Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Kato NW-2 (HO)
  • Member since
    January 2008
  • 595 posts
Kato NW-2 (HO)
Posted by mreagant on Wednesday, October 8, 2008 10:15 PM
I have a new-in-box Kato NW-2 that is several years old (c. 2000?).  I don't think it has a plug n' play.  I think I read that it was difficult to install a decoder in these switchers.  Anybody have experience with them or know something about possible problems with an installation?
Mike
  • Member since
    November 2005
  • 823 posts
Posted by garya on Wednesday, October 8, 2008 10:53 PM
I've done one, and it's not easy. See http://www.tcsdcc.com/decoderpics/Kato%20NW2/kato_nw2_m1.htm
Take your time, and it will work. I didn't grind off the mounting pins, but I did most off what this installation says.
I used a Lenz Gold Mini, and it runs GREAT.
Unfortunately, my cat knocked it off the workbench, and it broke a coupler pocket, which you can't get anymore.
Gary
  • Member since
    January 2002
  • 659 posts
Posted by ericboone on Thursday, October 9, 2008 12:09 AM
I have a pair.  I had to mill a pocket in the top of the frame to make room for the decoder.  If you have access to a mill, then it really is pretty easy.  If not, well I suppose if you're really cautious and take your time you could do something with an end mill in a Dremel tool.
  • Member since
    July 2003
  • 13,757 posts
Posted by cacole on Thursday, October 9, 2008 10:02 AM
I have 4 of those models, and they are some of the quietest and smoothest running switchers I own.  They are not DCC ready and there is no room anywhere for a decoder short of milling out a cavity in the top of the weight.  I used Lenz LE077FX decoders, which were the only ones available at the time that were small enough.  The Lenz decoder has a different number now.  A TCS M-1 decoder is about the same size, and there may now be other dime-sized decoders on the market.
  • Member since
    January 2008
  • 167 posts
Posted by AlreadyInUse on Friday, October 10, 2008 9:03 AM
I milled a pocket in the fuel tank for a Digitrax DZ143. I also milled channels to run the lighting wires. I used a Dremel tungston bit in a Dremel drill press. It took 3 evenings of very careful work, but the result was well worth it. The Kato NW-2 is an outstanding switcher.
I found the link mentioned above very helpful. Note: getting the shell off is very difficult. I followed instructions that I found at the Kato web site. Take your time; it'll be worth it.
You can never have too much glue
  • Member since
    December 2005
  • 505 posts
Posted by jim22 on Friday, October 10, 2008 1:10 PM
I chickened-out several times before I actually did the install, but here it is.  It was well worth it.  Too bad it's not sound, but that may have been impossible....
 http://members.cox.net/craneji22/Kato_NW2_Decoder_Install.html
Jim
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
