Toy train operating and collecting
Interested in O gauge, S gauge, and Standard gauge toy trains? Are you a fan of Lionel, MTH, American Flyer, and other brands of toy trains made today and in the past? If so, the Classic Toy Trains Toy train operating and collecting forum is just for you. If you're new here, please read our forum policies.
Last post 02-24-2008 4:29 PM by jmsiv. 21 replies.
Rate:
Sort Posts:
kehoesj
Joined on
02-25-2001
MP53 - CNW Pennisula 400
Dust control on layouts - anyone have this?
I was wondering if anyone out there has the Micro model vacuum cleaner (runs off of 9V battery, or adapter) that was advertised a few issues back in CTT - does this really work to collect dust ? Price on this was around $17 on sale.
ChiefEagles
Joined on
02-03-2004
Rolesville, NC
Re: Dust control on layouts - anyone have this?
Can't tell you about that one. I have found that the Ionic Breeze air purifier helps a lot. Have on in the my train room. Have one down stairs in livingroom. It cut down on dust on furniture. WhenI build layout upstairs, added one in there. Works great and cuts down on dust a lot. Little expensive but really helps.
sir james I
Joined on
04-24-2007
MICH
I have one I bought years ago from them, I found it to be close to useless. Others may think otherwise. the little brush just moves the dust around to a different spot.
jmsiv
Joined on
12-21-2005
NJ
the ionic air cleaner (electroststic) air cleaners are the best at removing microscopic particles from the air. I have one built in to my FHA heating system, keeps the whole house pretty much dust free. a vacuum of any size depends on filtration and the filter you would need to collect the fine particles instead of just blowing them somewhere else are expensive. they are called HEPA rated. I have them on my shop vacs. they are about $30 each. they are cleanable and washable, made of gortex. you only have to buy it once so in the long run they are probably cheaper.
Buckeye Riveter
Joined on
03-08-2004
Roger's Corners, OHIO
I have a small Dirt Devel with a brush. If something is loose it sucks it right up, but I can find it if I need to. Oops..there goes a plastic pig!
Blueberryhill RR
Joined on
10-11-2004
S.E. Ohio
I have a 2 inch cosmetic brush that is very soft. As the train comes by, slowly, I just give it a quick dusting.
alexweiihman
Joined on
09-18-2006
south east PA
Im to cheap to buy anything, besides some cheap soft paint brushes.
dbaker48
Joined on
12-20-2005
Sunny So. Cal.
ChiefEagles wrote: | | Can't tell you about that one. I have found that the Ionic Breeze air purifier helps a lot. Have on in the my train room. Have one down stairs in livingroom. It cut down on dust on furniture. WhenI build layout upstairs, added one in there. Works great and cuts down on dust a lot. Little expensive but really helps. |
We got one of those also, as you said sure ain't cheap !! Then about 6 months ago the state of California being what it is, has passed legislation making them illegal !!! It appears the amount of O-Zone that they create is toxic. (Especially if you plan on living 250 to 300 years, I'm more concerned about global warming, so we use ours in the train room.) It is also quite effective with smoke removal, however don't want to turn it up to high, you can get a head ache.
ChiefEagles
Joined on
02-03-2004
Rolesville, NC
dbaker48 wrote: | ChiefEagles wrote: | | Can't tell you about that one. I have found that the Ionic Breeze air purifier helps a lot. Have on in the my train room. Have one down stairs in livingroom. It cut down on dust on furniture. WhenI build layout upstairs, added one in there. Works great and cuts down on dust a lot. Little expensive but really helps. |
We got one of those also, as you said sure ain't cheap !! Then about 6 months ago the state of California being what it is, has passed legislation making them illegal !!! It appears the amount of O-Zone that they create is toxic. (Especially if you plan on living 250 to 300 years, I'm more concerned about global warming, so we use ours in the train room.) It is also quite effective with smoke removal, however don't want to turn it up to high, you can get a head ache. |
Both of mine stay on high. HUMMM BTW: no fan in them but if you get close, you can feel the air moving through it. I'd have more of them if they were not so high $$$. Hey, a new trade for me. Smuggling them into CA. ![Whistling [:-^]](/trccs/emoticons/icon_smile_whistling.gif)
traindaddy1
Joined on
01-05-2006
Northeast Bronx
Blueberryhill RR wrote: | | I have a 2 inch cosmetic brush that is very soft. As the train comes by, slowly, I just give it a quick dusting. |
I use this same method along with the "Big Bad Wolf" method* ie* I huff and puff and blow the dust away. Side Note: Dust is a major problem around here with on-going street and building construction. When not running the trains, I have a very light weight clear painters' plastic sheet covering the layout. It is really a 'pain' to remove and recover but it does cut down on the dust....A previous post on the same subject (not sure it was this forum) mentioned that "dust" added character and authenticity to the layout....In my house, it is just "dust".
Jumijo
Joined on
01-10-2005
New England
I use 2 soft make up brushes to clean off dust. A larger one for dusting structures, and a smaller one for dusting vehicles and applying blush. The problem with brushing the dust is that all that's been accomplished is the dust has been moved, not removed. A vacuum is the only way to really remove the dust. Dust may not seem all that noticable on your layout, but it does dull and mute the colors. I've noticed this to be true with the autumn foliage trees we have on our layout. Jim
kehoesj
Joined on
02-25-2001
Yes, Jim, moving the dust around is not desired. My layout dates back to around 1988 and you can imagine about 20 years of potential dust mounting up - but I haven't turned the layout to a winter scene because of it! I periodically use a very soft "cosmetic" brush on the vehicles, buildings and such, but I sure would like to remove the accumulation on the scenery. I think the dust has gone past just being a part of the scenery to a need to get rid of it. I've often thought about using a hair dryer, blowing it upward and then sucking it while drifting about the atmosphere with a shop vac. The trouble is that most of my scenery is just layed down, without the benefit of adhesion. I don't want to blow everything or it will look like a huge nor'easter came through Lionelville.
ChiefEagles
Joined on
02-03-2004
Rolesville, NC
One thing, never seen a real clean engine and rolling stock. So, some dust is protypical.
traindaddy1
Joined on
01-05-2006
Northeast Bronx
traindaddy1 wrote: | Blueberryhill RR wrote: | | I have a 2 inch cosmetic brush that is very soft. As the train comes by, slowly, I just give it a quick dusting. |
I use this same method along with the "Big Bad Wolf" method* ie* I huff and puff and blow the dust away. Side Note: Dust is a major problem around here with on-going street and building construction. When not running the trains, I have a very light weight clear painters' plastic sheet covering the layout. It is really a 'pain' to remove and recover but it does cut down on the dust....A previous post on the same subject (not sure it was this forum) mentioned that "dust" added character and authenticity to the layout....In my house, it is just "dust". |
JUST IN......So much for my dust cover.....Have been boarding my daughters' cats for a few days. Came into the train room and out came a "flying" feline. She got on to the layout under the dust cover and rearranged almost everything. Looks as though a tornado hit. Thank goodness that I have a 3" border around the layout that kept the trains from dropping off. (I guess that I'll live with the dust!)
ChiefEagles
Joined on
02-03-2004
Rolesville, NC
Get our free monthly newsletter delivered to your inbox
