
    April 2003
  • 305,205 posts
Posted by Anonymous on Thursday, November 6, 2008 7:40 PM
Absobloodylutely the best thing you can ever learn to use for your locos.
  • Member since
    December 2001
  • 1,932 posts
Posted by Stevert on Thursday, November 6, 2008 8:31 PM
jellybean
                                                Jellybean
  I'm glad you liked the recommendation, and I hope you end up liking the PR3 as much as I do.  It's a pretty neat little gadget.  A couple things to keep in mind:
  1. As already mentioned in this thread, that you will need a power supply to use it as a stand-alone programmer, but not if you're going to use it to connect to the LocoNet.
  2. You will need to install the USB drivers for it (included with the PR3) before you can use it with any software.
  3. If you're going to use JMRI with it, and you haven't used JMRI before, I suggest that you read the installation process for your computer type before you start.  Then go through JMRI's PR3 instructions here:  http://jmri.sourceforge.net/help/en/html/hardware/loconet/PR3.shtml  They briefly mention setting the preferences to the correct COM port it gets assigned to.  This is important!
Have fun and enjoy!
Steve
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
