General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 03-17-2005 1:04 AM by jfugate. 323 replies.
Rate:
Sort Posts:
Page 22 of 22 (324 items) « First ... < Previous 18 19 20 21 22
06-20-2007 9:50 PM In reply to
Offline wm3798
Top 200 Contributor
Joined on 03-22-2007
On the Banks of the Great Choptank
Posts 2,133
Re: RE: FORUM CLINIC: Building realistic scenery
I put together a brief slide show on PDF showing a section of my layout coming to life.  It's the summer of 1972, so the colors are less muted, but to my eye, you can feel the humidity rising from the river...
Scenery PDF
The first page has some code screwed up, but the rest is there.
Here's the finished product...
It's great to have threads like this where we can compare notes on technique.  Jeff, your stuff is awesome.
Lee
06-23-2007 11:32 AM In reply to
Offline jfugate
Top 100 Contributor
Joined on 01-05-2002
Portland, OR
Posts 3,140
Lee:
Great scenery work, and that's a very fine PDF you have there showing how you did the work. I especially like the landscape orientation ... it fits a computer screen better than portrait does.
06-23-2007 11:42 AM In reply to
Offline wm3798
Top 200 Contributor
Posts 2,133
Thanks, Jeff.  I created it as a power point, then printed it to .pdf.  It was pretty easy, and yes, I wanted to maximize the image area of the typical computer screen...
Lee
10-20-2007 3:14 PM In reply to
Offline smitty311
Not Ranked
Joined on 09-10-2007
Posts 126
Re: FORUM CLINIC: Building realistic scenery
I noticed alot of newbies asking scenery questions lately, so I bumped this up.  This as an awesome guide to all-around scenery construction.  Thanks again Joe!!!
Smitty
10-20-2007 5:28 PM In reply to
Offline jfugate
Top 100 Contributor
Portland, OR
Posts 3,140
Smitty
You're welcome. There's also some more info I've posted about scenery construction on my personal web site.
03-11-2008 6:59 AM In reply to
Offline TerminalCardiac
Not Ranked
Joined on 01-31-2008
possum holler Indiana
Posts 14
Bump diddy Bump..Bump Bump
Lazarus Come Forth!
Resurrecting, IMHO, one of the best Forums Ive seen!
THANK U JOE!!!
03-11-2008 1:59 PM In reply to
Offline jfugate
Top 100 Contributor
Portland, OR
Posts 3,140
Lazarus Come Forth!
THANK U JOE!!!
You're welcome! There's also more on my personal layout website, where I have an entire section dedicated to scenery discusssions.
04-28-2008 12:34 AM In reply to
Offline ronmcc
Not Ranked
Joined on 02-17-2008
Posts 31
Joe, new to this forum. Question for you. Have you ever thought of using sandpaper for roads, roofing, or parking lots? I used it on one of my first layouts for roads and parking lots and it worked out very well. Can be painted, shaped, comes in a verity of colors, different grits for different scales and can be glued with white glue. Might be something that can be of good use to other modlers. Also it isn,t all that expensive. Send me a PM and let me know your thoughts. Thanks, Ron
04-28-2008 4:30 PM In reply to
Offline jfugate
Top 100 Contributor
Portland, OR
Posts 3,140
I've used sandpaper for roofs, certainly. Works good.
Less thrilled about using it for roads or parking lots. Scenery work (at least the way I do it) tends to use a lot of water, so any sandpaper would turn to mush most likely. Plus it's just too easy to texture a road or parking lot with a more realistic variety of textures than just what sandpaper would provide.
It's the subtle variations in texture that really makes your scenery realism pop. Sandpaper would be too uniform in many cases for roads or gravel parking lots, where tire ruts and bare spots will really spice up the realism factor.
In place of sandpaper, I use fine sand or fine ballast, spread it out dry on the road or parking lot, wet it well with 70% isopropyl alcohol, then soak it with white glue diluted 3:1 with water (and a couple drops of dish detergent thrown in so it flows better). I'll come back in with a brite boy and burnish out the ruts or add bare spots. Finally I'll hit it with my plaster-tempera weathering powders as described elsewhere in this forum thread and on my layout web site
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
