General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 03-18-2007 1:59 AM by train18393. 8 replies.
Rate:
Sort Posts:
Page 1 of 1 (9 items)
03-17-2007 6:58 PM
Offline Trekkie
Not Ranked
Joined on 01-09-2007
Wake Forest, NC
Posts 109
Where do you find kapton tape?
I didn't think to ask when I picked up my decoders about the kapton tape. I read the instructions on Digitrax website and the way it was worded led me to believe that was included in the kit. By the time I got home my LHS I picked up my parts from is closed.
Was hoping to get my decoder in my new Kato Super Chief and at least make it go forwards and backwards a few times before next weekend and I have time to get out again (maybe)
Does any regular store carry that stuff? I tried searching Lowe's website and nothing comes up. Is kapton the type and there is a brand name I could find?
Thanks
03-17-2007 7:04 PM In reply to
Offline MisterBeasley
Top 10 Contributor
Joined on 12-02-2004
Bedford, MA, USA
Posts 9,132
Re: Where do you find kapton tape?
I googled it and it looks like overkill to me.  What are they using it for?  (FYI, it's a flavor of electrical tape with anti-static properties.)
I use generic plastic electrical tape.  I've installed quite a few Digitrax decoders with no problems.  Your results may differ.  I use shrink-wrap tubing for wire-to-wire connections.
03-17-2007 7:18 PM In reply to
Offline Trekkie
Not Ranked
Wake Forest, NC
Posts 109
The Instructions that I'm referring to here.
I'm not familiar with the insides of a locomotive, so forgive me I'm not using the right terminology probably
It's asking me to remove the pickup brass rails, and put the tape under it, and then put the rails back on. I'm guessing it's electrically isolating something that wasn't without the decoder. I'd read when I was investigating DCC that the motors needed to be electrically isolated so this must be how they do it.
03-17-2007 7:43 PM In reply to
Offline NS2591
Not Ranked
Joined on 06-25-2006
CN Flint Sub(Eastern Michigan)
Posts 511
The Kapton tape is the Yellow tape holding the decoder on the Styrofoam. I asked the same question at my N scale club a while back.
Offline tstage
Top 10 Contributor
Joined on 06-11-2003
Northeast OH
Posts 8,719
Tom,
You can pick some up at Litchfield Station.  I've used it to mount and insulate decoder installations and like the stuff.  The thin transparent tape is quite handy in certain situations.  Plain electrical tape works well, too.
Here's a more direct link to the Kapton tape page.  Hope that helps...
03-17-2007 7:57 PM In reply to
Offline rrinker
Top 25 Contributor
Joined on 02-14-2002
Reading, PA
Posts 7,584
 Kapton tape is the recommended tape for this because it is a lot thinner than black electrical tape, is a lot less messy, and is way stronger than other thin tapes like clear scotch tape. Thicker tape MAY work but it might also allow things to touch where they aren't supposed to since space is at a premium in an n-scale loco. As mentioned, the tape IS in the package. Doing double duty, that's all. If you want more you can get it from any of the numerous DCC suppliers.
                               --Randy
03-17-2007 8:28 PM In reply to
Offline Trekkie
Not Ranked
Wake Forest, NC
Posts 109
If it's in the packaging, it's invisible. They must have recently changed their packaging. The decoders came in a baggie with the instructions, and that's it. I flipped through each page, and found no tape anywhere.
03-17-2007 11:35 PM In reply to
Offline nfmisso
Top 100 Contributor
Joined on 12-28-2001
San Jose, California
Posts 3,032
Kapton® tape is made from polyimide film, it is used to make flexible circuits used in disk drives and many other applications.  It is yellowish-brownish in color.
The reason to use it for insulating decoders is that it is thin and very very abrasion resistant.  The vibrations in a model will wear through most thin materials relatively quickly, resulting in a smoked decoder, but not Kapton®.  Kapton® is made by DuPont.
See alse:
http://www2.dupont.com/Kapton/en_US/index.html
http://www.kaptontape.com/
http://www.uline.com/Browse_Listing_6407.asp?pricode=WE491
Uline has locations in many cities.
03-18-2007 1:59 AM In reply to
Offline train18393
Not Ranked
Joined on 06-29-2003
US
Posts 223
nfmiso said it well. It also seems to be quite puncture proof. Those sharp little points that result when soldering the PC board componants and cutting off excess leads poke through normal electrical tape, scotch tape and others quite easily, especially with a little pressure and vibration. The Kapton tape seems to prevent this from happening. I bought a couple of feet, as it is inexpensive. I use it when installing sound decoders in my HO equipment and had great luck. I have not run out yet, as you only need an inch or two at a time. I have put in about 10 Soundtraxx decoders with it. My source was Loys Toys, their part number# KAP and it sells for .50 cents per foot. I just checked their internet site.
Paul
Dayton and Mad River RR
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
