Back in the Sixties steam was done and over one hundred were gathered for scrapping. Laid-off fitters from the main shops were called back, give a quickie tutorial in operation of cutting torches and put to work on the condemned.
Three parallel tracks were used, piping for Oxygen and Acetylene laid out adjacent.
Steam engines, rods off, were brought up by a Judas Diesel five at a time, and spaced out on the centre track.
A steam crane was on the one outside track, a Diesel crane with a magnet on the other outside track.
Almost first move was to rip the cabs off with the crane, their interior wood lining often ablaze from the cutting torches, paint peeling.
Then they cut the outer tin jacketing to get at the boiler and firebox.
When the boiler shells were cut through, and holes cut for hooks, the big steam crane would yank sections of the top of the boiler off in a cloud of asbestos dust, the cutters on the running boards turning their heads but, surrounded in the white and rust cloud none the less.
The Asbestos block lagging held to the boiler shell by metal straps
Ugly to watch, but captivating.
Scrapping Diesels is NOT the same!
The big steam crane would lift the whole cylinder casting up, after cutting it free from the frame, the valve motion, crosshead and guides and brackets, the pilot, the front truck suspension, if applied, and the smokebox, and swing it into an awaiting gon, 3 to a car.
After the crews quit, we would climb up into the eviscerated engines to look around, watching out for hot slag.
Waste, wood, coal and oil were always smouldering, shrouding the scene like a War film.
Messy, dirty and stink.
Piles of driving boxes in a heap for their yellow metal.
Ditto headlights, for whatever reason.
Gauges, injectors, tri cocks, cab lights and other appliances scattered all around.
Wonder how the labourers who worked day after day in the white clouds of asbestos dust fared in later years..
One of the One Hundred. Scrapped serviceable. With a tender full of coal.
http://www.railways.incanada.net/Articles/art2006_12.JPG
Fifty years ago.
