Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Automatic reversing
  • Member since
    April 2003
  • 305,205 posts
Automatic reversing
Posted by Anonymous on Tuesday, November 8, 2005 3:37 PM
)] from point A to point B, go back to point A. Thank You.
georgi411@juno.com
  • Member since
    December 2004
  • 21,483 posts
Posted by MisterBeasley on Tuesday, November 8, 2005 6:12 PM
Does the train stop and reverse, or are there loops at each end?
It takes an iron man to play with a toy iron horse.
  • Member since
    October 2004
  • 8,639 posts
Posted by Texas Zepher on Wednesday, November 9, 2005 12:06 AM
Single track:
1. Break the track into three blocks. One big block in the center, and two tiny (one locomotive long) blocks on either end.
2. A DPDT relay with the contacts used for a direction switch in the track power.
3. Put a single-T detector in the end blocks.
4. The T on the block at the end of the "normal direction" is connected to a SPST relay. The relay both trips the direction relay in (#2 above), and holds itself on.
5. The T on the block at the "reverse direction" end is connected to a SPST relay that when tripped disconnects the power to the other T relay (#4 above).
Double track:
Only requires one Twin-T and one relay.
Two tracks like a passing siding. The turnouts sprung to always switch the train to the opposite track. Once again there are three blocks. The end blocks are past the points of the turnouts.
Basically on the end of the "normal direction" track is a block where a twin-T detector is. This trips a DPDT relay and reverses the locomotive. The locomotive switches to the other track. On this track the train is still detected by the Twin-T and holds the relay on. At the far end the locomotive enters a block that is not detected by the twin-T so the relay untrips and reverses direction. It crosses over to the undetected "normal direction" track.
Double track two trains:
Respond if interested, I developed this circuit for a "light rail" demo for our local city government. It is much more complicated that those above.
One can get electronic relays now instead of the mechanical ones....
  • Member since
    November 2002
  • 15 posts
Posted by woodview3 on Saturday, November 26, 2005 7:45 PM
What's a T-detector?
  • Member since
    October 2004
  • 8,639 posts
Posted by Texas Zepher on Saturday, November 26, 2005 11:45 PM
It is a standard MR circuit that is put in series with the track to detect when a train is on that section. Basically two diodes and a transistor. It can be improved with bias resistors and a second transistor. A Single-T can only detect trains in one direction. A Twin-T is two hooked together (sharing the diode set) so it can detect trains in either direction. To be detected the train must be conducting electricity, so without modification only locomotives and lited passenger cars/cabooses are detected.
Here is Bruce Chub's:
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
