Idaho Trains wrote: |
| Here are a few more update images - I have the tunnel constructed now. I have more work to go, but any useful comments are welcome? Image 1 - framework covered by tape
You probably don't want to hear this, but you asked:
The tunnels are very toylike, and that's because they're isolated lumps. A prototype railroad, confronted by these cliffs, would likely go around them, not spend the money and time to bore through them.
Real hills or mountains generally blend into the surrounding terrain, and these look like they were simply plopped on top of it. You might fix the problem somewhat by making the existing hill shorter and then adding "more" of it inside the parallel curved track (so it looks like the cruve goes through a cut). Adding more downslope near the tunnel portals--not upslope, as you have now--will help it blend in, too.
And, yes, the sky is very dark.
