Electronics and DCC
The place to discuss wiring for DC and DCC controlled model train layouts. If you're new here, please read our forum policies.
Last post 11-21-2009 11:35 PM by selector. 23 replies.
Rate:
Sort Posts:
ATLANTIC CENTRAL
Joined on
01-26-2009
Maryland
Re: Crest Train Engineer Vs DCC sysstems
davidmbedard:As a professional singer, drinking any type of Alcohol is a bad idea (just so you know).
You invited me to freemo to see how good DCC was and "have a couple beers", I politely declined.
See my memory is just as good as yours, dispite my old age of 52 years.
Sheldon
ATLANTIC CENTRAL
Joined on
01-26-2009
Maryland
tstage:NCE's D13SR decoder is 4-function, silent-running, and VERY good for the price. Singularly, they can be had for $13-$14 each. In bulk (4 or 10), you can get them for under $13 and $12, respectively. These particular decoders a FAR cry from the low-budget Lenz decoders that only run okay, at best. It's these decoders that David has qualms about; NOT the low price but better quality decoders.
Tom, David, That's all well and good and I'm happy the DCC prices are that low.
But I am tired of being criticized for not wanting to spend time and money for features I don't need or want.
Still, 100 locos (I'll publish the roster if that will make David happy) x $12 = $1,200. That's $1,200 I would rather spend on my signal system, or structures, or more rolling stock, or whatever.
And I like the fact that I can just put three matching locos on the head end of a train without 5 minutes of button pushing, assigning, un-assigning, consisting, etc, etc.
I dislike the small buttons and displays on most DCC wireless throttles.
And I like the fact that my trains won't crash into each other if operators make a mistake.
I use DCC on four different friend's layouts, I'm still not impressed, it's a cost/value thing for me. I don't buy expensive autos for the same reason. I don't buy expensive model train locos (brass or BLI at nearly full price, MTH, etc) for the same reason. My choices.
And not one feature of DCC is important to MY goals for MY modeling, so why spend the money or MORE importantly do the work of installing decoders?
I'm not in model railroading to make friends, help others or have a social life, so "conforming" to the crowd is of no importance. Those are just "side" aspects of the hobby for me. With or without those aspects the hobby would still fullfill my interest in it. I like to design and build things, houses, cars, model trains, electronics, furniture, and more are on my resume of successfull projects.
I still want to know why alternative control systems send some of you into hyper defense mode?
As for DCC companies going out of business, you have no way of predicting the future any more than I can trust Lewis Polk to not stop making the TE, even though he told me personally that they will make the current 10 channel TE as long as it is profitable, since they just spent a bundle retooling the 10 channel trackside just a few years ago.
Who knows, Atlas could decide their system is not competitive and get out/stop supporting it, CVP is little and privately owned, he won't live forever? I know all are good excusses to buy Digitrax with their poor ergonomics, no thanks.
Sheldon
maxman
Joined on
02-15-2008
rrinker:NCE and Wangrow (and Ramtraxx), while 3 seperate companies, shared a common system design, so no orphans.
Just as a minor point, although Wangrow and NCE shared a common design I believe that NCE no longer supports any of the Wangrow items, nor can you get the Wangrow products upgraded to whatever NCE's newest and greatest is. I also think that you cannot get any of your Wangrow items repaired by NCE. So in this regard, the Wangrow system is kind of an orphan but not necessarily obsolete if it continues to do what you want it to.
I believe that it would be fair to say that any of the current systems, be they Aristocraft or one of the DCC systems, could be "orphaned" if their owners suddenly decide that they no longer want to play trains and a buyer cannot be found for the business. The only way to avoid this issue would be to stay with a straight DC system.
Now, Sheldon, I have a question for you. I looked at your control panel wiring pictures. All of the wiring is neatly and professionally done. But in light of the previous discussions concerning the amount of electrical work required to get a DCC system up and running versus a straight DC system, exactly how much of that stuff I see is required by Aristocraft and how much was required by your own design so that you can achieve your walk-around control?
ATLANTIC CENTRAL
Joined on
01-26-2009
Maryland
maxman:Now, Sheldon, I have a question for you. I looked at your control panel wiring pictures. All of the wiring is neatly and professionally done. But in light of the previous discussions concerning the amount of electrical work required to get a DCC system up and running versus a straight DC system, exactly how much of that stuff I see is required by Aristocraft and how much was required by your own design so that you can achieve your walk-around control?
Everything you see on those relay panels and control panels is part of the walk around cab selection circuit and X section control for some of the track sections. My circuits would work the same with teathered memory throttles or with another radio throttle like the RCS system.
On a single track layout with passing sidings like the ones shown, only two cab asignments are needed for the each "town" (passing siding). The other two commonly needed "blocks" are correctly powered or turned off automaticly by the combined turnout postion of two passing siding turnouts.
And, then as you progress toward the next town, you can asign the first section of that town to your throttle before you leave the current town. All allowing you to walk with your train with no doubling back to the control panels and with very few buttons to push.
The buttons are lighted to show all users at all panel locations which cab is asigned to which section, and automatic buffer sections (short dead spots between track sections not asigned to the same cab) prevent trains from over running their cab.
The Train Engineer only requires two wires to the track, just like a simple power pack, the rest is cab control to allow multi train peration. The layout shown in the picture has 4 Aristo throttles asigned to the main line. It is a basement sized layout that depicts a 1900's logging line. Four trains at once is quite a bit of traffic as there are only 5 passing sidings, a wye and three stub end terminals, all connected by single track mainline.
There is also a logging branch which has both standard and HOn3. This area has two additonal Aristo throttles. In the town where the branch meets the main, all six throttles can be used in specific sections for interchange work.
My own layout is double track and works differently. I will save that explaination for a later time if anyone has interest.
Sheldon
tstage
Joined on
06-11-2003
Northeast OH
ATLANTIC CENTRAL:Tom, David, That's all well and good and I'm happy the DCC prices are that low.
Slow
down, Sheldon. I was not criticizing you; nor was I suggesting that
you invest your monies in anything other than what will best meet YOUR needs and wants. All I was doing was correcting your earlier
generalization that all "low budget" decoders were of inferior
quality. They are not.
ATLANTIC CENTRAL:I still want to know why
mode?
I think when those from either DC or DCC camp makes
untrue statements in regards to the other, that's when folks tend
to get riled up the most. Simply put: One has to be content with their
own personal choices in this hobby, as well as respect others for theirs. Tom
JSperan
Joined on
05-23-2009
I've always wondered what it would be like to see the two biggest egos on this forum duke it out! Sheldon, David, you should both take a bow. Sheldon, I have a good memory too. I still remember you asking a fellow from Norway if he was from the part of Europe your country "rescued" or the part who's butt you kicked. Considering Norway was in the war from the beginning, unlike the US...well you figure it out. Check your history.
ATLANTIC CENTRAL
Joined on
01-26-2009
Maryland
tstage: All I was doing was correcting your earlier generalization that all "low budget" decoders were of inferior quality. They are not.
Tom, maybe it did come across that way, but again, lets say I did go DCC with no sound, it is unlikely that $12 decoders would be the best choice for all my different locos and that was my main point regarding decoder cost.
tstage:I think when those from either DC or DCC camp makes untrue statements in regards to the other, that's when folks tend to get riled up the most.
DCC users on here endlessly make statements about DC based on next to no experiance with any advanced cab control system - yet no mater how carefully I state my opinions or reasons for my choices I get attacked. I know a little something about DCC. I have operated four different DCC layouts for 4-5 years now, one of those layouts I designed the track plan for.
It does get old being told "if you try it you'll like it" by DCC people with no knowledge or experiance with the type of DC system I use. Maybe they would like my system (or Ed Ravenscroft's MZL) if they tried it, but they where steared to DCC before they "learned" anything about these more advanced older technologies. That's fine, time marches on, but newer is not automaticly better, sometimes its just different, especally depending on the desired result.
Many choices in life should be based on ones personal goals rather than just "going with the crowd".
Remember, only dead fish go with the flow.
Sheldon
rrinker
Joined on
02-14-2002
Reading, PA
Yes, there is a huge difference in decoder quality. The Bachmann "on-board" ones aren't worth the pc board material they take up. MRC sells a motor-only deocder that costs MORE than the NCE D13SR/SRJ. The NCE D13SR is a top notch high-quality decoder.
Yes, back when DCC first appeared, decoders were $50 and up and had fewer features than that D13SR. But then again, previous command control systems cost even more AND the ENTIRE system was pretty much single vendor. With DCC you'd have to change the command station and throttles - eventually, when they wore out and you vendor was no longer in business. Most of the time you can use boosters from other manufacturers.
As for the Wangrow/NCE thing, correct, they no longer offer the support or upgrade - however they did for years. Any Wangrow users had plenty of time to get switched over.
--Randy
selector
Joined on
02-06-2005
Vancouver Island, BC
I invite the originator of this thread to use the "Search Community" function, just to the right, in the column next to this text box. If you use a syntax such as, "Best DCC system", you will find many threads extolling the virtues of DCC. Also, if you were to type, "DC or DCC", it would probably serve you well. There have been many threads on that subject.
I think we have mostly had our say in this thread, even if it is largely unsettled, so I will lock it. If you have a more specific question, please feel free to ask it in a new thread.
-Crandell
[locked]
