Hi,
I'm waiting for a great lakes freighter to arrive http://www.walthers.com/exec/productinfo/696-10501
and I´m wondering how tall it is. I need to know the height up to the deck and railings from the bottom of the boat so that I can plan my post height and position of my Huletts.
Any info on the height to the highest point would also be appreciated but not necessary.
Thanks in advance.
Magnus
Magnus,
I checked the Sylvan Models web site and the Great Lakes Lumber Hooker "Langell Boys" is 22"L x 4"W. However, it doesn't mention the height at all.
For the specific info you're looking for, I would just contact Sylvan directly. Here's their e-mail address:
office@sylvan.isp.ca
Magnus, I've had two dealings with Sylvan in the past and they have ALWAYS been responsive and very helpful. Terrific folks and a great product!
https://tstage9.wixsite.com/nyc-modeling
Time...It marches on...without ever turning around to see if anyone is even keeping in step.
Hi Tom,
I've already e-mailed Sylvan but wasn't sure if they where one of those companies that seem to misplace e-mails rather then replying to them. So I thought I better ask here as well and might get a quicker answer. I'm building the section as we speak so I'm eager to know as fast as possible. You know how it is.
So anyways, thanks for the suggestion and the email address, I apreciate the help and the effort tremendously. I'm glad to hear that Sylvan is very responsive. I got one of there Laker class steam ships. A very nice model so I expect this to be just as great.
Sincerely,
Hey, your very welcome, Magnus.
As I said, I've dealt with Sylvan twice and they treated me well both times. One instance I broke a part and asked them if I could purchase a replacement part. The other instance I was missing a part. In both cases, they sent me the item for FREE. The missing part was actually a rubber tire. Sylvan sent me an entire set of 6.
Magnus, if you don't hear back from them in the next day or so, just send them another e-mail. They are a small family-owned business. So, it wouldn't be entirely out of the ordinary if "family" things come up sometimes and they don't get to inquires as quickly as usual.
Anyhow, I look forward to seeing pictures of that ship when you're done assembling and painting it.
I have a Sylvan Great Lakes ore boat that I modified, but if you want, I can take some measurements of it when I get home tonight. What are you mainly looking for...height of the hull in the mid-section [for hullets]? I'm not sure what you mean by "post height", are you referring to forward and aft posts with the running lights on them, to determine bridge clearance? Mine are customized so they might not be accurate...
-Ken in Maryland (B&O modeler, former CSX modeler)
YIKES ! $300.00 for a plastic kit of a boat?? and can those dimensions be correct? 36'' long (3 feet) that's a pretty massive addition to any HO layout. Also try looking around on a site for plastic model boats, pretty sure you will come in way under $300.00.
tatansYIKES ! $300.00 for a plastic kit of a boat??
tatans,
Correction: It's actually resin rather than plastic. I've only put together their small resin car kits. However, they make a very good quality product. Should turn out quite nicely.
tatans YIKES ! $300.00 for a plastic kit of a boat?? and can those dimensions be correct? 36'' long (3 feet) that's a pretty massive addition to any HO layout. Also try looking around on a site for plastic model boats, pretty sure you will come in way under $300.00.
In fact $300.00 for a 1/87 ship model is not expensive at all, it is rather cheap. Also 36" long for a ship model of a Great Lake Freighter is rather short. A full length HO model of such a vessel would be over 7 feet in actual length.
At the club we scratchbuilt a model of a small containers ship see below.
Since the pictures were taken more work has been done on the scenery.
The ship was built from plan of a small container ship that could carry 1100 containers of 20 feet. It is 6 actual feet long, we had to cut 100 feet from its real length in order for it to fit in the space available. We also had to reduce the eight of the structure by one floor.
Jack W.
Here's pictures of my great lakes freighter. I believe i made my pier 2-1/2." I turned it into a container ship
chuck
Why would you expect it to be cheaper? These are highly specialized kits that are prototypical only for a small geographical area (Great Lakes) and are special purpose vessels designed for a single commodity. They're not going to sell in the thousands (or hundreds for that matter) per year.
Sure you can get cheaper boats, but not that size or prototype. You think the ore boats are expensive, check out this: http://www.modelshipmaster.com/products/ocean_liners/hellespont_fairfax.htm
Given that the prototype is 380 meters long and the model only 1 meter (more or less), that model is at a scale of approsimately 1/380 ( or significantly less than half the size of N scale). 'Course it is "RTR" and not a kit. Hmm. I could get a DPM brass engine for that price.
Andre
Chuck, how did you made your cranes?
A lot of the crane 's components are scratch built. The basic main derricks are 2 IHC intermodal crane kits that i cut one end off and filled in with styrene. I used bits and pieces from other kits so that the lifts move up and down and from side to side and can pick up a container from the ship if need be. Both derricks can also slide along the pier on code 100 rail that I embedded into the "concrete" next to the railroad tracks.
jalajoie Chuck, how did you made your cranes?
CSX_road_slug Magnus I have a Sylvan Great Lakes ore boat that I modified, but if you want, I can take some measurements of it when I get home tonight. What are you mainly looking for...height of the hull in the mid-section [for hullets]? I'm not sure what you mean by "post height", are you referring to forward and aft posts with the running lights on them, to determine bridge clearance? Mine are customized so they might not be accurate...
Mr Csx,
I would apreciate in case Sylvan takes it time to answer.
About the "post" that is a typo on my part, sorry. I meant port height. Basically I want to know how high above the water that I want to place my quay (I lost that word from my English vocabulary when typing originally).
I need to work out the height so that I know in what position to model the Hulett unloaders that I got.
I would would be very happy if you could give me that info.
Sincerly, Magnus
I don't think that is very expensive at all to be honest. It's a one time investment and you don't need many of them. It's not like the coal hoppers and ore jennies needed to receive the cargo. Nor are they engines which might cost a lot more for just one engine and we all end up buying several, atleast I do.
About the length, they are very narrow so they don't eat up to much space. I will have to large boats of this size on the layout and tugboat. I got a Gato class submarine built up that I'm considering adding as well that is roughly 4 feet as well. But they are all narrow! So they make excellent industries. The Laker class tramp steamer I got make an all round industry that can pretty much receive any cargo and thus is a lot of industry in a small space, just 3 feet. It can receive either oil or coal as fuel. It can receive all kind of boxcars with all kind of materials.
This ore boat can be lengthened and I've order two additional sections bringing the boat up to 140 cm. Which is not overwhelming in any way if you ask me.
tstage Anyhow, I look forward to seeing pictures of that ship when you're done assembling and painting it. Tom
Will do, it will take some time but I'll post some pics when it gets here and starts getting assembled. Need a new camera too, the old one eats batteries, two pics and then they are gone. :(
Lillen I would apreciate in case Sylvan takes it time to answer. About the "post" that is a typo on my part, sorry. I meant port height. Basically I want to know how high above the water that I want to place my quay
Since everybody else is showing pics of their boats, I'll show mine. Here is a full-length shot of the Marquette taken in 2005, when my current layout was still under construction. NOTE: It has 3 hull extensions, and a "false bottom" to make it look partially empty.
A head-on view:
Thanks Chuck for the info, that is ingenious.
Ken, I like very much your harbor overall scene.
jalajoieKen, I like very much your harbor overall scene.
Thanks Jack, if I had a gymnasium [and the $$] I'd model the entire Cuyahoga Valley!
CSX,
Very impressive. Now your starting to tempt me into getting a third section as well!
You have a very nice layout. Was it featured in Joe Fugates's magazine? I think I recognize it from somewhere but I can not put my finger on it.
LillenWas it featured in Joe Fugates's magazine? I think I recognize it from somewhere but I can not put my finger on it.
CSX_road_slug LillenWas it featured in Joe Fugates's magazine? I think I recognize it from somewhere but I can not put my finger on it. It is one of the revolving "banner" images on the MRH web site (the ones that have "Yes its a model" pasted on them)
Thanks for clearing that up. That explains it.
Here are the measurements on a standard Sylvan hull (without a false bottom):
Waterline to top edge - 1.875 in or 4.8 cm
Waterline to top of handrail - 2.25 in or 5.7 cm
Dock* to waterline - 2.0 in or 5.1 cm
* That's what my own dock measures, but it may not be truly prototypical; I've seen other model docks that are half that height.
Q: Do you really have to cement your Huletts into permanent positions? I thought they were designed so you can change their position as often as you want to. At least that's the way I would do it if I were building them. If the model wouldn't stay in the desired position, I would drill a tiny hole in a non-visible location and insert a 'set' screw to hold the two overlapping pieces in place.
CSX_road_slug Here are the measurements on a standard Sylvan hull (without a false bottom): Waterline to top edge - 1.875 in or 4.8 cm Waterline to top of handrail - 2.25 in or 5.7 cm Dock* to waterline - 2.0 in or 5.1 cm * That's what my own dock measures, but it may not be truly prototypical; I've seen other model docks that are half that height. Q: Do you really have to cement your Huletts into permanent positions? I thought they were designed so you can change their position as often as you want to. At least that's the way I would do it if I were building them. If the model wouldn't stay in the desired position, I would drill a tiny hole in a non-visible location and insert a 'set' screw to hold the two overlapping pieces in place.
First of, thanks a LOT for these measurements and the edited photo. I really appreciate you taking the time to help me by not only taking the measurements but also editing the picture. So thanks a lot.
Second, about the Huletts, well they are built so that you can "operate" them as you wish after they've been built. I got one built up already and it's a nice model and moves easily. But, the cables at back of that should control the model if it was the real thing have to be set in the position that you want it to rest in. Because if you lift the models bucket above that point the string will go loose and just hang there. Not a very realistic or visually appealing look. So therefor you need to plan the position to begin with. I plan to have on all way down. That is the one I've built so far and the other will be on it's way up or down in midway.
Once more, THANKS!
And oh, Sylvan hasn't answered me yet so this lets med get going now.
Does anyone have the measurements for the N scale Great Lakes Freighter??. My dock will be a little over 1" to the sea floor and I need to know the height from the main deck to the bottom of the hull.
I just wanted to say that I've now received an answer from Sylvan. Great response time for such a small company and I wanted you guys to´know it to.
I klnow I'm a bit late, I see your post was 2010 but I'm interested in the plans you used to create this container ship. JGH
