Electronics and DCC
The place to discuss wiring for DC and DCC controlled model train layouts. If you're new here, please read our forum policies.
Last post 11-24-2009 11:39 AM by wedudler. 7 replies.
Rate:
Sort Posts:
Page 1 of 1 (8 items)
11-19-2009 5:29 AM
Offline derf
Not Ranked
Joined on 03-31-2009
Posts 24
turnouts
I have peco turnouts, both insul and electro frog. Will these work with DCC out of the box or are there modifications that need to be made? I have heard different things about shorts. They are code 100.
Thanks,
Derf
11-20-2009 3:49 AM In reply to
Offline retsignalmtr
Top 500 Contributor
Joined on 02-05-2002
Westchester NY
Posts 819
Re: turnouts
Both of those switch types will work on DCC but both have issues with DCC that you may run into that they don't have with DC. Decembers MR has an article explaining those problems. I model in N and have those problems with them on DCC. I have to use nail polish to extend the insulation beyond the frog of all my Peco and Atlas insulfrog switches to prevent shorts when wheels of cars and loco's bridge both rails. It's a simple fix.  Nail polish is harder than paint and will last longer between applications.
11-20-2009 5:24 AM In reply to
Offline derf
Not Ranked
Posts 24
Re: turnouts
Do you also use the polish on the electrofrogs?
derf
11-20-2009 8:33 AM In reply to
Top 500 Contributor
Westchester NY
Posts 819
Re: turnouts
The electro frog switches have a different problem with DCC than insul frog types do. Nail polish won't work there. It requires making cuts through the rails with a dermmel or razor saw and then some wiring and soldering to the rails along with auxiliary switch contacts to power the frog. If you don't have the DEC issue of MR, get it.
11-20-2009 3:41 PM In reply to
Offline locoi1sa
Top 500 Contributor
Joined on 07-12-2006
Posts 1,227
Re: turnouts
 Derf
 Here is all you need to know.
http://www.wiringfordcc.com/switches.htm
   Pete
11-22-2009 7:09 AM In reply to
Offline cacole
Top 10 Contributor
Joined on 07-23-2003
Sierra Vista, Arizona
Posts 9,322
Re: turnouts
 We have nearly 50 Peco code 100 Insulfrog turnouts on our large HO scale layout and use the North Coast Engineering ProCab radio throttles.  We have NEVER had a shorting problem on any Peco turnout.  I always use insulated rail joiners on both rails that diverge from the frog and then use separate feeder wires beyond the frog -- maybe that's the secret to avoiding shorts.
11-24-2009 11:09 AM In reply to
Offline bsteel4065
Not Ranked
Joined on 01-28-2001
United Kingdom
Posts 384
Re: turnouts
Hi
I have both Peco code 83 insulfrog and electrofrog turnouts on my layout using NEC ProCab and have no problems with either. I also have a live feed into the turnout and have insulated joiners on the two tracks out of the turnout. I then power the track the other side of the turnouts.
Hope this helps.
11-24-2009 11:39 AM In reply to
Offline wedudler
Top 500 Contributor
Joined on 09-16-2004
Germany
Posts 1,213
Re: turnouts
locoi1sa:
 Derf
   Pete
This is what I did with my Peco turnouts. Here're pictures.
Electrofrog or insulf frog, that's for me no question
Wolfgang
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
