Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
stripping the small wires on decoders
  • Member since
    April 2004
  • 19 posts
Posted by Wayne Schauder on Friday, July 6, 2007 9:55 AM
Has anyone a sure fire way of stripping those small wires on decoders?  The strippers I have require too much clamping force on the unstripped part of the wire. This squashes the wire and sometimes pulls out a strand or two.  After a couple of tries I wind up with a too short a wire!  Thanks ....Wayne
  • Member since
    July 2003
  • 5,743 posts
Posted by simon1966 on Friday, July 6, 2007 10:24 AM
Sounds like you need a better wire stripper. If you are cutting wires then the hole is too small. If you have one that allows you to accurately set the opening for the wire it works like a charm on the finest of wires.
Simon Modelling CB&Q and Wabash See my slowly evolving layout on my picturetrail site http://www.picturetrail.com/simontrains and our videos at http://www.youtube.com/user/MrCrispybake?feature=mhum
  • Member since
    November 2006
  • 11 posts
Posted by Alroy66 on Friday, July 6, 2007 10:27 AM
Hi Wayne
I don't know if you got your answer yet but what I do is heat the end of the wire a little with my iron when it's hot. Just about 1/16" then use my finger to pull the insulation off. This usually gives me just enouph to solder and no missing strands of wire.
Al
You do not stop playing because you grow old; You grow old because you stop playing. Now, go play with some trains!!!
  • Member since
    October 2006
  • 8,571 posts
Posted by richg1998 on Friday, July 6, 2007 10:29 AM
I use Klein wire stripper model 11047 which is for #22 through #30 wire. Most of the time I use the slot for #28 wire. Make sure of the model as Klein sells two other nearly identical models for larger wire. Below is a link for the photo.
http://www.pricegrabber.com/p__Klein_Tools_Klein_Tools_11047_Flat_Design_Wire_Stripper_Cutter_for_22_30_AWG_Stranded_Wire,__18353925/search=klein+tools+11047
rich
If you ever fall over in public, pick yourself up and say “sorry it’s been a while since I inhabited a body.” And just walk away.
  • Member since
    September 2002
  • 7,486 posts
Posted by ndbprr on Friday, July 6, 2007 10:34 AM
Just pinch it between your thumbnail and your first finger.
  • Member since
    April 2004
  • 19 posts
Posted by Wayne Schauder on Friday, July 6, 2007 1:36 PM
Thanks for the answers folks!  My stripper is adjustable but does not seem to work on different colors as they seem to have more or less insulation depending on color!  The fingernail thing doesn't work for me.  I think my nails are too thick on the ends.  I didn't try the hot iron idea yet, but I will try it until I get the Klein stripper I ordered!  Thanks again......Wayne
  • Member since
    January 2004
  • 483 posts
Posted by cordon on Friday, July 6, 2007 1:39 PM
Smile [:)]
I use my teeth. The tongue and teeth are very sensitive and accurate.  With minimum practice you can get very repeatable results.
Smile [:)]  Smile [:)]
  • Member since
    January 2007
  • 180 posts
Posted by Otis on Friday, July 6, 2007 1:53 PM
Adjustable strippers are just not good.  Stands to reason....use a stripper hole size designed for the wire.  My regular wire strippers are good from gauge 20 to 30 and almost never miss a perfect cut.  Just get a good pair, go easy on the cutting action and pull the insulation off with you fingernails rather than the tool.
  • Member since
    July 2004
  • 5,199 posts
Posted by bogp40 on Friday, July 6, 2007 3:17 PM
rich
Although Klien is probably the best of that type of stripper, Ideal make a 16-26g stripper (red handle) for about 1/2 the price. I have used the larger yellow handle for so many years I can't remember when bought, for Romex and automotive use.  These strippers can be found at HD and Loews.
But as already mentioned, some very small, fragile wires are better stripped by pinching with your fingernails. Even just the slightest nick will break the wire/ strands.
Modeling B&O- Chessie  Bob K.  www.ssmrc.org
  • Member since
    August 2005
  • 88 posts
Posted by ctclibby on Saturday, July 7, 2007 6:58 AM
Well your mileage may vary on this...  Pinch the wire between your thumb and first or second finger, pull.  You will get good at it after a few tries.  I have never broken any wires doing it this way, and can get pretty close to 1/4 inch insulation removal!
Have fun!
Todd Hackett
 Libby, Montana 59923
 I take only pictures then leave footprints on railroad property that I know is not mine, although I treat it as such...
  • Member since
    June 2003
  • 429 posts
Posted by train18393 on Sunday, July 8, 2007 1:05 AM
Wayne,
Radio Shack has a little stripper that is inexpensive, and once you get it set it works quite well. You can mail order one from Micro Mark that appears to be easier to set the wire size on. Don't own one of those, I use the Radio Shack cheepie.
Paul
Dayton and Mad River RR
  • Member since
    April 2004
  • 19 posts
Posted by Wayne Schauder on Monday, July 9, 2007 1:45 PM
Hi rich, I got my Klein stripper this morning and I have to say that it works perfectly for me! My old stripper had "V" shaped cutters while the Klein has round cutters.  I think that the round shape makes it superior.  Thanks again for your advice!!  Wayne
  • Member since
    October 2006
  • 8,571 posts
Posted by richg1998 on Monday, July 9, 2007 6:30 PM
Your welcome Wayne. It is a little pricier but it does a very good job. I used a V type stripper for quite a few years but working with this small wire required a better tool. It is very repeatable. I also have the next larger size which is a great help with larger size wires on the layout. I have nicked wires a lot in the past. When you nick a solid core wire, the wire can break a lot easier with little bending.
No doubt some of you have a system that works for you and I have no problem with that.
  • Member since
    July 2006
  • 594 posts
Posted by Gandy Dancer on Tuesday, July 10, 2007 8:29 PM
I did that very successfully in grade school and junior high.  Then I realized how hard it was on my teeth and stopped doing it.
  • Member since
    October 2001
  • 242 posts
Posted by MRRSparky on Thursday, July 12, 2007 4:39 PM
I use my handy-dandy Exacto #11 blade to make a slight nick in the insulation on one side of the wire.  You can actually feel the blade just touch the wire inside - there is a definite different feel.  Then just pull the insulation off.  Works every time and doesn't damage the wire.
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
