bb4884 wrote: |
| So today I was driving and almost broke my shocks at a crossing. There was construction there over 2 months ago, and they(meaning construction workers) raised the road about 3 inches. Hurts when going 40 MPH It has been this way the last two months. Is there any way I can contact someone to get it fixed? Edit: I forgot the RR, it is the BNSF. |
To be honest, you will have better luck in dealing with your municipality than you will with the railroad - it is the municipality that maintains the surface roads. We had a similar instance back in 2002, where the UP replaced an old asphalt crossing on Dobson Road here in Mesa with a concrete crossing. This raised the level of the crossing about 2" higher than the surface of the road, so the UP construction crew made asphalt ramps up and over the crossing. Unfortunately, this was not enough and if you drove over the track on Dobson at road speed, you'd come close to throwing your cars' alignment out. Enough complaints were filed that the City of Mesa regraded and repaved Dobson Road about 100 yards from either direction of the track. This solved the problem.
