General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 12-09-2007 4:35 AM by SilverSpike. 29 replies.
Rate:
Sort Posts:
Page 1 of 2 (30 items) 1 2 Next >
07-06-2007 11:32 PM
Offline SilverSpike
Top 150 Contributor
Joined on 08-11-2002
Wake Forest, NC
Posts 2,878
Roundtable and Roundhouse Renovations - Update!
Roundhouse and track alignment
Updated some work on my roundhouse and roundtable renovation project this past weekend. Here are a few pics from the work crew.
Alignment check and test with roundhouse on cork foundation layer and track alignment:
NMRA gauge check on inspection pit track alignment:
Roundhouse interior track alignment check:
Sheet styrene (.030) cut and fitting check:
Roundtable weathering
Adding some iron paint to the rail flange:
Some rusting due to rails on the turhtable tray side walls:
  Posted on July 07, 2007
I started work on my Stewart Industries HO Yard Servicing Facility Work Pit. (Cat. N. 213)
The Box (Click image for larger view)
I filed down the metal castings first to get them cleaned up a bit. Then I cemented the metal casting sides together with Goo and now they are drying in my magnetic gluing jig. I have six of these kits that will eventually make it into the bottom foundation of my 6-stall roundhouse.
Contents (Click image for larger view)
This is my first time working on a metal castings kit of this kind, so my learning curve is on the high upswing. The sides and ends of the pit are all metal castings as are the two ladders, the floor is wood, and there are two HO scale code 100 track sections for each side of the pit.
Filing (Click image for larger view)
Applying cement (Click image for larger view)
Setting the pieces (Click image for larger view)
I have a taken these few photos and I will post more of them as I progress through the first kit, taking notes too for future reference.
Any other tips or tricks with working with metal castings would be great!
07-11-2007 3:06 PM In reply to
Offline Heartland Division CB&Q
Top 150 Contributor
Joined on 01-25-2007
Kentucky
Posts 2,681
Re: Yard Service Facility Work Pit
So far.......So good!
Thanks for sharing this project.
07-11-2007 9:18 PM In reply to
Offline last mountain & eastern hogger
Not Ranked
Joined on 08-11-2006
Saskatchewan
Posts 548
Pirate [oX)]
Ahyyy,
Is that paint or blood on that tray.
You will have a great looking engine facility.  Keep up the good work.
James:1 Verse:5
The "wobbly" lives on..................................
Johnboy out...........
07-16-2007 7:18 PM In reply to
Offline SilverSpike
Top 150 Contributor
Wake Forest, NC
Posts 2,878
Johnboy,
You know....I have cut myself a few times while working on the layout, but mostly with benchwork construction. Actually, that is a paint spill on the magnetic jig, and I think it was from a jar of boxcar red.
Also, I have continued to update this thread topic on my own web site pages, you can find it in the Modeling Techniques page linked under the Structures heading.
http://piedmontdivision.rymocs.com/
Cheers,
Ryan
09-18-2007 1:40 PM In reply to
Offline SilverSpike
Top 150 Contributor
Wake Forest, NC
Posts 2,878
Roundhouse and roundtable renovations Updated!
To follow the complete story check out the Roundhouse Renovations web page on my Piedmont Division web site.
09-18-2007 2:07 PM In reply to
Offline loathar
Top 10 Contributor
Joined on 08-05-2004
Amish country Tenn.
Posts 9,979
Re: Roundhouse and roundtable renovations Updated!
Roundtable? Ya building King Arthur's railroad?Big Smile [:D]
09-18-2007 2:30 PM In reply to
Offline SilverSpike
Top 150 Contributor
Wake Forest, NC
Posts 2,878
No plans as of yet to add the "Knights" but that would be funny if I had one of them sporting a lonely steed and in full dress guarding the property!
09-18-2007 2:34 PM In reply to
Offline selector
Top 10 Contributor
Joined on 02-06-2005
Vancouver Island, BC
Posts 14,809
Ryan, very intersting and it looks good.  The only question I have is about the height of the styrene between those two bay tracks.  I take it that you have made it somewhat less than the tread on the rail tops?
-Crandell
09-18-2007 2:47 PM In reply to
Offline SilverSpike
Top 150 Contributor
Wake Forest, NC
Posts 2,878
-Crandell
Good question Crandell!
I am using the Evergreen .030 sheet styrene for the final concrete floor between the bay tracks. And I find that the top of the styrene is just below the top rail height, I don't have an exact measurement, but I do want one of those nice digital measuring calipers eventually.
I got this idea from the October 2007 MR issue and the "Scenery Step by Step" article by Jim Hediger and Cody Grivno  Detail and weather an engine shop, p. 38-41. I might say that it was another one of those just in time MR articles
09-18-2007 3:42 PM In reply to
Offline selector
Top 10 Contributor
Posts 14,809
It was just that, the way the image shows it to me, the styrene is clearly very close to the two rails at each extremity, and that would make its overall height quite important to ensure pilots, MU hoses, even our somewhat wider than true scale wheels don't get lifted or snagged by the styrene.  I used plaster at the outer edge of my bays because my setup requires the house to be set back from the pit ledge by about 2"...so I needed a "concrete" apron of sorts to keep the gap from looking goofy.  I found that I overestimated the clearances of locomotive parts by quite a long shot, and had to do a lot of sanding and cleaning out of the flange paths inside the flextrack to keep things moving and making contact with the powered rails all the way into the bays.
Live and learn.
-Crandell
09-18-2007 4:15 PM In reply to
Offline wjstix
Top 50 Contributor
Joined on 02-14-2002
Mpls/St.Paul
Posts 5,634
So the difference between a turntable and a roundtable is like the difference between day and knight??
Laugh [(-D]
09-18-2007 4:24 PM In reply to
Offline selector
Top 10 Contributor
Posts 14,809
One's a rotundra, the other a turnroundra.
09-18-2007 4:25 PM In reply to
Offline GraniteRailroader
Not Ranked
Joined on 11-28-2006
Northeast
Posts 566
Laugh [(-D]
Omg.
Whistling [:-^]
09-18-2007 4:57 PM In reply to
Offline SilverSpike
Top 150 Contributor
Wake Forest, NC
Posts 2,878
Live and learn.
-Crandell
Thanks for the heads up! I have not cut the inside sheets as of yet, the one sheet that is showing is on the outside edge of the rails and should not present a problem. Being HO scale, the inside the rails sheet will be cut 9/16" wide to fit the area between the rails and should leave enough area or gap for the wheel flange(s) to clear. I will be working on this step this weekend and will provide an updated report on my findings.
Oh, and I like the sub-topic thread of humor that has taken a life of it's own! Big Smile [:D]
11-13-2007 1:54 PM In reply to
Offline SilverSpike
Top 150 Contributor
Wake Forest, NC
Posts 2,878
Re: Roundtable and Roundhouse Renovations - Update!
Finally got the concrete (styrene) flooring done this weekend for the roundhouse.
Measured, cut and attached the sheet styrene to the cork sheets between the rails and inside the rails:
Using latex caulk I attached the styrene sheets to the cork sheets:
Then spread out the latex caulk into a thin even consistency with a plastic card:
All the styrene sheets in place:
Then I scored expansion joints into the styrene and spaced a grid at every 1 1/2" and 1 3/4".
Then I preped the area for spraying painting with a 50:50 mixture of Floquil Concrete and Floquil Aged Concrete.
The final product after the paint dried:
And with the roundhouse positioned:
The next steps include filling in the gaps in front where the flooring meets the roundtable and then the details start getting added.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
