General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 06-29-2007 5:44 AM by Philip. 4 replies.
Rate:
Sort Posts:
Page 1 of 1 (5 items)
06-28-2007 6:42 AM
Offline Philip
Not Ranked
Joined on 08-01-2006
Australia
Posts 13
Painting Brass Locomotives
What is the concensus of opinion- Is it necessary to prime brass before applying the colour coats when painting brass locos? I use floquil paints and have an Aztec airbrush.
Which primer is recommended?
Many thanks
Philip
06-28-2007 6:58 AM In reply to
Offline dti406
Not Ranked
Joined on 07-23-2006
Nordonia Hills, OH
Posts 362
Re: Painting Brass Locomotives
If using the Regular Floquil paint (Not Polly S) I would use either the Oxide or Gray Primer before painting with your color coats.
My new preference for painting brass is Scalecoat I, as it does not need a primer, it bakes on well and has a gloss finish which is great for decaling.
Rick
06-28-2007 8:45 AM In reply to
Offline doctorwayne
Top 200 Contributor
Joined on 01-04-2004
Posts 2,222
Most brass that isn't "factory painted", at least nowadays, has had a coat of clear lacquer or brass-coloured paint (sometimes both) applied.  This prevents the brass from tarnishing and also hides the solder used to assemble the model.  I've painted brass using Floquil's grey primer and also right on the factory finish, with no additional primer, both for Floquil and Scalecoat paints.
06-28-2007 8:57 AM In reply to
Offline Virginian
Top 500 Contributor
Joined on 05-07-2004
Ohio
Posts 1,619
If it has a very good smooth coat of laquer, clear or otherwise, I will paint right over it.  If I strip to bare brass, I do prime when using Floquil, us ually with Floquil gray.  More and more I find myself going to the Testors, Model Master, or Scalecoat II lines and no primer for everything.  I have been satisfied with the results.
06-29-2007 5:44 AM In reply to
Offline Philip
Not Ranked
Australia
Posts 13
Thank you all for your collective advice.
Cheers
Philip
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
