General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 05-26-2007 6:37 PM by Canondale61. 22 replies.
Rate:
Sort Posts:
Page 1 of 2 (23 items) 1 2 Next >
09-20-2005 1:46 PM
Offline grandeman
Top 500 Contributor
Joined on 04-24-2005
Posts 1,049
Angry [:(!] Making Fall Aspens, a mini tutorial.
Hi guys. It's in response to this post http://www.trains.com/community/forum/topic.asp?page=1&TOPIC_ID=45609, that I'm putting this mini tutorial together. Before I start I'd like to say that I don't feel qualified to tell many of the members here how to model anything. I'm just an average model railroader and this is my technique for making aspens. It was concieved by a previous failure to get the results I was after on my first attempt. I tried again because we need the trees without the high prices of commercially marketed aspens.
Total time to make an aspen is probably less than 10 minutes (not counting paint drying time). The only cost involved is a cheap can of spray paint and the Woodland Scenics foliage material.
Friend and fellow board member cjcresent turned me on to a local plant called Oakleaf Hydrangea. http://davesgarden.com/pf/go/131/ While he may not have had aspens in mind, I've adapted the plant to meet the need. Oakleaf Hydrangea grows in the wild around here and on a recent railfan trip at our hunting lease, cjcresent pointed it out to me. Thanks CJ! The best time to harvest it is now, as the branches are dried on the plant and ready for use.
If you can't get the Oakleaf Hydrangea, Hobby Lobby has a variety of commercially available, prepackaged products that would probably work just as well for very reasonable prices.
Oakleaf Hydrangea, the "raw" tree material. Trim all the leaves and buds/seeds off.
After the excess material is removed, paint the tree flat white (off white would be even better).
Using white floral tape (Hobby Lobby, .67 cents a roll), tape the trunk in overlapping layers. The tape is like wax impregnated crepe paper and is best applied while stretched tightly. If done correctly, seems will be all but invisible. One roll of tape will do MANY trees.
Add the bark markings with a black Crayon. It's best if the Crayon is sharpened with a razor blade. Make the markings radom in nature.
Using Woodland Scenics Early Fall Foliage, carefully stretch the material and tear it into small, manageable pieces. This material reminds me a cross between pillow stuffing and furnace filter. When applying the foliage, keep in mind that real trees are airy and can be seen thru at spots. Ideally, you want to be able to see traces of the branch structure and upper trunk and backdrop when applied.
And now for the fun part, the planted fall aspen on the layout!
09-20-2005 1:58 PM In reply to
Offline dthurman
Top 500 Contributor
Joined on 09-19-2004
Central Illinois
Posts 992
RE: Making Fall Aspens, a mini tutorial.
[tup]
Well, now I can see I am off to Micheals to buy some Oakleaf Hydrangea and then the LHS for some foilage.
Thanks Grande Man!!!
09-20-2005 2:07 PM In reply to
Offline chewie8han
Not Ranked
Joined on 01-24-2004
PA
Posts 280
Thanks Grande Man! (gathers up the spilled beans, and prepares to tell the wife that these beans will grow into nice fall aspens... with a trip to the LHS!)
09-20-2005 2:10 PM In reply to
Offline steveblackledge
Top 500 Contributor
Joined on 11-08-2002
GB
Posts 972
Chears Grande man, nice work and well done
09-20-2005 3:43 PM In reply to
Offline Josh_A
Not Ranked
Joined on 02-05-2005
Posts 71
those are the best looking deciduous trees I've ever seen. Very well done, and easy to make too!!
09-20-2005 5:24 PM In reply to
Offline grandeman
Top 500 Contributor
Posts 1,049
Thanks for the comments guys. I hope you all have an aspen forest before long...
09-20-2005 10:10 PM In reply to
Offline JohnT14808
Not Ranked
Joined on 01-11-2003
Pacific NW
Posts 733
Grandeman....VERY nice!! I wonder if seeds for the Oakleaf Hydrangea are available at the local nursery......Plant some seeds next spring and you could have aspens in the Fall!!! ....wonder if the stuff will grow in the Pacific NW....Hm-m-m-m-m-m-m Sounds like ANOTHER Google search.......
Nicely done...Thanks for your tutorial. Wonderful trees.
09-20-2005 10:12 PM In reply to
Offline ondrek
Not Ranked
Joined on 02-24-2004
Vermont
Posts 527
Angry [:(!] RE: RE: Making Fall Aspens, a mini tutorial.
pardon me for asking, but did you also make the fur trees in the picture?
if yes, can you do a tutorial on how you made those too?
thanks
Kevin
09-21-2005 4:31 AM In reply to
Offline fievel
Not Ranked
Joined on 01-16-2003
Posts 278
Grande Man - that is absolutely amazing ! I've been looking for a more realistic
method for tree making. I plan on having Summer green foliage, but the trunk
detail is what really makes it come alive. Thanks a lot , and - GREAT JOB !!
[bow][bow][bow]
09-21-2005 8:12 AM In reply to
Offline grandeman
Top 500 Contributor
Posts 1,049
JohnT14808, check the link for places the oakleaf hydrangea grows. There's a list but you have to scroll down the page a good bit.
ondrek, the firs are made by Busch. I got them from a Walthers sale flyer . They range in size from 1"(great for distant ridgelines) to 6 " and 160 of them set me back about $50.
fievel, the green foliage should work just as well. Cjcrescent is using the oakleaf hydrangea for other type trees with good result as well. They would be even easier since the trunk wouldn't need tape/marking and the tree wouldn't need to be painted prior to adding foliage.
Thanks again for the positive comments. I've learned many cool things here and it's great to be able to give a little back every once in a while. Don't ya just love the internet?
Edited cause I can't type...[:I]
09-21-2005 10:38 AM In reply to
Offline egmurphy
Top 150 Contributor
Joined on 01-14-2003
Mexico
Posts 2,620
Nice work. They look great. A couple of questions.
1. So with the 'foliage' material you don't have to bother sprinkling on ground foam afterwards, it's already included?
2. Did you just put some white glue on each branch before applying the foliage, or did you dip the tree in dilute white glue?
3. Nice photography too. How do you manage to aim and squeeze the shutter release with both your hands in the photo?
Regards
Ed
09-21-2005 10:42 AM In reply to
Offline dthurman
Top 500 Contributor
Central Illinois
Posts 992
I heard he is good with his feet [:)]
09-21-2005 10:46 AM In reply to
Offline grandeman
Top 500 Contributor
Posts 1,049
The WS floiage already has the texture applied. In the earlier thread, I was speculating that dyed "pillow stuffing" could be sprinkled with foam for the desired effect. After using the WS foliage, I'm going to stick with it.
I just wrapped the foliage onto the limbs, no glue. It's a material that gets caught on the tree well enough as is.
As for the pics, I'm using the camera's timer feature and a tripod. The timer is great for getting sharply focused layout shots too...
09-21-2005 10:57 AM In reply to
Offline twhite
Top 50 Contributor
Joined on 07-07-2004
Carmichael, CA
Posts 6,336
Smooth job, Eric! I like it VERY much. Actually, I can adapt it for some fall Maples and Liquid Ambers that grow out here in California. I know that the Maple isn't native to California, but it was brought out here in the 1850's by New England settlers in the foothills, and grows all over the place in the Sierras, now. Thanks for the tutorial. Between your 'aspens' and Aggro's 'pines', you've made a lot of modelers happy campers when it comes to trees.
Tom [:P][:P]
PS: How big was that .22 you used to shoot those little holes in that little sign in the photo on your other thread, BTW? That is SO cool!
T.
09-21-2005 11:03 AM In reply to
Offline grandeman
Top 500 Contributor
Posts 1,049
Tom [:P][:P]
T.
I hope you can put the info to use, Tom.
As for Billy Bob, unfortunately he shoots a 44, not a 22! He ain't shoot'in nothin now, Jimmy Mac took his pistol... [:D]
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
