General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 11-22-2009 1:04 PM by inhrmswy. 8 replies.
Rate:
Sort Posts:
Page 1 of 1 (9 items)
11-19-2009 7:27 PM
Offline Moonie
Not Ranked
Joined on 05-01-2008
Posts 64
Erasing Decals?
Hi All,
 I've heard that if you want to remove decals from a locomotive or other rolling stock without damaging the underlying paint, you can take an eraser and simply rub them off. Is this true, and if so, does it matter what kind of eraser (hard, soft?) Also, is this maybe more for older Athearn BB rolling stock or can it be used on modern RTR rolling stock as well? Thanks in advance,
Peter.
11-19-2009 7:55 PM In reply to
Offline jeffrey-wimberly
Top 10 Contributor
Joined on 06-21-2004
Sundown, Louisiana
Posts 13,323
Re: Erasing Decals?
 It can be done with an eraser (not sure what type) but you have to be very careful not to mar the paint. I use acetone-free nail polish remover and a bit of a paper towel. It works well enough for me.
11-19-2009 8:09 PM In reply to
Offline hcc25rl
Not Ranked
Joined on 08-14-2006
Burnsville, MN
Posts 166
Re: Erasing Decals?
 Assuming that the area the decal is on hasn't been covered with Dullcote or something similar, you can use Micro-Sol or similar product to soften and remove the decal(s) with a paper towel. I'd avoid using ANY eraser as they are very abrasive although it may not be apparent at first, they DO leave subtle scratch marks. BE CAREFUL!
Jimmy
11-19-2009 8:15 PM In reply to
Offline Piedsou
Not Ranked
Joined on 03-02-2001
Waldorf, Maryland
Posts 143
Re: Erasing Decals?
Are you speaking of removing decal applied lettering or factory painted on lettering? The procedures for removing them can be different.
Dale Latham
11-20-2009 7:51 PM In reply to
Offline J W Bowker
Not Ranked
Joined on 09-09-2009
Central Arkansas
Posts 33
Re: Erasing Decals?
I'm also interested in this process, but in my case it would be removing modern factory applied lettering  on a couple of steam engines and tenders..
Correct me if I am wrong, but I think most manufacturers use some fairly sophisticated processes for lettering now rather than decals--possibly some form of computer controlled laser printing application that is a lot more sophisticated and precise than anything available to the hobbyist.
I do know that there are a variety of erasers available at art supply stores that have fairly low abrasive qualities so as not to damage high quality art and drafting papers when making corrections..
 Cheers
11-21-2009 3:52 PM In reply to
Offline john2wilm
Not Ranked
Joined on 11-01-2006
Wilmington, NC
Posts 60
Re: Erasing Decals?
 Removing factory lettering which is what I think you are asking, I have found using walthers micro sol and a sharp hobby knife, with a fine tip works well. the micro slol softens the paint and the knife scraps it off, then use a paper towel to wipe off the excess. Most of the paint that is applied by the manufacture can be lightly scrapped off. This is specially true for Roundhouse cars. The newer Athearn cars need to have the lettering softened a little before removing. It some times takes off some of the paint along with it. Hope this helps.
11-21-2009 5:52 PM In reply to
Offline retsignalmtr
Top 500 Contributor
Joined on 02-05-2002
Westchester NY
Posts 823
Re: Erasing Decals?
I just changed the road name and number on a Bachmann 2-8-0 today. It was decorated for New Haven and I needed it for the New York Central. The lettering looked like it was painted on. I coated the printing with Micro Sol for a few minutes, then using a tiny jewlers screwdriver scraped the printing until it loosened then rubbed it lightly with a pencil eraser until all the printing was gone without disturbing the loco's black paint. I wiped off the residue with a soft cloth and applied my new decals.
11-22-2009 12:43 AM In reply to
Offline nbrodar
Top 100 Contributor
Joined on 06-20-2005
Phoenixville, PA
Posts 3,315
Re: Erasing Decals?
 I'm usually able to remove most lettering using Solveset and an eraser.  Some paint is softer then others, so it takes some care to remove the lettering and not the paint.
Nick
11-22-2009 1:04 PM In reply to
Offline inhrmswy
Not Ranked
Joined on 08-21-2009
Posts 7
Re: Erasing Decals?
Recently I used MicroSol and an ink eraser (papermate) to strip the factory printing from a bunch of P2K 50 foot boxcars.  This does not scratch up the underlaying paint but does leave a shine.  Not to worry though, a quick misting of dulcote takes that away and you cant tell anything was ever there.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
