Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
entry-level DDC system?
  • Member since
    March 2010
  • 160 posts
Posted by Swayin on Monday, March 22, 2010 1:41 PM
Hi folks,
My first post on this forum; I hope it's not riduclously redundant. My kids and I are working on a 6x16 HO scale layout in the garage - great fun. I picked up a new Bachmann EZ Command system at a swap meet for next to nothing, but notice when I have a couple of engines going at once (especially an older DC model) that all the engines slow way down. Also, if I program my lone DCC-equipped loco to an address other than 3, its performance seems to suffer - gets very slow as well.
Is this a function of the system, which is obviously entry level in the extreme, or  or something I'm not considering? and if it's the system, is there one better suited for us, such as a Digitrax or MRC system?
thanks in advance ...
-------------------------------------------------------------------------------- The Beatings Will Continue Until Morale Improves
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Monday, March 22, 2010 2:57 PM
 The Bachmann is about as entry level as you can get. As for slowing down, 2-3 locos is probably the most it can handle, it's only about a 1 amp output. However, do you have more than one set of feeders to the layout that size? The rails and the rail joiners aren't particularly great and reliable conductors of electricity, and the slowdowns are probably the result of insufficient power gettig to the track - voltage drop in the rails/joienrs/wire will get worse the larger the load, so it makes sense that one loco is probably ok. I'll bet if you watch carefully, even when running one loco it noticeably slows down when it gets to the poit furthest from where the feeder wires connect. Add more feeder connections, and tie them together with some reasonably hefty wire - #16 should be good here. Keep the feeders short, only a foot or so. You'll probably see a huge improvement.
 If you want to step up to a system where you cna use the cab numbers as addresses and program some of the useful CVs you may have been reading about, you can't go wrong with either the Zephyr of PowerCab. Both are full featured systems and are generally light years beyond the EZ Command when it comes to features and capabilities. I've had as many as 8 locos, half with sound, runnign on my Zephyr, so it's enough for most home users, but both it and teh PowerCab are fully expandable to top fo the line systems as your layout and needs grow.
                                            --Randy
Modeling the Reading Railroad in the 1950's
Visit my web site at www.readingeastpenn.com for construction updates, DCC Info, and more.
  • Member since
    July 2006
  • 578 posts
Posted by Blue Flamer on Monday, March 22, 2010 3:08 PM
Swayin
Hi folks,
 Sign - Welcome to the Forums.
From what I have read on these forums, the Bachman unit is definitely entry level but it should run at least one or two loco's. My favorite is the NCE entry level set, 'cause that is what I bought for just under $150.00. Full retail is $189.00 but I have seen them on line for well under $150.00. They are very easy to use and program decoders with and should run at least 3 or 4 HO scale loco's with no problem.
As for your problem with the engines not running well, do you have at least a #14 or possibly a #12 gauge buss  line from the base unit the full length of the layout. You also need to drop feeders from the track to tie into the buss every 3 to 4 feet using #22 gauge  for drops under about 6 to 8 inches. If you require feeders longer than 8 inches, I would increase the size to #18 gauge. This was what I did.
It may sound like overkill, but Nickle Silver track is not the greatest conductor of electric current. Copper wires are much more efficient and no where near as expensive as track. Also, don't forget that you are sending little packets of information from the controller to the decoders in your engines. The less distance that the information has to travel through the track to the engine, the less chance that the packets of info will degrade and cause problems.
I am sure that some of the other more knowlegable  ladies and gentlemen of these Forums will give you much more and better info than I can.
Good Luck with your layout and again, Sign - Welcome
Blue Flamer.
"There is a very fine line between "hobby" and "mental illness"." Dave Barry, Syndicated Columnist. "There's no point in being grown up if you can't be childish sometimes." Doctor Who.
  • Member since
    June 2006
  • 9,577 posts
Posted by cudaken on Monday, March 22, 2010 5:20 PM
 I was a E-Z fan for three year. It ran 3 sound engines with proper wiring. When I need more power I did get a booster. When I went full DCC (at one time one main line was DC and the other line was DCC) I was running 4 engines and I need the extra power.
 Far as the older DC engines, they take 2 to 3 times the power than newer engines. Old Athearn with what was called a Rocket Motor by it self can pull 1 plus amp.
 Don't give up on it just yet and few more details would help.
 All so Welcome to the site!
           Cuda Ken
I hate Rust
  • Member since
    February 2005
  • 23,330 posts
Posted by selector on Monday, March 22, 2010 6:24 PM
I am certain I peeve some users and former users of the Bachmann EZ-Command system when I offer my opinion on this topic when it appears, but I would recommend any starter or basic system except the EZ-Command.
I didn't know much about it when I purchased mine, silly me, but in my defense, it was recommended by my LHS owner who had four of them he wanted to unload.  I hooked it up and spent maybe 10 minutes with it before I realized that it is a lame duck.  It cannot access the CV's those of us who use DCC engines like to access to customize the acceleration and volumes of individual sounds, for example.  Also, at the time it was limited to 1 amp, and I already owned three sound-equipped locomotives with power-hungry QSI decoders...with more causing me to drool.  One whole amp was woefully inadequate.
The fact is that all the other manufacturers make darned good starter systems....great ones, in fact. So, you could almost flip a coin between any two and find yourself quite content with any one of them.  Just understand up front that they do differ in power handling, in the way they 'feel', including the paddles in your hand, and even the visual displays vary.  You would be well advised to think about two years down the road...will your power needs be met with the purchase you make next week?  Can you add power easily to what you purchase next week if the answer is no?  What would that involve in today's dollars?  Would it make more sense to over-purchase slightly, say by 40-60% of your current estimated power requirements and be confident that you could use this system for the next 10 years?
I am sensitive to how I may tread on the toes of those who are perfectly content with the EZ-Command, but I can't participate in a thread like this one and say it's a good buy in my opinion.  Not with a clear conscience.  It's like a calculator without a multiplication function.
-Crandell
  • Member since
    July 2006
  • 2,173 posts
Posted by Driline on Monday, March 22, 2010 7:26 PM
selector
-Crandell
Thank you for your honest opinion. It's refreshing NOT to hear the  "Its your layout do what you want" mantra. A lame reply thrown around much too often.
Modeling the Davenport Rock Island & Northwestern 1995 in HO
  • Member since
    May 2009
  • 356 posts
Posted by Silver Pilot on Monday, March 22, 2010 7:47 PM
cudaken
           Cuda Ken
Ken, you forgot to mention how many decoders you fried after you added the booster.
Google is good! Yahoo is my friend.
  • Member since
    February 2002
  • 30,002 posts
Posted by rrinker on Monday, March 22, 2010 8:47 PM
Silver Pilot
 Yeah but that was a combination of slightly inadequate wiring and the poor quality of the MRC welding machine, err booster.  Actually, it seems it was a quite nice welder, maybe an EDM power supply, it was just a not so good DCC booster.Big Smile
                                                       --Randy
  • Member since
    May 2009
  • 356 posts
Posted by Silver Pilot on Monday, March 22, 2010 9:02 PM
rrinker
Silver Pilot
                                                       --Randy
AND, since the OP mentioned how when he ran multiple engines they ran slower and adding a booster would be a possible solution except Ken's experiences show what happens you unwittingly combine poor wiring, mismatched components and a lack of knowledge of DCC.
  • Member since
    June 2004
  • From: Orig: Tyler Texas. Lived in seven countries, now live in Sundown, Louisiana
  • 25,640 posts
Posted by jeffrey-wimberly on Monday, March 22, 2010 11:44 PM
Swayin
What you are describing is an inherent weakness in the Bachmann EZ-Command system. It has only 1 amp to work with and that doesn;t go far when you have several locos running at once. I used one for two years before some friends helped me get my Digitrax Zephyr. The Bachmann system worked OK for me since I was only running two trains at once and maybe running a switcher on the side. Running a DC loco on address 10 is going to eat up a lot of power that could otherwise be put to better use, especially if it's an older loco with an inefficient motor. I've changed out most of the motors in the antique Athearn locos I have and they run much better because of it.
Running Bear, Sundown, Louisiana
          Joined June, 2004
Dr. Frankendiesel aka Scott Running Bear
Space Mouse for president!
15 year veteran fire fighter
Collector of Apple //e's
Running Bear Enterprises
History Channel Club life member.
beatus homo qui invenit sapientiam
  • Member since
    March 2010
  • 160 posts
Posted by Swayin on Tuesday, March 23, 2010 12:29 PM
Thanks everyone for the great feedback and replies ... much info to chew on, but it seems inevitable that I will at some point move up to at least the Digitrax Zephyr.
 Again, thank you! Bow
  • Member since
    April 2007
  • 869 posts
Posted by Lake on Wednesday, March 24, 2010 9:49 PM
 I spent 3 years reading N-scale, Model Railroader magazine and the forums. After all this I bought a Digitrax super empire with radio control. I can be any where in the room and it works. No cables in the way or having to be pointing at a RF terminal.  My lay out is in a 11' by 10' and no direct line of site to a IR port.. So all I can say is, "It's Alive and works great". Worth every dollar.
So I would say get any system that uses a radio frequency as you get the best of all worlds. The local model railroad club uses the same system but without the radio control. What a pain in the you know what. Cables in the way all the time.
Ken G Price   My N-Scale Layout
Digitrax Super Empire Builder Radio System. South Valley Texas Railroad. SVTRR
N-Scale out west. 1996-1998 or so! UP, SP, Missouri Pacific, C&NW.
  • Member since
    June 2006
  • 9,577 posts
Posted by cudaken on Thursday, March 25, 2010 9:20 AM
 Well, my E-Z served me well and for $30.00 what can I say. I don't think the MRC Booster was so much of a problem as the poor wiring to the new section. In retrospect I had no problems with the E-Z and MRC booster eating decoders till I added the new section.
 Swayin, more feeders may help. Like I said I was running 3 BLI steam engines with QSI sound with no problems.
 By the way Swayin, do you know what the quarter test is and understand why to use it? If I understood and did the test I would not killed decoders like I did.
 Any system is going to eat decoders if not wired right.
                  Ken
I hate Rust
  • Member since
    March 2010
  • 160 posts
Posted by Swayin on Thursday, March 25, 2010 11:53 AM
cudaken
nossir, I do not ... enlighten me when you get the chance! Thumbs Up
  • Member since
    August 2008
  • 1,329 posts
Posted by wholeman on Thursday, March 25, 2010 1:13 PM
 The quarter test is simple.  You place a quarter on the rails when they are powered.  If the quarter causes a short and makes the DCC system reset itself, then you have good wiring to the track.
Will
  • Member since
    March 2010
  • 160 posts
Posted by Swayin on Thursday, March 25, 2010 1:19 PM
Neat. The theory being that if it *doesn't* cause a short, not enough juice is getting to the rails? and should this be done at the point farthest from the connection?
  • Member since
    August 2008
  • 1,329 posts
Posted by wholeman on Thursday, March 25, 2010 1:33 PM
Swayin
Sort of.  It can be done just about anywhere.  I have been told that once you've installed a new feeder, give it the quarter test.
Will
  • Member since
    May 2009
  • 356 posts
Posted by Silver Pilot on Thursday, March 25, 2010 2:31 PM
Swayin
Not quite.  There is enough 'juice' to run a locomotive even if a short is not caused by the quarter.  The 'theory' is that there is too much drop in voltage between that CS and the spot being tested that the CS can not sense or recognize that there is a short and shut down the system.  Installing more feeders helps resolve the issue.
Do a internet search for dcc and quarter test - read about it.  That's how people learn.
  • Member since
    March 2010
  • 160 posts
Posted by Swayin on Thursday, March 25, 2010 4:54 PM
wow - you almost made it through a whole post without saying something snotty - maybe there's hope for you yet.
  • Member since
    June 2006
  • 9,577 posts
Posted by cudaken on Thursday, March 25, 2010 5:44 PM
Swayin
 You and I could be come friends Swayin! Big Smile
With the to thin of a feeder wire I was fooling the booster in to thinking I need more power.( This part need's to be left to someone that understand electrical stuff.) So when something went wrong the booster did not shut down. When I laid a quarter a cross the track it just made a sizzling sound. Disapprove Booster did not shut down.
 In a nut shell, I built a stand a lone bench (now hooked to the main bench) and wanted to test run it. Only wire I had handed was 22 gauge that I was using for feeders. Ran the 22 gauge wire to the main bench blocks (I was DC so I had blocks and not a bus wire) I had power so I thought I was good to go, well DC I might have been, DCC NOT!
 I was clue less what was wrong and BBQ $200.00 in decoders. Part that threw me was there was no dead short, decoders would last say 10 to 20 hours before I let the smoke out!
 Luckily Simon 1966 lives close by and he spotted the problem like that! Ran a heaver wire to the main bench blocks and I have been fine for a year now.
 Your friend, running $$ steam engines again with not derailment problems Ken.
I hate Rust
  • Member since
    September 2007
  • 6,099 posts
Posted by Phoebe Vet on Thursday, March 25, 2010 6:10 PM
I vote with Selector.
I started with an EZCommand.  It is now in the junk box under the layout.  I have a Digitrax Super Chief with duplex radio and you could not pay me to go back.
Dave
Lackawanna Route of the Phoebe Snow
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
