General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 11-18-2009 8:40 PM by subman. 10 replies.
Rate:
Sort Posts:
Page 1 of 1 (11 items)
11-18-2009 12:50 PM
Offline wabash2800
Not Ranked
Joined on 09-26-2006
Posts 57
Why doesn't Floquil offer RR Tie Brown in a spary can?
I know they offer it in a paint jar and as a marker but it seems counter intuitive that they don't offer it in a spray can. (Rail Brown is offered in a spary can, as is Roof Brown.) I will go back and weather my ties for variation but could just zap the track on the sides with Rail Brown, and after dry,  zap it from directly above with the RR Tie Brown both using a spray can...
11-18-2009 1:36 PM In reply to
Offline tomikawaTT
Top 25 Contributor
Joined on 02-12-2005
Southwest US
Posts 7,715
Re: Why doesn't Floquil offer RR Tie Brown in a spary can?
Have you sent this question to the manufacturer?  It's not very likely that they'll find it by cruising this forum.
So happens, RR Tie Brown wouldn't do me much good.  Concrete ties, you see.
(Maybe concrete tie grey-white, to kill that plastic sheen?)
11-18-2009 2:01 PM In reply to
Offline wjstix
Top 50 Contributor
Joined on 02-14-2002
Mpls/St.Paul
Posts 6,172
Conversely, something I've wondered about is, why do they offer Great Northern "Big Sky Blue" in a spray can?? I guess it's usefull as a generic sky blue for backdrops (maybe a little dark) but how many people specifically model Great Northern 1967-70 that would be painting engines with a spray can??
11-18-2009 2:31 PM In reply to
Offline jeffrey-wimberly
Top 10 Contributor
Joined on 06-21-2004
Sundown, Louisiana
Posts 13,323
 I was wondering about this as well. A spray enamel I can deal with as I do any spray painting outside. An enamel in a jar wouldn't do me any good for indoor use as many enamel paints cause me health problems rather quickly even in a well vented room. Some kind of allergic reaction. All I could find it in was paint pens and they don't last very long and tend to flood the surface at first. The pens cause me problems as well but it takes longer. After thinking about it I came upon a solution that works for me. I made samples of the colors I use the most and went to Lowe's and had them made up in quart cans for the colors I use the most and 1/2 pint cans for the others. Most of it is flat latex so I can use it without going into a coughing fit every time I touch it and it's easy for me to filter and thin for air brush use and it cleans up easily with water. Now I don't have to wait for a nice windless day to paint outside. Yes, I tried the paint booth idea but there's not enough room in here for even a small one and I can't very well chop a hole through the wall to vent it and there are no windows that open. Besides, the enamel effects me inside, outside, everywhere. So as I said, this is a solution that works for me.
11-18-2009 2:35 PM In reply to
Offline cwclark
Top 100 Contributor
Joined on 01-30-2004
Crosby, Texas
Posts 3,531
I must be missing out but i've never seen floquil paint in a spray paint can. I always thought it was paint for air brush work.  at least that's what i use it for....chuck
11-18-2009 3:32 PM In reply to
Offline kog1027
Not Ranked
Joined on 10-06-2002
Central Florida - US
Posts 159
Chuck,
Floquil is owned by the same company that owns Testors & Rustoleum.  So, they definitely have access to the equipment to create spray cans.
I've noticed that some Floquil colors appear in their sister paint lines under different names.  It might pay to take a sample of Tie Brown to your local home improvement store and compare it to the Rustoleum offerings.
Mark Gosdin
11-18-2009 4:22 PM In reply to
Offline MikeFF
Not Ranked
Joined on 08-02-2006
Posts 33
I just painted my layout with an airbrush and Polly S RR Tie Brown thinned about 50% with rubbing alcohol, it works great. I did use an organics filtering mask and had no ill effects. You do have to be careful cleaning the rails as the ties are so slick that it is possible to scuff off the paint if you hit it with the abrasive block. Touch up is easy.
11-18-2009 4:39 PM In reply to
Offline markpierce
Top 50 Contributor
Joined on 04-04-2003
Union-Garratt Loco (Mark in Martinez, CA)
Posts 4,389
The Krylon brand has several spray paints I find particularly useful for painting/weathering track.  They are ultra flat black and brown (camouflage) interior/exterior paints and rust and grey primers.  I find them at hardware stores.  The price is a fraction for that charged by hobby paint suppliers.  Check'em out.
http://www.krylon.com/products/camouflage_paint_with_fusion_technology/
Mark
11-18-2009 4:53 PM In reply to
Offline CSX_road_slug
Top 500 Contributor
Joined on 06-23-2006
Baltimore, MD
Posts 1,075
cwclark:
I must be missing out but i've never seen floquil paint in a spray paint can. ...
That's not surprising.  Very few LHS's carry the Floquil spray cans - the only shop in my region that has them is M.B.Klein (modeltrainstuff.com).  Not sure exactly why, but I'm guessing that the spray cans have a shorter shelf life than the 2oz jars because their contents are under pressure.
11-18-2009 6:54 PM In reply to
Offline markie97
Not Ranked
Joined on 07-16-2006
Posts 25
I recently purchased Roof Brown in a spray can which is very close to RR Tie Brown.
Mark
11-18-2009 8:40 PM In reply to
Offline subman
Not Ranked
Joined on 01-10-2008
florida
Posts 126
Iv`e been wondering if this idea about letting the big box stores match the railroad colors would work. Most times the LHS is out of these colors and for that matter mb klein is out of the brown colors also. Today I went to Home Depot to look for a rust color for the rails and came home with a 2 oz. sample of Glidden Fresh Baked Pumpernickel (sample GLO 30)which is a perfect match for rust.The big craft stores do carry different brands other than Floquil & Poly Scale which will work also.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
