Toy train operating and collecting
Interested in O gauge, S gauge, and Standard gauge toy trains? Are you a fan of Lionel, MTH, American Flyer, and other brands of toy trains made today and in the past? If so, the Classic Toy Trains Toy train operating and collecting forum is just for you. If you're new here, please read our forum policies.
Last post 11-24-2006 6:59 PM by Joe Hohmann. 6 replies.
Rate:
Sort Posts:
Page 1 of 1 (7 items)
11-24-2006 4:08 PM
Offline nickt22
Not Ranked
Joined on 05-15-2006
Posts 35
those short little wires
Often when you get a Lionel or any O scale building,  the lighting is already wired but it ends in a short, stubby wire. How can you extend this wire so it reaches farther to where you want to go. Is there a way to attach a piece of wire that is longer to it without soldering it? Im totally clueless
11-24-2006 4:42 PM In reply to
Offline Roger Bielen
Top 200 Contributor
Joined on 07-23-2003
Watkinsville, GA
Posts 2,121
Re: those short little wires
Nick, you can use a small wire nut.  If the wire is extremely thin you may have to double it over to get it to stay.  If the wire is a 22 - 24 ga a red crimp connector can be used.  I usually solder on a length of 22 ga wire and cover the splice with shrink tube.
11-24-2006 4:45 PM In reply to
Offline Demon09
Not Ranked
Joined on 01-03-2006
Chicago
Posts 224
To connect the wires to a longer piece, you can just get a length of wire the same guage, strip the ends of the new piece to expose the wire, and wrap them around the ends of the other piece, but make sure to use electrical tape to prevent a short on the line. You would do this for both wires, but make sure you don't mix up the wires, because if the positives and negatives are defined on these wires, they can never be crossed or switched.
11-24-2006 4:48 PM In reply to
Offline adrianspeeder
Top 500 Contributor
Joined on 03-31-2002
Harrisburg PA / Dover AFB DE
Posts 1,378
Simple crimp connectors offer an easy solution, but for a "proper" connection, I prefer to solder too.  A trick I use all the time is to pull off the plastic of the common crimp connector, crimp it, solder either end, and then some heat shrink tubing to seal the deal.  Overkill? maybe for the tiny wires where the connector isn't needed (just solder and heatshink), but perfect for your main connections to track with the bigger wire.
Here are some helpful pics I took workin on the truck one day.
Splice: http://www.supermotors.net/vehicles/registry/6721/52133
Connector: http://www.supermotors.net/vehicles/registry/6721/52136
Adrianspeeder
11-24-2006 5:34 PM In reply to
Offline lionelsoni
Top 25 Contributor
Joined on 12-27-2001
Austin, TX
Posts 6,362
If incandescent lamps are all that's in there, it doesn't matter if you swap the wires.
11-24-2006 6:59 PM In reply to
Offline jefelectric
Top 150 Contributor
Joined on 12-06-2003
Central PA
Posts 2,291
I used to solder additional wire onto the short leads.  Lately I have been using small plug in connectors.   When a lamp burns out you just have to lift the building far enough to unplug it and then you can take it to the bench to do the lamp replacement.  This is especially nice if it is a long reach to the building.
Offline Joe Hohmann
Not Ranked
Joined on 07-12-2006
Media, PA
Posts 489
True...proven by the fact that my house has not burned down...yet. Joe
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
Free Newsletter
Get our free monthly newsletter delivered to your inbox
My Profile
Screenname: (get your screenname)
Search Community
in
