Simple crimp connectors offer an easy solution, but for a "proper" connection, I prefer to solder too. A trick I use all the time is to pull off the plastic of the common crimp connector, crimp it, solder either end, and then some heat shrink tubing to seal the deal. Overkill? maybe for the tiny wires where the connector isn't needed (just solder and heatshink), but perfect for your main connections to track with the bigger wire.
Here are some helpful pics I took workin on the truck one day.
Splice: http://www.supermotors.net/vehicles/registry/6721/52133
Connector: http://www.supermotors.net/vehicles/registry/6721/52136
Adrianspeeder
