General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 03-05-2008 5:56 PM by Mike B. 36 replies.
Rate:
Sort Posts:
NevinW
Joined on
01-09-2001
Nevada
Painting the fascia and valence
I am soliciting opinions about the best color to paint a fascia and valence. Wood paneling is clearly out of favor. Some people are painting it the same color as the basic scenery, i.e. tan for desert, green for an eastern layout. Others are advocating flat black. What is everyones opinion? - Nevin
chutton01
Joined on
12-24-2001
Re: Painting the fascia and valence
I vote for a somewhat dark shade of brown/tan simply to represent dirt/rock supporting the landscape above (in mountain or other areas with,say granite underlayment, use dark grey - make sure to feather in colors between areas) - no root details or underground creeks or whatever (unless you're really into that), just plain brown/grey/tan etc. (and if you have a curtain/skirt that reaches the floor, dye the bottom a neon red/orage to represent hot molten magma - OK, so that's the ultimate vertical selective compression, but it's still a fun idea)
jacon12
Joined on
11-13-2002
US
I haven't done my facia yet but I think I'm going to go with a dark green. I model the southeastern U.S. and it fits best imho. JaRRell
joe-daddy
Joined on
07-14-2006
Colorado
Interesting topic, My choice is a flat, darker green, not quite OD, but close and I am using black plastic sheeting as the curtain. I've read and thought about this quite abit and rather like the shadow box effect that darker colors create. My original thinking did not include a valence, as I use track lights, but I'm certainly going to put up a temporary valence probably the same color as the facia to see if I get the shadow box effect others talk about. Joe
Mark R.
Joined on
04-25-2004
I went with the museum look myself. My valence and facia are painted satin black as is the drywalled ceiling above the aisle-way. Everything below the bench-work is painted a dark hunter green. The ceiling above the layout itself (behind the valence) is painted the same sky blue as the back-drop, as is the back of the valence ....
Mark.
Dave Vollmer
Joined on
11-26-2003
Bellevue, NE
Flat black for me. I find it makes the green foliage look that much greener and really helps focus the viewer on the layout and not the fascia.
jfugate
Joined on
01-05-2002
Portland, OR
Mark R. wrote: | I went with the museum look myself. My valence and facia are painted satin black as is the drywalled ceiling above the aisle-way. Everything below the bench-work is painted a dark hunter green. The ceiling above the layout itself (behind the valence) is painted the same sky blue as the back-drop, as is the back of the valence ....
Mark. |
Likewise on my HO Siskiyou Line.  (Click image to enlarge)
I use a dark hunter green for the fascia, black for the valance and skirting. I leave the ceiling white, but the aisles don't have any lighting -- only the layout, so the emphasis is on the layout, and you can see in the above photo. I like the museum-shadowbox look. I think it's very attractive and it focuses attention on the layout, as it should.
reklein
Joined on
07-22-2004
Lewiston ID
I like the museum look too but I don't care for the stark black so I go with a nuetral color ,dark beige.
nbrodar
Joined on
06-20-2005
Phoenixville, PA
I use a medium to dark green fascia, with charcoal gray/black skirting.
Nick
tomikawaTT
Joined on
02-12-2005
Southwest US
I personally favor unpainted Masonite(r) for my fascia panels, for several reasons: - My fascia is made up of small panels which will be removed frequently for construction, maintenance and troubleshooting. I would expect any painted finish to start looking pretty sad in fairly short order.
- I am terminally lazy.
- Solid color painted surfaces will show grubby paw prints a lot more than will unfinished Masonite.
Valence panels, which will only be installed once and then left alone, will look best if flat black. My , other opinions may differ. Chuck (modeling Central Japan in Septembeer, 1964)
cwclark
Joined on
01-30-2004
Crosby, Texas
I like satin black fascia. The layout looks good with satin black paint fascia because it puts ones focus on the layout and a gallon of black latex paint from Walmart is cheap so that railroad funding is spent on more important stuff like rolling stock, locomotives, and scenery items.
bogp40
Joined on
07-28-2004
Weymouth, Ma.
My club decided to use a green. Of the 60 members, there were various reasons for the choice with blending with our NE scenery and the look with the layout in such a well lighted large space. I imagine that if we modeled Southwestern or desert a tan to brown would have been the pick.
I really like that shadow box / museum look. Nice work.
fifedog
Joined on
04-06-2006
Try this: Get three 4' strips of scrap fascia. Paint each strip a separate color. Temporarily "tack" a different fascia up and leave it up for a couple days. The one that looks best to you, go with. BTW, I went with left-over sheets of white ice paneling...but then again, I model snow...
joe-daddy
Joined on
07-14-2006
Colorado
Hmmm, I wonder where I got the idea I wanted shadow box? Mr. Fugate, your DVDs are wonderful! another Joe, Joe Daddy jfugate wrote: | Likewise on my HO Siskiyou Line.  (Click image to enlarge)
I use a dark hunter green for the fascia, black for the valance and skirting. I leave the ceiling white, but the aisles don't have any lighting -- only the layout, so the emphasis is on the layout, and you can see in the above photo. I like the museum-shadowbox look. I think it's very attractive and it focuses attention on the layout, as it should. |
Chuck Geiger
Joined on
07-14-2006
Fresno, CA
Flat Black:
