Electronics and DCC
The place to discuss wiring for DC and DCC controlled model train layouts. If you're new here, please read our forum policies.
Last post 11-20-2009 2:44 PM by tstage. 13 replies.
Rate:
Sort Posts:
Page 1 of 1 (14 items)
11-19-2009 2:19 PM
Offline berlingo
Not Ranked
Joined on 07-13-2007
Thailand
Posts 78
DCC ready & decoder?
Hi, I would like to ask you question about Bachmann EZ decoder . I have 20 locos from Athearn Dcc ready, need to install decoder by Bachmann. The question is Are they friendly to Athearn Dcc ready? If not which one will you be thinking ? I have Athearn DCC ready and Bachmann DCC on board locos, planning to buy Bachmann EZ digital controller . There is one shop in Thailand where i can find this staff. But for decoder is my question. I have my uncle who lives in Denver is coming down to Thailand next month , maybe this is a good time to buy from US. They are cheeper than here in Thailand. Thank you very much. BertAXM,
11-19-2009 2:48 PM In reply to
Offline berlingo
Not Ranked
Thailand
Posts 78
Re: DCC ready & decoder?
Sorry, my post is disappear on the 1st page. What' s wrong?
11-19-2009 2:49 PM In reply to
Offline tstage
Top 25 Contributor
Joined on 06-11-2003
Northeast OH
Posts 8,974
Kopong,
Generally speaking, decoders and locomotives are not brand-specific.  In other words, you don't have to use a Bachmann decoder (actually made by Lenz) with a Bachmann locomotive. Decoders are designed to go in a variety of manufacturer's products.
With that said, certain decoders may be designed to fit into a specific locomotive.  For example, Digitax decoders ending with the suffx "L0" are designed for Proto 1000/2000 locomotives.
Actually, what would be helpful, Kopong, is if you could list the Athearn locomotives (e.g. 2-8-2 Mikado, GP38-2, etc.) that you are looking to install decoders in.  That way folks can offer suggestions based on a specific locomotive.
11-19-2009 2:50 PM In reply to
Offline tstage
Top 25 Contributor
Northeast OH
Posts 8,974
berlingo:
Kopong,
Your post was moved to the Electronics and DCC forum.  It will get more answers that way.
11-19-2009 3:03 PM In reply to
Offline berlingo
Not Ranked
Thailand
Posts 78
Thank you very much Tom, I'm sorry for that, anyway my Athearn locos are AC4400, C44-9W ,SD 40, AMD 103, RS3, SW1500. Thank you very much.
11-19-2009 3:08 PM In reply to
Offline Phoebe Vet
Top 150 Contributor
Joined on 09-21-2007
Charlotte, NC
Posts 2,547
If you buy any electronics, including a DCC system, in the USA be sure that your electrical supply matches.  Is your electric service 120 VAC 60 HZ?  It often varies from country to country.
11-19-2009 4:06 PM In reply to
Offline cacole
Top 10 Contributor
Joined on 07-23-2003
Sierra Vista, Arizona
Posts 9,337
 Bachmann decoders are not very highly regarded for smooth motor control.  A TCS T-1 or NCE DA13SR would probably be a better choice if they'll fit.
I don't think all of the models you listed are DCC Ready so some may require soldering.
If you can send an e-mail to Bruce Petrarca at Litchfield Station or the folks at Ulrich Models Hobby Shop listing exactly what you have they can probably recommend which decoders you should use and whether or not they will require soldering.
Contact information for these two dealers can be found on their web sites:
http://www.mr-dcc.com
http://www.ulrichmodels.biz/servlet/StoreFront
Another problem you're probably going to encounter is the shipment of decoders to a foreign address if your uncle can't get them in time or runs into trouble with customs inspectors -- you never know what some countries will or will not allow to be imported.
11-19-2009 4:36 PM In reply to
Offline berlingo
Not Ranked
Thailand
Posts 78
Thank you very much for your great help, And my Athearn locos are blue boxes, Equipped with Quick Plug DCC technology Directional headlights. So, you just plug it in , right? and no soldering required. If i understand. And i've just looked to some of my locos said DCC ready wiring harness installed Directional headlights. What does that mean " DCC ready wiring harness installed Directional headlights" ? regarding to Dcc decoder A TCS T-1 or NCE DA13SR , Are they really be used with Bachmann digital controller? And i haven't heard about these brands. The electric service in my country is 220V 50/60Hz.
11-19-2009 5:01 PM In reply to
Offline cacole
Top 10 Contributor
Posts 9,337
If all of your locomotives are truly Athearn with Quick Plug Technology, then either of the decoders I mentioned will just plug in.  Any brand of NMRA-compliant decoder will work with any brand of Command Station.
Directional lights have nothing to do with DCC conversion, and neither does your local electrical service -- a DCC Command Station converts the AC voltage to the DCC standard voltage on the track as long as you have the power supply required by your local electrical service.
You need to open up all of your locomotives and verify that they have a JST 9-pin header (an oblong, white plastic socket) or an 8-pin NMRA Medium decoder socket to accept a decoder.  If any of them don't have one or both of these sockets in them, they are not DCC Ready and will require soldering.
Most DCC Ready Athearn locomotives have a dummy plug connected to the JST socket that has to be removed even if you're going to use the NMRA Medium 8-pin socket.
11-19-2009 5:38 PM In reply to
Offline Phoebe Vet
Top 150 Contributor
Charlotte, NC
Posts 2,547
berlingo:
That is the reason that I warned about the electric service.  It doesn't matter for the decoders but is DOES matter if he buys a controller in the USA.  If he does buy the controller in the USA he will have to buy a different power supply for it. In the case of the Bachmann that means a different transformer that plugs into the wall.
Any brand of DCC decoder will work with any brand of DCC controller.
11-20-2009 12:54 PM In reply to
Offline berlingo
Not Ranked
Thailand
Posts 78
I would like to thank you to. TOM Phoebe Vet and cacole Lots of appreciation. And one more question, please. "DCC ready wiring harness installed." What does this mean by that? Thank you very much.
11-20-2009 1:45 PM In reply to
Offline Phoebe Vet
Top 150 Contributor
Charlotte, NC
Posts 2,547
Basically all DCC ready means is that the motor is isolated from the frame.  Most, but not all, engines labeled DCC ready have an 8 pin socket, sometimes called a medium socket, already wired in.  Sometimes you just unplug the jumper and plug a decoder into that socket.  Sometimes you remove a board that is plugged into that socket and plug in a decoder.  It is just as simple as it sounds.
If it does not have the plug then you have to solder wires from the decoder harness to the engine. It is more difficult but not beyond the capability of anyone who knows how to solder.  The color code of the wires will come with the decoder.
11-20-2009 2:24 PM In reply to
Offline berlingo
Not Ranked
Thailand
Posts 78
Thank you Probe Vet, I got it, this is new thing for me to learn. I've been collecting model railroads from DC to DCC , just started my project with HO scale. My plan is to be both DC and DCC layout . I will have more questions in the nearly future. Thank you very much. From Thailand.
11-20-2009 2:44 PM In reply to
Offline tstage
Top 25 Contributor
Northeast OH
Posts 8,974
berlingo:
Kopong,
If you do plan to have both DC and DCC on the same layout, make sure that you keep the two COMPLETELY isolated electrically from one another.  DC & DCC do not play nicely together.  Ideally, you should have some sort of toggle switch that gives you an either/or - i.e. either DCC or DC; not both.
It isn't even advisable to have - for example - an outside track with DCC and an inside with DC, which is connected by crossover turnout.  Even if they are electrically isolated from one another, if you accidentally allow a locomotive to span the gap, you'll be cooking a lot of decoders that way.
Bottom line: Make sure you set your layout up as either/or.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
