Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Using a Wye for a Reverse Loop
  • Member since
    February 2007
  • 1,842 posts
Posted by superbe on Friday, March 28, 2008 7:09 AM
Here is a simplified description of my over all track layout. It is a double track main with double cross overs. In order to reverse directions I want to know if I could use a 2 way Wye with the track going to both sides of the end of a loop. If you take the right side of rhe Wye the train would run counter clockwise and if you took the left it would run clockwise. .
Does this make any sense and will this work? Any thoughts on this will be greatly appreciated.
Bob
  • Member since
    February 2005
  • 7,982 posts
Posted by pcarrell on Friday, March 28, 2008 8:47 AM
Do you mean something like this?
If so, sure, you can do it.  You just have to do some wiring to the loop part to flip the polarity of the rails so you don't get a short, and if you're in DCC you can get an autoreverser that will do it for you.
Philip
  • Member since
    February 2007
  • 1,842 posts
Posted by superbe on Friday, March 28, 2008 9:39 AM
Hi Phillip,
 I started to lay a conventioal loop at one end of the layout, but wanted to be able to reverse direction both ways which would mean another reverse loop. This is going to eat up a lot of real estate so I thought by using the Wye it would eliminate an extra loop.
Also shouild I have posted this in the wiring section?
Bob
  • Member since
    February 2007
  • 1,842 posts
Posted by superbe on Friday, March 28, 2008 9:42 AM
Phillip,
You figured it out exactly.
Thanks for you help.
Bob
  • Member since
    February 2005
  • 7,982 posts
Posted by pcarrell on Friday, March 28, 2008 9:51 AM
Yeah, it's definately doable.  You just need something to flip the polarity of the rails for you.  You see, as the tracks go around the loop they turn back on themselves, but now the inside rail becomes the outside rail, and vice versa.  Since the polarities are different you'll have a short circuit there if you don't change the polarity if the exit rails from the loop area.  There are lots of ways to do this.
Are you using DC, or DCC?
Philip
  • Member since
    April 2003
  • 5,440 posts
Posted by markpierce on Friday, March 28, 2008 10:52 AM
The tail of the wye will determine the maximum train length unless you first take apart and then reassemble the train.
Mark
  • Member since
    February 2007
  • 1,842 posts
Posted by superbe on Friday, March 28, 2008 11:09 AM
Yes, I'm using DCC and have a reverser from Tony's Train Exchange but haven't hooked it up. I alternate working on the wiring underneath the layout with working on top laying track.
The next step will be to redo the track and install the Wye.
 Patience is truly a virtue.
Bob
  • Member since
    February 2007
  • 1,842 posts
Posted by superbe on Friday, March 28, 2008 11:16 AM
Hey Mark,
Check my drawing. After going through the wye the train will switch to the inner main line. Will this should solve the length problem.
Bob
  • Member since
    November 2005
  • 4,000 posts
Posted by jecorbett on Friday, March 28, 2008 1:36 PM
I solved the real estate problem by stacking the loops. You get two loops in little more than the space required for one. Each loop of course has it's own lead tracks on opposite sides of the loops, but the balloon tracks themselves take up no more real estate than a single loop. To do this of course, your mainline would have to rise from one loop to the other a minimum of 4 inches (assuming HO).
On my previous layout, I used a little bit different approach. My balloon staging yard was in an adjacent room and both ends of the mainline fed into the same loop, with a double slip turnout at the throat. A double crossover would work as well but would require a little more length. With this arrangement, trains could enter the loop from either end of the main. All trains would travel around the loop in a counter clockwise direction and could re-enter either end of the mainline depending on how the double slip was set.
For me, wyes are a good solution for turning the locomotive, but I see problems using them to turn the whole train. For one you would need two tail tracks that can accomodate an entire train length and that can eat up an enormous amount of real estate as well. Second, you would have to back the train up through one leg of the wye and depending on train length could cause problems with derailing. I would give this some thought before settling on a wye.
  • Member since
    February 2007
  • 1,842 posts
Posted by superbe on Friday, March 28, 2008 4:50 PM
Thanks for the idea but I don't have the space for a 4" rise. I'm afraid I have a Champaigne appetite bur a beer budget. I may be trying to do too much in too small a space.
Bob
  • Member since
    January 2004
  • 483 posts
Posted by cordon on Saturday, March 29, 2008 1:32 AM
Smile [:)]
I think the wye will require more real estate than a reversing crossover from main to main.  The "dotted" lines in the diagram above will have a reverse curve sufficient for the tail track to be parallel with your straight mains.  You will need two of them, making the distance from main to main twice what you'd need for a reversing crossover.
Smile [:)]   Smile [:)]
  • Member since
    February 2007
  • 1,842 posts
Posted by superbe on Saturday, March 29, 2008 7:56 AM
Hi Cordon,
You're right. Last night I placed the track as planned on top of the layout and I ended up with just one true reverse loop. Getting to the stem from both directions just isn't practical particulary with my space limitations.
As you can probably tell I'm adlibing my track plan but in trying this I did end up with improvements to the over all layout.  I'm going back to regular reversing loops. This is the fun part in building the layout for me.
Thanks,
Bob
  • Member since
    March 2008
  • 5 posts
Posted by blueridgehobo on Saturday, March 29, 2008 12:07 PM
If I understand your question correctly, one wye any place you want to put it is sufficient.  However, if you want to run more than one train simultaneously, or always travel forward, and be able to change directions from any direction you will need at least two wyes, and maybe more.  The critical issue here is building in sufficient blocks to handle the degree of complexity you choose, and having polarity reversing ability at every wye.  With the double crossovers, a wye need be placed at only one direction, clockwise or counterwise, the locomotive's direction being changed at whatever time it is travelling in the direction having the wye.
  • Member since
    February 2007
  • 1,842 posts
Posted by superbe on Saturday, March 29, 2008 5:36 PM
 Yes your post covers what I had in mind. Thanks for your comments. They add to and comfirm other advice. I had not realized the complexity of what I am trying to do both in theory and in actually laying the track to fit the situation. Maybe way too much for a newbe.
I've got to walk away from this for a while.
Thanks again,
Bob
  • Member since
    January 2010
  • 7 posts
Posted by Jack Herer on Thursday, January 14, 2010 2:41 PM
pcarrell
please post more on the ways on how to switch the polarity , i am trying a simple reverse loop with a wye connector,  like the drawing of the hangman's noose above.
i came upon a short circuit, then i seen the rails when back on themselves. i quickly disconnected and started my research
im also using DC only
i have some isolating connectors on order, they might take awhile, i live 400 miles from the store i had to order from.
do i isolate the wye connector from the rest of the rail?
how is the proper way to wire the loop?
thanks
jack
Jack Herer
  • Member since
    May 2005
  • 1,496 posts
Posted by tgindy on Thursday, January 14, 2010 10:14 PM
A wye means a tad more hands-on operation than the reverse loop -- especially with a DCC auto-reverser.  This may have a bearing on your Givens & Druthers assuming either choice is doable.  So, which style suits your operations-preference?
Conemaugh Road & Traction circa 1956
  • Member since
    February 2009
  • 935 posts
Posted by Doc in CT on Friday, January 15, 2010 7:04 AM
tgindy
Why so?  It's a turnout with two curved segments rather that a straight segment and a curved segment?
Co-owner of the proposed CT River Valley RR (HO scale) http://home.comcast.net/~docinct/CTRiverValleyRR/
  • Member since
    November 2006
  • 1,484 posts
Posted by Paulus Jas on Friday, January 15, 2010 11:07 AM
hi Jack,
For proper wiring buy a book. It's very easy to explain with a good picture; a good picture tells more then a million words.
http://www.kalmbachstore.com/12412.html
Hi Bob,
the biggest problem with a wye is to find a place for it with a long enough tailtrack. When you have a double track oval the two entrances to the wye will become busy places. If you even need (not want) to install signals depends on the number of trains that will be running at the same time. With two operators it will be doable to keep an eye on the other; with more operators at the same time the result will be a predictable head-on.
Paul
  • Member since
    February 2007
  • 1,842 posts
Posted by superbe on Friday, January 15, 2010 11:38 AM
superbe
Hi All,
Since my 2008 thread has been reopened, I thought I'd report the happy ending to my inquiries. Using wyes in my case took up too much space so I created a track pattern inside the circular main in the form of an X using turnouts and a 90 degree cross over. That gave me the two reverse loops.
With lots of good help from the forum I wired it using two PSX-AR reversing modules from Tony's Train Exchange. I'm using DCC.
They work like a charm.
Bob
  • Member since
    November 2006
  • 1,484 posts
Posted by Paulus Jas on Friday, January 15, 2010 12:04 PM
Hi Bob,
 I didn't noticed your thread from March 2008 was hijacked by Jack.
Paul
  • Member since
    May 2005
  • 1,496 posts
Posted by tgindy on Friday, January 15, 2010 12:16 PM
Doc in CT
[Why so?  It's a turnout with two curved segments rather that a straight segment and a curved segment?
While either method turns trains -- there are more turnouts in a wye.
  • Member since
    February 2009
  • 935 posts
Posted by Doc in CT on Friday, January 15, 2010 12:31 PM
 Oh
So we are talking about a Y  as opposed to a Wye turnout.  Bit more annoying for proper DCC operation.
  • Member since
    February 2009
  • 935 posts
Posted by Doc in CT on Friday, January 15, 2010 2:46 PM
I think this is what it should look like (I planning on moving the gaps away from the turnout to give the rails time to move).
reversing loop DCC
  • Member since
    February 2005
  • 23,330 posts
Posted by selector on Friday, January 15, 2010 4:12 PM
Jack, your wye turnout is wired and joined normally to the oncoming main line that then goes on to form the loop via the turnout.  It is at the two split routes of the turnout that you place gaps.  Use insulating plastic joiners if you wish.  Some guys, like myself, don't like how they look, so we leave a gap and fill it with some styrene left over from a model kit.  Glue it in place and file it to look a lot like it belongs.  That means four such gaps.
So, you now have a layout complete, including power feeders up to the two routes on that wye turnout.  You have the loop rails in place and gapped right at the place where each end meets the wye turnout.
Now you must wire those dead rails, and you do it the same way as the rest of the layout EXCEPT that there must be a double-pole double-throw (DPDT) toggle switch wired in series somewhere cut into that pair of feeders.  There are diagrams on the net showing how to wire a DPDT to reverse polarity.  But you must feed that loop.  It's just that you need to be able to flip that toggle once the train enters the loop and the last metal axle clears the gap.  From there, you know you can safely cross the gap at the far end.
-Crandell
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
