General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 11-21-2009 6:22 PM by leighant. 19 replies.
Rate:
Sort Posts:
Page 1 of 2 (20 items) 1 2 Next >
11-20-2009 12:41 PM
Offline 0-6-0
Not Ranked
Joined on 06-13-2006
northeast ohio
Posts 539
so what you can't see it
Hello I have been working on a kit and my wife came in and was looking around. And then ask why are you going to all that trouble on the side you cant see? And I said it was good practice for the side you can see and if I left it alone it would bother me. She gave me one of those wife looks and left. So what do you do? Do it right and finish it or do you leave it. Because you cant see it. Frank
11-20-2009 12:49 PM In reply to
Offline pike-62
Not Ranked
Joined on 02-04-2001
Posts 628
Re: so what you can't see it
The next time you are painting the house or mowing the lawn only do what is in the front of the house. When she asks why you didn't do the back...ask her why go thru all the trouble on the side people don't see.
11-20-2009 12:53 PM In reply to
Offline tstage
Top 25 Contributor
Joined on 06-11-2003
Northeast OH
Posts 8,971
Frank,
For me, if there's a window where even part of the inside can be viewed by a visitor (or me), then I try and "reasonably" detail it, like this diner that I'm still working on:
Now, how far you define "reasonably" is entirely up to you.  With that said, I'm probably one of those that goes a little farther than is necessary.
11-20-2009 3:45 PM In reply to
Offline MisterBeasley
Top 10 Contributor
Joined on 12-02-2004
Bedford, MA, USA
Posts 9,624
Some day, you may change your layout.  After all, no layout is ever really "done."  So, you may put that structure somewhere else, or turn it around so the back becomes the front.  If, or when, that happens, the unfinished side is going to look pretty strange.
I have a table layout, so everything can be seen from pretty much any direction.  Sometimes, I put a camera in there, too, to catch a view that the eye wouldn't otherwise see.  You may do this someday, so you'd might as will do the whole job.
11-20-2009 4:32 PM In reply to
Offline shayfan84325
Top 500 Contributor
Joined on 11-06-2007
Utah
Posts 826
This is one of my favorite photos of my layout:
It was taken from the back wall looking toward the front (I used a little tripod and the self timer.).  Everything in the picture is from that "can't see" angle,   For me, this one picture is good enough reason to finish everything all the way around.
11-20-2009 5:10 PM In reply to
Offline selector
Top 10 Contributor
Joined on 02-07-2005
Vancouver Island, BC
Posts 15,504
And yet, it was a legitimate question.  I don't weather the web of the rails on my layout that don't appear on camera angles or from the operating area.  To me it is a mis-use of resources, time and paint, that could be used where they can be readily appreciated in view.
Yet, again, it would be an incomplete model for me if I went to the trouble to pay for, and painstakingly erect, a model, especially an expensive craftsman type, and not do all I could so that it could be situated in any orientation.
-Crandell
11-20-2009 7:18 PM In reply to
Offline jeffrey-wimberly
Top 10 Contributor
Joined on 06-21-2004
Sundown, Louisiana
Posts 13,323
 Because I might want to turn it around someday and the work will already be done. DUH!
11-20-2009 7:35 PM In reply to
Offline twhite
Top 25 Contributor
Joined on 07-07-2004
Carmichael, CA
Posts 6,671
jeffrey-wimberly:
What Jeff said.
11-20-2009 7:48 PM In reply to
Offline tbdanny
Not Ranked
Joined on 06-26-2009
QLD, Australia
Posts 417
I know that just knowing it is complete is enough for me.  It wouldn't feel right if one side of the structure was just 'blank'.
What you can do is use the 'back' side for techniques you're not sure about using on that particular model.  I discovered a quick way for doing brickwork like this, by accident, on a roundhouse wall that will be facing the backdrop.  After spilling some light filler on it, I noticed it created a bit of a mortar texture.  So I spread it over the entire wall section.  It worked well, so I applied it to the 'visible' part of the roundhouse.
11-20-2009 8:07 PM In reply to
Offline hcc25rl
Not Ranked
Joined on 08-14-2006
Burnsville, MN
Posts 166
 IMHO - I'd finish everything 'cause I'm just that way!
Jimmy
11-20-2009 9:41 PM In reply to
Offline Archer1
Not Ranked
Joined on 05-27-2009
Posts 46
 Frank -
This is more from a modeler, than a model railroader, OK?
I still remember reading an article  or seeing something somewhere when I was a kid, where a guy was doing, IIRC a helicopter model and he was detailing the engine. I still remember his words, too bad you won't be able to see this at all once it's in the chopper.  I still remember my reaction - this guy is a idiot. That stuck. If there's no way something will ever/could ever be seen, I have a hard time justifying working it. Kinda like detailing a carb on a curbside model car with a non-opening hood. (If I ever decide to cut the hood, THEN I'll do the carb.)
 Getting back to MRR, most of my layout are 360 degree numbers, so most people can do walk arounds. In that case, yes, pretty near everything gets worked. I like being able to see things from different angles - keeps it interesting and can lend a few surprises to the layout.
 The last part of the equation is what's called the payoff in some psych circles. In this case, the payoff means how much work is THIS part going to take vs. what's going to be my return on it. Sometimes I can be under the magnifying lamp for hours and sometime a quick coat of paint suffices. We all do it.
Archer
11-20-2009 10:07 PM In reply to
Offline doctorwayne
Top 200 Contributor
Joined on 01-04-2004
Posts 2,222
Except for the scalehouse and other small structures in the foreground, none of the structures in this photo have modelled backs.  There is a back, or, in the case of the larger buildings, a lot of heavy-duty bracing, but it's simply blank .060" styrene.
Her's the same area from the opposite direction:
This one, built from a bag of broken parts from the used table at my LHS, has only two finished walls, as that was all for which there was parts.  The other walls are more .060" styrene:
The brick building shown here has only its front finished.  The other walls are painted a "brick colour", but they're barely visible from any direction:
I built four of these coal dealer's storage bins.  Three are finished like this one:  both ends and the side facing the track:
The fourth has both ends and the truck loading side finished:
The two kit-built structures on the right are fully modelled (I didn't feel that it was worth the effort to replace the rear walls, even though they're not viewable), while the two kit-bashed ones at left are three-sided:
As is this scratch-built icehouse:
And the GERN complex is modelled only on its visible sides.  Even the free-standing section, at right, has only two finished sides:
I do, however, paint both sides of both rails, as I often take photos from the layout.  Here's a shot of the area shown in the first picture:
...and a view on the layout (the track has yet to be ballasted) from the same direction as my second photo:
Another reverse-angle view:
This shot looks right across the aisle to the area of the scene above:
And a view along the tracks (I think that's the northern lights overhead, but I don't like the looks of those clouds in the distance ):
Near the icehouse:
And a view from staging:
The buildings in the foreground at right and centre are fully modelled, while the one at left has a finished wall (facing the camera) cut-off on an angle at the edge of the layout, with the cut area simply blank styrene.  The front, facing the building at centre, is also finished, as is the unseen wall, which faces the five-storey building to the rear.  That wall can be seen at right in the photo above.
For an around-the-walls type of layout, using finished walls only where they'll be visible allows you to double the size of many structures simply by using the unseen wall on the side where it will be seen - many of the structures above are examples of this.
11-20-2009 10:16 PM In reply to
Offline blownout cylinder
Top 50 Contributor
Joined on 11-11-2008
London ON
Posts 4,580
jeffrey-wimberly:
But Jeff, some don't like to model things like that!!
11-20-2009 10:57 PM In reply to
Offline ham99
Not Ranked
Joined on 02-11-2004
Posts 384
If I hadn't finished the back, I'd wake up some night at 3:00 a.m. and not be able to go back to sleep thinking about it.  I'd probably get out of bed and go fix it.
11-21-2009 4:37 AM In reply to
Offline IRONROOSTER
Top 50 Contributor
Joined on 06-08-2003
Northern Viriginia
Posts 4,904
 I do all the sides because I don't know where it will be used on the next layout and also to me that represents a finished model.  But I also understand the theatrical aspect of this hobby so I can see why you wouldn't bother with the parts that are going to be seen.  With interiors and scenery I go the other way.  If you can't see it, I don't bother.
Enjoy
Paul
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
